06-18-2013, 04:47 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: PAKISTAN
Member: 1435528 Status: Offline Sonork: 100.1603713 Thanks Meter: 217 | N900 flashing problem registered to: hussainafridi Connect phone on selected interface... Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2101 NOLO : 01/0E/14 SWVer: RX-51_2009SE_10.2010.19-1.003_PR_003 Device mode : Production mode Read info Ok ---Processing MCU image--- Processing APE part File : 43925734_RX-51_2009SE_1.2009.42-11.203.2_PR_F5_203_ARM.bin Processing : kernel , 2.6.28-20094102.3+0m5 Kernel flash Ok Processing APE part File : 43925734_RX-51_2009SE_1.2009.42-11.203.2_PR_F5_203_ARM.bin Processing : rootfs , RX-51_2009SE_1.2009.42-11.203.2_PR_203 RootFs flash Ok Processing CMT part File : 43925734_RX-51_2009SE_1.2009.42-11.203.2_PR_F5_203_ARM.bin Processing : cmt-2nd , 8.2.2009.34.3-2+0m5 Processing : cmt-algo , 8.2.2009.34.3-2+0m5 Processing : cmt-mcusw , 8.2.2009.34.3-2+0m5 CMT part prepare Ok, files are sent Program CMT request Ok Switch : OSSO UART+USB Version : RX-51_2009SE_1.2009.42-11.203.2_PR_203 Switch CMT request Ok CMT : Erasing... CMT : Program... CMT : Program Finished! ---Processing eMMC image--- Setting RFS ... Reopening the connection... Failed set RFS mode! #2 Seems as Cable/Driver/Battery problem Connect phone on selected interface... mobile working is ok but when i open camera then he show this (not enough memory to open camera solution) i want to flash with emmc file . plz gide me how can we do this ok ? |
The Following User Says Thank You to DILDIL-PAKISTAN For This Useful Post: |
06-18-2013, 07:12 | #2 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 666540 Status: Offline Thanks Meter: 354 | Quote:
Flash your mobile with this version & let me know what is the result...... Nokia N900 RX-51 Version 21.2011.38.1 | |
06-18-2013, 09:15 | #5 (permalink) |
Member: 1435528 Status: Offline Sonork: 100.1603713 Thanks Meter: 217 | Connect phone on selected interface... Check : Processing RX-51_2009SE_21.2011.38-1.004_PR_COMBINED_004_ARM.bin ========== FW APE version : 21.2011.38-1.004 FW CMT version : rx51_ICPR82_10w08 FW PRx release : PR_1.4 FW Region info : INDIA FW Region ver : 004 KERNEL version : 2.6.28-20103103+0m5 ========== Check : File Is Ok ! Core : v1.64 , Tablet FlashEngine : v3.1 Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2101 NOLO : 01/0E/14 SWVer: RX-51_2009SE_20.2010.36-2.203.1_PR_203 Device mode : Production mode ========== FW APE version : 20.2010.36-2.203.1 FW PRx release : PR_1.3 FW Region info : UK FW Region ver : 203 ========== Read info Ok === SW version Check ==== Skipped!!! Reason : User Request === SW version Check ==== ---Processing MCU image--- Processing NOL part File : RX-51_2009SE_21.2011.38-1.004_PR_COMBINED_004_ARM.bin Processing : xloader , 1.4.14.9+0m5 Processing : secondary , 1.4.14.9+0m5 NOL part Ok, boot flash done Processing APE part File : RX-51_2009SE_21.2011.38-1.004_PR_COMBINED_004_ARM.bin Processing : kernel , 2.6.28-20103103+0m5 Kernel flash Ok Processing APE part File : RX-51_2009SE_21.2011.38-1.004_PR_COMBINED_004_ARM.bin Processing : rootfs , RX-51_2009SE_21.2011.38-1.004_PR_004 RootFs flash Ok Processing CMT part File : RX-51_2009SE_21.2011.38-1.004_PR_COMBINED_004_ARM.bin Processing : cmt-2nd , BB5_09.36 Processing : cmt-algo , BB5_09.36 Processing : cmt-mcusw , rx51_ICPR82_10w08 CMT part prepare Ok, files are sent Program CMT request Ok Switch : OSSO UART+USB Version : RX-51_2009SE_21.2011.38-1.004_PR_004 Switch CMT request Ok CMT : Erasing... CMT : Program... CMT : Program Finished! Executing PostFlash : RX-51_2009SE_21.2011.38-1.004_PR_004 Executing PostFlash : Reset RD Flags Executing PostFlash : Reboot Done! Elapsed: 00:01:49 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok AFTER FLSAHING NEW VERGEEN BUT PROBLEM IS SEAM |
