05-15-2013, 13:21 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india Age: 37
Member: 1146038 Status: Offline Thanks Meter: 196 | n900 give me error in flashing why please team help.... log ... Code: card found: S/N Connect phone on selected interface... Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2101 NOLO : 01/0E/14 SWVer: RX-51_2009SE_20.2010.36-2.203.1_PR_203 Device mode : Production mode ========== FW APE version : 20.2010.36-2.203.1 FW PRx release : PR_1.3 FW Region info : UK FW Region ver : 203 ========== Read info Ok Check : Processing RX-51_2009SE_21.2011.38-1_PR_COMBINED_MR0_ARM.bin ========== FW APE version : 21.2011.38-1 FW PRx release : PR_1.4 FW Region info : GLOBAL FW Region ver : MR0 KERNEL version : 2.6.28-20103103+0m5 ========== Check : File Is Ok ! Core : v1.64 , Tablet FlashEngine : v3.1 Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2101 NOLO : 01/0E/14 SWVer: RX-51_2009SE_20.2010.36-2.203.1_PR_203 Device mode : Production mode ========== FW APE version : 20.2010.36-2.203.1 FW PRx release : PR_1.3 FW Region info : UK FW Region ver : 203 ========== Read info Ok === SW version Check ==== Skipped!!! Reason : empty initial data ( IF YOU FLASH eMMC ONLY - SKIP this!) === SW version Check ==== ---Processing MCU image--- Processing APE part File : RX-51_2009SE_21.2011.38-1_PR_COMBINED_MR0_ARM.bin Processing : kernel , 2.6.28-20103103+0m5 Kernel flash Ok Processing APE part File : RX-51_2009SE_21.2011.38-1_PR_COMBINED_MR0_ARM.bin Processing : rootfs , RX-51_2009SE_21.2011.38-1_PR_MR0 thanks advance |
05-15-2013, 15:21 | #4 (permalink) |
Member: 1146038 Status: Offline Thanks Meter: 196 | give me this error but this error solve .... bcoz this is my side problem " flash file not download proper so " sorry for that but now download complete file and flash also done but problem not solve set auto restart so now where is problem ..... thanks advance Code: card found: Connect phone on selected interface... Check : Processing RX-51_2009SE_21.2011.38-1_PR_COMBINED_MR0_ARM.bin ========== FW APE version : 21.2011.38-1 FW CMT version : rx51_ICPR82_10w08 FW PRx release : PR_1.4 FW Region info : GLOBAL FW Region ver : MR0 KERNEL version : 2.6.28-20103103+0m5 ========== Check : File Is Ok ! Core : v1.64 , Tablet FlashEngine : v3.1 Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2101 NOLO : 01/0E/14 SWVer: RX-51_2009SE_21.2011.38-1_PR_MR0 Device mode : Production mode ========== FW APE version : 21.2011.38-1 FW PRx release : PR_1.4 FW Region info : GLOBAL FW Region ver : MR0 ========== Read info Ok === SW version Check ==== Skipped!!! Reason : empty initial data ( IF YOU FLASH eMMC ONLY - SKIP this!) === SW version Check ==== ---Processing MCU image--- Processing NOL part File : RX-51_2009SE_21.2011.38-1_PR_COMBINED_MR0_ARM.bin Processing : xloader , 1.4.14.9+0m5 Processing : secondary , 1.4.14.9+0m5 NOL part Ok, boot flash done Processing APE part File : RX-51_2009SE_21.2011.38-1_PR_COMBINED_MR0_ARM.bin Processing : kernel , 2.6.28-20103103+0m5 Kernel flash Ok Processing APE part File : RX-51_2009SE_21.2011.38-1_PR_COMBINED_MR0_ARM.bin Processing : rootfs , RX-51_2009SE_21.2011.38-1_PR_MR0 RootFs flash Ok Processing CMT part File : RX-51_2009SE_21.2011.38-1_PR_COMBINED_MR0_ARM.bin Processing : cmt-2nd , BB5_09.36 Processing : cmt-algo , BB5_09.36 Processing : cmt-mcusw , rx51_ICPR82_10w08 CMT part prepare Ok, files are sent Program CMT request Ok Switch : OSSO UART+USB Version : RX-51_2009SE_21.2011.38-1_PR_MR0 Switch CMT request Ok CMT : Erasing... CMT : Program... CMT : Program Finished! Executing PostFlash : Reboot Done! Elapsed: 00:01:52 Connect phone on selected interface... |
05-15-2013, 16:52 | #6 (permalink) |
Member: 1146038 Status: Offline Thanks Meter: 196 | see this is log ... Read info Ok Enable R&D mode... Device state : R&D mode Enable OMAP WatchDog (Will NOT allow modify Kernel) OMAP WatchDog check set Ok but problem not solve ... |
05-15-2013, 18:17 | #7 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Need DISABLE OMAP WD. And other things, expect RD should be disabled. If not help - I was say what to do. Sw here can't help anymore. Also, try flash with eMMC content fie, but I sure on 95% - it not help. |
