04-08-2013, 09:50 | #1 (permalink) |
Freak Poster Join Date: Feb 2008
Member: 714291 Status: Offline Thanks Meter: 39 | N9 flashing error! I have nokia N9 with security code forgotten Trying to remove it by flashing but am getting downgrade try error Downloaded many latest files and due to best tool directory but failed Can anyone analyze this log file and direct me to the right path please! Thank you! Check : Processing 3290ADCC_DFL61_HARMATTAN_40.2012.21-3.480.04.1_PR_LEGACY_480_ARM_RM-696_PRD_signed.bin ========== FW APE version : 40.2012.21-3.480.04.1 FW CMT version : 9.2.2011.51 FW PRx release : PR_1.3 FW Region info : BRANDED TO CARRIER FW Region ver : 480 KERNEL version : 2.6.32-20121301+0m8 ========== Check : File Is Ok ! Core : v1.62 , Tablet FlashEngine : v3.0 Insert cable in to powered OFF phone! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RM-696 , HWRev : 1603 NOLO : 01/06/23 SWVer: DFL61_HARMATTAN_40.2012.21-3.365.2_PR_365 Device mode : Production mode ========== FW APE version : 40.2012.21-3.365.2 FW PRx release : PR_1.3 FW Region info : BRANDED TO CARRIER FW Region ver : 365 ========== Read info Ok === SW version Check ==== Ok [Reflashing or Upgrade] === SW version Check ==== Processing APE Boot... File : 3290ADCC_DFL61_HARMATTAN_40.2012.21-3.480.04.1_PR_LEGACY_480_ARM_RM-696_PRD_signed.bin Processing : ape-algo APE Algorithm boot Ok Reopening the connection... RFS mode init Ok Device : RM-696 HW build : 1603 Bat.level : 89 SW release : (empty) Protocol : 108 UPDAPP ver : 1.7.2 Upd/Dev PT : 3 , 3 FL_images : cert-sw,xloader,secondary,rootfs,kernel,moslo,config,mm c,tar,cmt-2nd,cmt-algo,cmt-mcusw Last errors : bb5_rdc_cert_read failed Code Match Ok HW match Ok RFS Set : Host Protocol set to 108 RFS Set : CMT Verify On RFS Set : Perform RFS On RFS Set : eMMC preserve On ---Processing MCU image--- Processing File : 3290ADCC_DFL61_HARMATTAN_40.2012.21-3.480.04.1_PR_LEGACY_480_ARM_RM-696_PRD_signed.bin RFS : Sending config for [cert-sw] -> Ver T : RM-696 -> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805 RFS : Init pipe 00 RFS : Flashing... RFS : Finalizing... cert-sw Flash done RFS : ERROR_SECURITY! PHONE REPORT DOWNGRADE TRY! Receiving error list... Last Errors : bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed Downgrade disallowed (1352704526) [Pipe 0] Finishing in error state with status 10 Flashing failed More info in Last Error Log Elapsed: 00:00:13 Connect phone on selected interface... |
04-08-2013, 17:40 | #3 (permalink) | |
Member: 714291 Status: Offline Thanks Meter: 39 | Quote:
Bro, Is this not bigger enough to overcome the one it has? 64612199_DFL61_HARMATTAN_40.2012.21-3.427.6_PR_LEGACY_427_ARM_RM-696_PRD_signed But it gives the same error Please help me to figure out! | |
04-09-2013, 17:13 | #5 (permalink) | |
I have searched every where in navy firm but not found that version I have even downloaded as per its product id 059j217 but same error Can any one please upload such file so i can revive my N9 Thank you! | |
