02-20-2013, 18:59 | #3 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: islamabad
Member: 352880 Status: Offline Sonork: 100.1609545 Thanks Meter: 554 | Quote:
i did every thing change PC change usb port reinstall windows reinstall drivers else .......... suddenly one day he was working one time and after put out the usb port and again put in to usb port then not working best software show Best dongle is not connected i change the dongle Sim socket but no success .......... still i loss my best dongle till i use best dongle cracked its not enjoy able to use cracked software plz recover my best dongle i want to use original......... *** blessed you | |
02-20-2013, 20:15 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Try to clean Smart-Card contacts, this may helps. Also you can try to heat smart-card little bit, this may solve the problem if it was contacts problem. Also we can try to re-program this card remotely, but if cards become damaged physically this operation may not helps. |
02-21-2013, 09:28 | #5 (permalink) | |
smart card is ok and perfect i think the fault in the dongle parts may be dongle chips ic are damaged | |
02-22-2013, 11:35 | #8 (permalink) | |
To make re-programming try contact to [email protected] You should tell to us your Dongle S/N (check it in old log files) and explain the problem well to supporter via e-mail. | |
02-25-2013, 08:46 | #9 (permalink) | |
plz hel me ... tell me which ic is damage or where i bought the new best dongle smart card reader | |
02-25-2013, 13:00 | #10 (permalink) | |
1. Card-Reader (small USB device that looks like a flash disk) 2. BEST Smart-Card (white card like an ordinary SIM card) If you have other Card-Reader f.e. PKey - insert BEST SmartCard into that Card Reader and see results. | |
08-20-2019, 14:05 | #15 (permalink) |
Junior Member Join Date: Nov 2010
Member: 1449331 Status: Offline Thanks Meter: 4 | Boot: Usb Key BL V1.22 Connect to server .... ok Update firmware step1 ... ok Update firmware step2 ... failed 21,error after this error my bst dongle not working... only red light showing... i was changed 8.000 ctrystal but same problem... dongle port is also showing but not working.. in bst fwupdater is showing empty no, serial key number showing .... and update button is desible... plzzzzz help me |
