11-25-2012, 14:18 | #1 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | N900 Only Nokia logo done via BEST 1.57 Code: card found: S/N .............. registered to: mbiborna Connect phone on selected interface... Check : Processing RX-51_2009SE_21.2011.38-1.003_PR_COMBINED_003_ARM.bin ========== FW APE version : 21.2011.38-1.003 FW CMT version : rx51_ICPR82_10w08 FW PRx release : PR_1.4 FW Region info : MIDDLE EAST , North Africa FW Region ver : 003 KERNEL version : 2.6.28-20103103+0m5 ========== Check : File Is Ok ! Core : v1.57 , FlashEngine : v2.7 Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2101 NOLO : 01/0E/14 SWVer: RX-51_2009SE_21.2011.38-1_PR_MR0 Device mode : Production mode ========== FW APE version : 21.2011.38-1 FW PRx release : PR_1.4 FW Region info : GLOBAL FW Region ver : MR0 ========== Read info Ok === SW version Check ==== Skipped!!! Reason : empty initial data ( IF YOU FLASH eMMC ONLY - SKIP this!) === SW version Check ==== ---Processing MCU image--- Processing NOL part File : RX-51_2009SE_21.2011.38-1.003_PR_COMBINED_003_ARM.bin Processing : xloader , 1.4.14.9+0m5 Processing : secondary , 1.4.14.9+0m5 NOL part Ok, boot flash done Processing APE part File : RX-51_2009SE_21.2011.38-1.003_PR_COMBINED_003_ARM.bin Processing : kernel , 2.6.28-20103103+0m5 Kernel flash Ok Processing APE part File : RX-51_2009SE_21.2011.38-1.003_PR_COMBINED_003_ARM.bin Processing : rootfs , RX-51_2009SE_21.2011.38-1.003_PR_003 RootFs flash Ok Processing CMT part File : RX-51_2009SE_21.2011.38-1.003_PR_COMBINED_003_ARM.bin Processing : cmt-2nd , BB5_09.36 Processing : cmt-algo , BB5_09.36 Processing : cmt-mcusw , rx51_ICPR82_10w08 CMT part prepare Ok, files are sent Program CMT request Ok Switch : OSSO UART+USB Version : RX-51_2009SE_21.2011.38-1.003_PR_003 Switch CMT request Ok CMT : Erasing... CMT : Program... CMT : Program Finished! Executing PostFlash : Reboot Done! Elapsed: 00:02:05 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia N900 Software ver : RX-51_21.2011.38.1 V 0.0.000 RX-51 (c) NOKIA IMEI : 356938030702386 Ape Ver : Nokia N900 (RX-51 rev 2101) Maemo 5 (21.2011.38.1.003) Linux version 2.6.28-omap1 Product 0582647A APE Var : 0582647A DSP Ver : ICPR82_10w08 APE Test: RX-51_2009SE_21.2011.38-1.003_PR_003 PPM : CNT : Product SN : MUM325532 Product code : 0582647 Module code : 0203827 Long Prod.SN : 0 Hardware info======= HWID : 2101 Retu : 34 Tahvo : 00 Batery: 0 mV APE HW: RX-51 rev 2101 Lock info =========== IMEI : 356938030702386 IMEI spNet : 3A 65 39 08 03 07 32 08 IMEI svNet : 33 65 39 08 03 07 32 28 F1 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Not Present SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : Not Set UserDataExLevel : Error! Can't read initial data Done! |
The Following User Says Thank You to mbiborna For This Useful Post: |
