09-03-2014, 10:47 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Afghanistan Kabul
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,472 | N9 Flashing Failed Code: Connect phone on selected interface... Check : Processing 43AD05DD_DFL61_HARMATTAN_40.2012.21-3.454.6_PR_LEGACY_454_ARM_RM-696_PRD_signed.bin ========== FW APE version : 40.2012.21-3.454.6 FW CMT version : 9.2.2011.51 FW PRx release : PR_1.3 FW Region info : BRANDED TO CARRIER FW Region ver : 454 KERNEL version : 2.6.32-20121301+0m8 ========== Check : File Is Ok ! Core : v1.95 , Tablet FlashEngine : v5.4 Insert cable in to powered OFF phone! (Ignore if phone Connected) Waiting for NOLO... Maemo Phone not found :( Core : v1.95 , Tablet FlashEngine : v5.4 Insert cable in to powered OFF phone! (Ignore if phone Connected) Waiting for NOLO... === SW version Check ==== Skipped!!! Reason : empty initial data ( IF YOU FLASH eMMC ONLY - SKIP this!) === SW version Check ==== Processing APE Boot... File : 43AD05DD_DFL61_HARMATTAN_40.2012.21-3.454.6_PR_LEGACY_454_ARM_RM-696_PRD_signed.bin Processing : ape-algo APE Algorithm boot Error Boot error #1 Try again few times. Check cable and battery Elapsed: 00:01:03 Connect phone on selected interface... Core : v1.95 , Tablet FlashEngine : v5.4 Insert cable in to powered OFF phone! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RM-696 , HWRev : 1603 NOLO : 01/06/23 SWVer: DFL61_HARMATTAN_40.2012.21-3_PR_006 Device mode : Production mode ========== FW APE version : 40.2012.21-3 FW PRx release : PR_1.3 FW Region info : MIDDLE EAST FW Region ver : 006 ========== Read info Ok === SW version Check ==== Ok [Reflashing or Upgrade] === SW version Check ==== Processing APE Boot... File : 43AD05DD_DFL61_HARMATTAN_40.2012.21-3.454.6_PR_LEGACY_454_ARM_RM-696_PRD_signed.bin Processing : ape-algo APE Algorithm boot Ok Reopening the connection... MKII mode init Ok Device : RM-696 HW build : 1603 Bat.level : 11 SW release : (empty) Protocol : 108 UPDAPP ver : 1.7.2 Upd/Dev PT : 3 , 3 FL_images : cert-sw,xloader,secondary,rootfs,kernel,moslo,config,mmc,tar,cmt-2nd,cmt-algo,cmt-mcusw Last errors : bb5_rdc_cert_read failed Code Match Ok HW match Ok Battery Voltage is low [ 11% ] , Charging, wait... Charge done. Can proceed now MKII Set : Host Protocol set to 108 MKII Set : CMT Verify On MKII Set : Modem Factory Set is On MKII Set : eMMC preserve On ---Processing MCU image--- Processing File : 43AD05DD_DFL61_HARMATTAN_40.2012.21-3.454.6_PR_LEGACY_454_ARM_RM-696_PRD_signed.bin MKII : Sending config for [cert-sw] -> Ver T : RM-696 -> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805 MKII : Init pipe 00 MKII : Flashing... MKII : Finalizing... cert-sw Flash done MKII : Sending config for [kernel] -> Ver I : 2.6.32-20121301+0m8 MKII : Init pipe 01 MKII : Flashing... MKII : Finalizing... kernel Flash done MKII : Sending config for [rootfs] -> Ver I : DFL61_HARMATTAN_40.2012.21-3.454.6_PR_454 MKII : Init pipe 02 MKII : Flashing... MKII : Finalizing... rootfs Flash done MKII : Sending config for [cmt-2nd] -> Ver T : RM-696 MKII : Init pipe 03 MKII : Flashing... MKII : Finalizing... cmt-2nd Flash done MKII : Sending config for [cmt-algo] -> Ver T : RM-696 MKII : Init pipe 04 MKII : Flashing... MKII : Finalizing... cmt-algo Flash done MKII : Sending config for [cmt-mcusw] -> Ver I : 9.2.2011.51 -> Ver T : RM-696 MKII : Init pipe 05 MKII : Flashing... MKII : Finalizing... MKII : ERROR_PIPE_FINAL_REQ FAILED Receiving error list... Last errors : MTC_NOS_READY not received MTC_NOS_READY not received MTC_NOS_READY not received CMT RFS failed [Pipe 5] Finishing in error state with status 1 Flashing failed More info in Last Error Log ======= ERROR HANDLING ======= CMT_FINALIZE_ERROR : Failed to verify CMT HowTo Fix : Make Patched FW in xCntTool [MeeGo] module and flash it ======= ERROR HANDLING ======= Elapsed: 00:31:59 Phone disconected! Connect phone on selected interface... Connect phone on selected interface... |
09-03-2014, 11:15 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hi. Does it very hard to read software log and not stupidly try again and again? Code: ======= ERROR HANDLING ======= CMT_FINALIZE_ERROR : Failed to verify CMT HowTo Fix : Make Patched FW in xCntTool [MeeGo] module and flash it ======= ERROR HANDLING ======= |
