05-30-2015, 07:19 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: pakistan
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | Microsoft 535 RM-1090 drivers problem and show " winusb device (null) tried so far but not succeed to install it manually any solution plzzzz |
05-31-2015, 09:49 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Re-install drivers and if still same - install them manually to that WINUSB NULL |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
05-31-2015, 12:34 | #5 (permalink) |
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | thanks for reply..........problem solved. this site helps me a lot for understand........ https://msdn.microsoft.com/en-us/lib...(v=vs.85).aspx log: Code: Connect phone on selected interface... Core : v2.07 , WP8x FlashEngine : v8.5 FFU : RM1090_02063.00000.15114.43009_RETAIL_prod_signed_1020_01FA0C_000-HK.ffu Checking FFU file, wait... FFU Revision ID : 2.0 FFU Model ID : Nokia.MSM8212.P6214 FFU RootKeyHash : 8575FBF67B868C9B6E83EC22CA912F3D88EED8C1 FFU Languages : Portuguese(Brazil) , Russian , Belorusian , fr-ca , Indonesian , Korean , Polish , Ukrainian , Uzbekistan(Latin) , Catalan , Swedish , Bulgarian , Japanese , Spanish , English (UK) , Czech , Latvian , Slovak , Chinese , sr-latn-rs , af-za , Hindi (India) , gl-es , Turkish , Thai , Italian , Danish (Denmark) , ha-latn-ng , Slovenian , Malay (Malaysia) , Lithuanian , Persian (Iran) , Kazakh , Romanian , English , eu-es , Estonian , Filipino (Philippines) , Greek , Norwegian (Bokmal , Norway) , Finnish , Vietnamese , Arabic , Croatian , Portuguese(Portugal) , Chinese(Taiwan) , Macedonian , Hungarian , Spanish(Mexico) , Azerbaijan(Latin) , German , Albanian , Dutch (Netherlands) , French , Hwbre (Israel) , FFU ChipSectors : 15155200 FFU Header : 0x000E0000 FFU Payload : 0x72A20000 FFU FastVerify : Ok Waiting for phone... Dead mode is selected , no phone in normal mode found 1. Press and hold "Volume Down" 2. Insert USB cable 3. Hold button until phone will be detected Device catched in BOOT mode! Boot Mode confirmed! Setting Preloder Collect Info... Setting Application Setting Secure Collect Info... === Nokia Flash App info : Protocol Version : 2.34 Protocol Implementation : 2.59 === Phone Initial info : Phone RMxxx ID : RM-1090 Phone Model ID : Nokia.MSM8212.P6214.1.1 Phone Model PC : 059W7L1 Phone IMEI : 357819062232444 === eMMC info : eMMC Vendor : Hynix eMMC CID : 0090 eMMC Size : 7456 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : BC2353ACA62C327ECCD582A281CA4A5672F35001 === Other info : SD present : False Full Check skipped , will be checked by ImageSignature Battery Level : 56% Battery Level enough to flash FFU : RM1090_02063.00000.15114.43009_RETAIL_prod_signed_1020_01FA0C_000-HK.ffu Flashing FFU Sending FFU Header CertData Header sent , accepted :) Perform Data Partition Erase Erase done Sending FFU Payload Data... Finishing flashing Flashing done! Green Light :) Image Sent, processing PostFlash Make Factory Set : Ok PostFlash Finished Total flash time : 00:08:18 Rebooting Connect phone on selected interface... |
The Following User Says Thank You to Muhammadsaqib11 For This Useful Post: |
05-31-2015, 12:52 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Yeah, this helps a lot. Mostly - problem in OS, but can be used such workaround well. |
