09-17-2012, 16:00 | #1 (permalink) |
Freak Poster Join Date: Dec 2011 Location: Poland
Member: 1709265 Status: Offline Thanks Meter: 41 | is that mean damaged flash chip? I have dead E52 (only vibrate). I read full flash and tried to recover SL data but result is always the same also when try with Restore SL from phone Code: Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 19F00008CA6C03440AD8983F669FB5C12478DD98 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 85F252E351E225CAFC4DFBC8041EABD2823E3500 ADL: phone is in flash mode Reading NPC certificate... IMEI : 359327034937155 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\3593270********_CRT_2nd.rpl Trying read spr block , wait ... Get phone data... Get flash data... SPR Read Ok! Spr saved to : 3593270********.spr ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Processing SimLock extraction.... Checking readed data, wait few seconds ID_INFO : ICPR82_11w16.3/19-05-11/RM-469 Initial data found, start fun... Elapsed: 00:00:30 Phone disconected! Connect phone on selected interface... program doesn't save _SIM.rpl _SIM.pm is that mean flash chip is damaged? BR |
09-18-2012, 03:34 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. No, something strange in windows, seems, it not allow create files. Try run BEST as admin, or if not luck - send SPR file to [email protected] |
09-19-2012, 09:29 | #3 (permalink) | |
Member: 1709265 Status: Offline Thanks Meter: 41 | Quote:
Code: card found: S/N 1A94:0118 registered to: rosta01 Connect phone on selected interface... Checking, wait ... Get phone info data from flash... IMEI : 359327034****** NPC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\359327034******_CRT_2nd.rpl Get secure data... ID_INFO : ICPR82_11w16.3/19-05-11/RM-469 Initial data found, start fun... Elapsed: 00:00:07 Checking, wait ... Get phone info data from flash... IMEI : 359345031****** NPC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\359345031******_CRT_2nd.rpl Get secure data... ID_INFO : ICPR82_11w16.4/02-06-11/RM-645 Initial data found, start fun... SimLock RPL saved : c:\InfinityBox\BEST\Backup\Cert\359345031******_SIM.rpl SimLock PM saved : c:\InfinityBox\BEST\Backup\Cert\359345031******_SIM.pm Done! Elapsed: 00:00:08 BR | |
The Following User Says Thank You to rastogsm For This Useful Post: |
09-20-2012, 09:29 | #7 (permalink) |
Member: 1709265 Status: Offline Thanks Meter: 41 | Yes it was locked, but some year ago I calculated code for this phone and I found it anyway isn't it strange that I read full flash of unlocked phone and rpl was locked |
