08-25-2013, 04:24 | #1 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | n9 tried to flash error-help registered to: zonetrichur Connect phone on selected interface... - > Press "Check Files" for check and select data - > Needed parts can be checked or unchecked manually Check : Processing DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_006-OEM1-958_ARM.bin ========== FW APE version : 40.2012.21-3 FW CMT version : 9.2.2011.51 FW PRx release : PR_1.3 FW Region info : MIDDLE EAST FW Region ver : 006 KERNEL version : 2.6.32-20121301+0m8 ========== Check : File Is Ok ! Core : v1.64 , Tablet FlashEngine : v3.1 Insert cable in to powered OFF phone! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RM-696 , HWRev : 1603 NOLO : 01/06/23 SWVer: DFL61_HARMATTAN_40.2012.21-3_PR_006 Device mode : Production mode ========== FW APE version : 40.2012.21-3 FW PRx release : PR_1.3 FW Region info : MIDDLE EAST FW Region ver : 006 ========== Read info Ok === SW version Check ==== Ok [Reflashing or Upgrade] === SW version Check ==== Processing APE Boot... File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_006-OEM1-958_ARM.bin Processing : ape-algo APE Algorithm boot Ok Reopening the connection... RFS mode init Ok Device : RM-696 HW build : 1603 Bat.level : 51 SW release : (empty) Protocol : 108 UPDAPP ver : 1.7.2 Upd/Dev PT : 3 , 3 FL_images : cert-sw,xloader,secondary,rootfs,kernel,moslo,config,mm c,tar,cmt-2nd,cmt-algo,cmt-mcusw Last errors : bb5_rdc_cert_read failed Code Match Ok HW match Ok RFS Set : Host Protocol set to 108 RFS Set : CMT Verify On RFS Set : Perform RFS On RFS Set : eMMC preserve On ---Processing MCU image--- Processing File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_006-OEM1-958_ARM.bin RFS : Sending config for [cert-sw] -> Ver T : RM-696 -> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805 RFS : Init pipe 00 RFS : Flashing... RFS : Finalizing... cert-sw Flash done RFS : Sending config for [kernel] -> Ver I : 2.6.32-20121301+0m8 RFS : Init pipe 01 RFS : Flashing... RFS : Finalizing... kernel Flash done RFS : Sending config for [rootfs] -> Ver I : DFL61_HARMATTAN_40.2012.21-3_PR_006 RFS : Init pipe 02 RFS : Flashing... RFS : ERROR_PIPE_CHECK_REQ FAILED Receiving error list... Last errors : mmc: sfdisk returned status 1 mmc: Could not exec 'tune2fs -L rootfs /tmp/sudmmcK1hlp6/internal0p2' mmc: Could not remove mount directory /tmp/sudmmcK1hlp6/mnt: No such file or directory [Pipe 2] Finishing in error state with status 1 why above error? |
