12-16-2013, 07:45 | #1 (permalink) | |
No Life Poster Join Date: Aug 2011 Location: Afghanistan
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 368 | N9 Flashing Error please help ! Quote:
WBR | |
12-16-2013, 10:38 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. If you check this in log : Code: bmeipc_open failed Could not read battery level Seems as power fault. Try other battery for start (which is 100% works) Check BSI line. Check Pearl. Check Omap power and Rapu power lines according service manual. |
The Following User Says Thank You to Dzirt For This Useful Post: |
07-07-2014, 12:42 | #3 (permalink) | ||
No Life Poster Join Date: Jan 2008 Location: Kabul Afghanistan
Member: 687312 Status: Offline Thanks Meter: 290 | Quote:
Sir I also have problem with flashing a N9 : Quote:
WBR | ||
07-08-2014, 07:46 | #6 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | 480 , for example. Should work for it. Also, if no luck - Tools - XcntTool - MeeGo - N9 - Make UniFw (NOT tick MODEM patch) , select Fw 480. Flash file. |
07-10-2014, 09:21 | #7 (permalink) | |
Sir there isnt any FW 480 in navimanager and would you please give the link for that tool or tell me the exact name of it ? WBR | |
