11-04-2012, 20:50 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | N96 security damaged Code: 1st boot Ok, C0 APE part info : APE ASICID : 008815D3 APE MODE ID : 00 APE PUB ID : 503231755E3789321FCADEB0D17E04313D0284A7 APE R_HASH : 0BBC4203E2D3B82504C75CB65E906A35 APE ROM ID : 137A9A3B33259D2C CMT part info : CMT ASICID : 000000010000022600010006400C192101031103 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 049001152A7500525AD13A8885792690E820F2D1 CMT MODE ID : 00 CMT R_HASH : CAEEBB65D3C48E6DC73B49DC5063A2EE CMT ROM ID : 4B9B75103E691FF8 CMT : Sending 2nd loader... CMT Loader sent, Boot Ok rap= 049001152A7500525AD13A8885792690E820F2D1 hash= CAEEBB65D3C48E6DC73B49DC5063A2EE key= 516C0F2C870051EF095235CDE455D6B2D48F28B6 Init Service mode... Wait... Key file updated... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" enabled, try again now - > If SDD original - "Use Server Sx4" Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 359320023929457 Use custom key... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" disabled, try again now - > If SDD original - "Use Server Sx4" Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 359320023929457 Use custom key... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" disabled, try again now - > If SDD original - "Use Server Sx4" Local SX4 procedure started... Check SD : Key Damaged!!! SX4 Auth error :( Repair SD procedure started... Phone Imei: 359320023929457 Key file exists, no need to read... Accepted SdRepReq (on alive SD) by user Operating mode is OK, no need change... Writing Super Dongle Key... Error Repair fail...! Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok CMLA Key status : CMLA key is Ok SimLock status : SimLock is Ok Security status : Security Damaged!!!!! :( - > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual ) Code: Check SD : Key is Ok Phone Imei: 359320023929457 Use custom key... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" disabled, try again now - > If SDD original - "Use Server Sx4" Operating mode is OK, no need change... Field 1 Record 0 write - Error Record 2 write - Error Record 4 write - Error Record 6 write - Error Record 8 write - Error Record 13 write - Error Record 16 write - Error Record 18 write - Error Record 20 write - Error Record 22 write - Error Record 23 write - Error Record 24 write - Error Record 25 write - Error Record 26 write - Error Record 28 write - Error Record 29 write - Error Record 31 write - Error Record 33 write - Error Record 34 write - Error Record 35 write - Error Record 37 write - Error Record 39 write - Error Record 44 write - Error Record 45 write - Error |
