04-26-2017, 10:11 | #1 (permalink) |
Freak Poster Join Date: Jan 2013 Location: RUSSIA
Member: 1872225 Status: Offline Sonork: 100.1668729 Thanks Meter: 32 | MTK Nokia 225 Unlock Procedure 0 Info 2017-04-24 17:35:46 -17 System SL3 unlock code (15 digits) 357814065560883 EXECUTING 1 Info 2017-04-24 16:11:41 -17 System SL3 unlock code (15 digits) 354252060010831 EXECUTING 2 -34 This is taking so much time.... This is not normal someone have faith in this service? Solve my problem, becouse last time it took 2 hours now its 2 days... |
04-27-2017, 19:20 | #2 (permalink) |
Member: 1872225 Status: Offline Sonork: 100.1668729 Thanks Meter: 32 | 221802863540464 Code not working 1 Info 2017-04-24 16:11:41 -17 System SL3 unlock code (15 digits) 354252060010831 EXECUTING 2 -34 Send me good working code please... Last edited by soulgsm; 04-27-2017 at 19:25. |
04-29-2017, 08:35 | #3 (permalink) |
Member: 1872225 Status: Offline Sonork: 100.1668729 Thanks Meter: 32 | Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Unlock procedure started... Using F-bus count... Sending code 221802863540464 Level : 7 to SimLock Server... Simlock Server Answer: Error Done! I need my credits back or fix this unlock code please i am waiting since the date 24... soon its 01.05 guys come on ... its a simple damn MTK |
04-29-2017, 08:39 | #5 (permalink) |
Member: 1872225 Status: Offline Sonork: 100.1668729 Thanks Meter: 32 | Phone found! MTKx Nokia Phone detected Read info... Ok Unlock procedure started... Using F-bus count... Sending code 221802863540464 Level : 7 to SimLock Server... Simlock Server Answer: Error Done! |
05-02-2017, 09:42 | #7 (permalink) | |
Member: 1872225 Status: Offline Sonork: 100.1668729 Thanks Meter: 32 | Dude Quote:
THEY GOT MY IMEI AS 15 DIGIT FOR UNLOCK PROCEDURE LOOK HERE 1 Info 2017-04-24 16:11:41 -17 System SL3 unlock code (15 digits) 354252060010831 EXECUTING 2 -34 STOP POSTING USELESS MESAGES | |
05-02-2017, 09:58 | #8 (permalink) |
Member: 1872225 Status: Offline Sonork: 100.1668729 Thanks Meter: 32 | ALL INFO Reading Phone Info.... Software ver : 30.06.11 00-00-00 RM-1012 IMEI 1 : 354252060010831 IMEI 2 : 123456789012345 XappVer : 000008E8 Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : EA CNT : PEARL.30.06.11.p2 Product SN : 564EB00AU Product code : 059W345 Base Prd.code: 059W428 Module code : 0206306 Hardware info======= HWID : 3401 LCDVer: TPO Lock info =========== IMEI : 354252060010831 IMEI spNet : 3A 45 52 02 06 10 80 13 Conf key : 800000000003000B Provider key : 2261000000000000 Country : Romania Operator : RO ORANGE Lock info: Block 1 L1:Close; SimLock status : Ok Security status : Ok Done! Unlock procedure started... Using F-bus count... Sending code 221802863540464 Level : 7 to SimLock Server... Simlock Server Answer: Error Done! |
05-02-2017, 13:07 | #9 (permalink) |
Member: 1872225 Status: Offline Sonork: 100.1668729 Thanks Meter: 32 | Please solve my problem ! It's my money you got , and without the procedure i payed ! Who are you to take my money and just leave my problem unsolved... Infinity Answer to the users ! |
05-02-2017, 13:28 | #10 (permalink) |
Member: 1872225 Status: Offline Sonork: 100.1668729 Thanks Meter: 32 | --- Insert USB cable now! --- Wait for phone... Phone found! [ 70 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : BFDEF51FCECB4190CE36CF9A84321EA7 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.30.06.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 Boot Ok Get settings... [INFO] : Encrypted RPL [RPL VERIFY] : Code 0x10 : MOBILE_ID match with MOBILE_ID info in RPL! Reset SimLock Counters Reset SimLock Counters Done! Security restored All done! Connect phone on selected interface... Phone not connected... Connect phone and try again... Phone found! MTKx Nokia Phone detected Read info... Ok Unlock procedure started... Using F-bus count... Sending code 221802863540464 Level : 7 to SimLock Server... Simlock Server Answer: Error Done! I even flashed the phone Reseted the NCK counters... it gives me CODE ERROR I have 5 more pieces to unlock like this model ....i want to change my mind but i have faith in infinity. I wait for the refund to go on with the unlocking ! |
05-03-2017, 07:02 | #11 (permalink) |
Member: 1872225 Status: Offline Sonork: 100.1668729 Thanks Meter: 32 | Unlock procedure started... Using F-bus count... Sending code 221802863540464 Level : 7 to SimLock Server... Simlock Server Answer: Error Done! Unlock procedure started... Using F-bus count... Sending code 221802863540464 Level : 7 to SimLock Server... Simlock Server Answer: Error Done! I am still waiting it has been 9 days since i have been with this request, i will wait untill my phone ill be solved. |
05-03-2017, 08:13 | #12 (permalink) |
Freak Poster Join Date: May 2012 Location: sheikhupora pakistan
Member: 1763350 Status: Offline Sonork: 100.1623253 Thanks Meter: 13 | HELLO I THINK INFINITY TEAM IS SLEEPING THEY DON'T WANT TO GIVE A REPLY THEY MUST SHOULD'VE GIVE A RESPONSE THEIR PRODUCT USERS regard tahir,,, |
05-08-2017, 10:39 | #13 (permalink) |
Member: 1872225 Status: Offline Sonork: 100.1668729 Thanks Meter: 32 | I have made a request 26-04-17, 09:11 and i did not recived anything regarding my CODE / PAYMENT / REFUND / REQUEST. I will inform the Head administrator of this forum about this product robberry from users money. Its not allright to just stay and ignore your members. I will post the paypal transaction/ the kindness i had with this team products and solutions. Maybe someone higher will solve my issue. I need refund of my 12 credits to start new unlock procedure becouse i dont wanna quit using Infinity BST. |I will wait an answer in less than 24 Hours Once again , its not about money its about customers care. |
