02-18-2014, 11:04 | #3 (permalink) |
No Life Poster Join Date: Jan 2012 Location: YOUR HEART
Member: 1712884 Status: Offline Thanks Meter: 857 | yes: good and easy worck this dongele thanks Code: card found: S/N 8B40:0122 registered to: 8B408586 Connect phone on selected interface... Core : v1.82 , BB5XG FlashEngine : v9.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm618__08.35.mcusw PPM : rm618__08.35.ppm_meac CNT : rm618__08.35.image_meac_0595303 Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 0000000000084D9285C2588CB3386788C121BDED ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0 Processing RAWLOADER... FLIC : 00300020 Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : E9700989029D9E899915F781B1582048E042A738 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 354854042507246 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\354854042507246_CRT.rpl === SW Version Check === - > REFLASHING === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm618__08.35.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm618__08.35.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [ISA+DYNSW] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [UPDAPP] Total writen 511 blocks TIME : Write time : 00:00:05 MCU Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing rm618__08.35.ppm_meac Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm618__08.35.ppm_meac Total writen 100 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing rm618__08.35.image_meac_0595303 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm618__08.35.image_meac_0595303 Total writen 318 blocks TIME : Write time : 00:00:03 CNT Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:00:12 Reboot phone now... - > AfterFlash Failed! :( Reason : Downgrade try or HW Error Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! Elapsed: 00:02:10 Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : Verify Error :( -> Error answer from BootRom Backup Certificates now... Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF EBL Loader : Custom Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL : Custom EBL sent Ok EBL : Quantum_Bootloader_10.56_M1S1 Boot done! Read CRT block... Read EEPROM block... SL3 Simlock found (XGOLD) ... ===== USER CODE ===== Executing Code extraction... - > Phone Lock Code : 12345 ===== USER CODE ===== MMC password not found (not set) NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\353799047813787_XG213.rpl Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Read and Check phone data... ---------------------- RAP_BOOT: 0000000000000000 RAP_PUB: 0000000000000000000000000000000000000000 CMT_ROOT: 00000000000000000000000000000000 RAP_PAPUB: 0000000000000000000000000000000000000000 ---------------------- Live Test Ok! ---------------------- CNT sector : 128 kb ------------------------ CMLA Key status : CMLA key Not exist SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Reading Phone Info.... Connected phone - C1-01 Software ver : V 03.35 02-12-10 RM-607 (c) Nokia IMEI : 353799047813787 XappVer : 0000071C PPM : V 03.35 02-12-10 RM-607 (c) Nokia M_C CNT : Content: m_c_0596380 V 03.35 02-12-10 RM-607 (c) Nokia Product SN : 4DF98CCAI Product code : 0596380 Base Prd.code: 0585582 Module code : 0204427 Long Prod.SN : 0 Hardware info======= HWID : 2000 Batery: 3925 mV CMT BT: 19b5-22012 LCDVer: AUO Lock info =========== IMEI : 353799047813787 IMEI spNet : 3A 35 97 09 74 18 73 08 IMEI svNet : 33 35 97 09 74 18 73 08 F7 Sl Conf : 001-01-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : C16AE7ED6DC8EF8A Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; CRT308 Backup Created CMLA Key status : Not Present SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Reading User code... User Code is: 12345 Done! Phone disconected! Connect phone on selected interface... Core : v1.82 , BB5XG FlashEngine : v9.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm607__06.15.mcusw PPM : rm607__06.15.ppm_m_c CNT : rm607__06.15.image_m_c_0596700 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_2.5_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI : 353799047813787 PCcode : 0596380 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\353799047813787_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm607__06.15.mcusw Image : rm607__06.15.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40040000 , Len : 0x00040000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40080000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40080000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 4/5 Erase , Start : 0x400A0000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x400A0000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 5/5 Erase , Start : 0x40400000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:02:12 Write , Start : 0x40400000 , Len : 0x01780000 Flashing , wait ... Region flash done, time : 00:00:28 CRC check passed , 0x49A2 ===Flashing [PPM]=== File : rm607__06.15.ppm_m_c Image : package_m_c.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41C00000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:17 Write , Start : 0x41C00000 , Len : 0x0031B8B4 Flashing , wait ... Region flash done, time : 00:00:03 CRC check passed , 0x6C3D ===Flashing [CNT]=== File : rm607__06.15.image_m_c_0596700 Image : package_m_c_0596700.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42200000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:05:03 Write , Start : 0x42200000 , Len : 0x00B80000 Flashing , wait ... Region flash done, time : 00:00:20 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:09 No write data, skip CRC check passed , 0x4083 Flashing done! Total flash time : 00:08:45 Reboot phone now... Reading Phone Info.... Connected phone - C1-01 Software Info: V 06.15 25-11-11 RM-607 (c) Nokia IMEI: 353799047813787 PPM version : V 06.15 25-11-11 RM-607 (c) Nokia M_C Product code: 0596380 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 39 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:09:33 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - C1-01 Software ver : V 06.15 25-11-11 RM-607 (c) Nokia IMEI : 353799047813787 XappVer : 0000071C PPM : V 06.15 25-11-11 RM-607 (c) Nokia M_C CNT : Content: m_c_0596700 V 06.15 25-11-11 RM-607 (c) Nokia Product SN : 4DF98CCAI Product code : 0596380 Base Prd.code: 0585582 Module code : 0204427 Long Prod.SN : 0 Hardware info======= HWID : 2000 Batery: 3880 mV CMT BT: 19b5-22012 LCDVer: AUO Lock info =========== IMEI : 353799047813787 IMEI spNet : 3A 35 97 09 74 18 73 08 IMEI svNet : 33 35 97 09 74 18 73 28 F2 Sl Conf : 001-01-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : C16AE7ED6DC8EF8A Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; CRT308 Backup Created CMLA Key status : Not Present SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Reading LifeTimer data... LifeTime is: 1202551 seconds Phone works: 334 Hours; 2 minutes; 31 seconds Last calls : Last call : 00:00:00 Total received calls : 00:00:00 Total sent calls : 00:00:00 Done Reading PM from field 0 to 400 Field [4] 10 Record(s) Record 1: 800 byte(s) readed - Ok Record 3: 10 byte(s) readed - Ok Record 4: 8 byte(s) readed - Ok Record 5: 8 byte(s) readed - Ok Record 6: 8 byte(s) readed - Ok Record 9: 5 byte(s) readed - Ok Record 18: 80 byte(s) readed - Ok Record 19: 4 byte(s) readed - Ok Record 26: 132 byte(s) readed - Ok Record 28: 2 byte(s) readed - Ok Field [8] 10 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 16 byte(s) readed - Ok Record 2: 16 byte(s) readed - Ok Record 3: 128 byte(s) readed - Ok Record 4: 128 byte(s) readed - Ok Record 8: 8 byte(s) readed - Ok Record 9: 8 byte(s) readed - Ok Record 10: 32 byte(s) readed - Ok Record 11: 4 byte(s) readed - Ok Record 12: 4 byte(s) readed - Ok Field [11] 5 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 4 byte(s) readed - Ok Record 2: 4 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 241 byte(s) readed - Ok Field [13] 167 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Record 2: 1 byte(s) readed - Ok Record 3: 2 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 5: 1 byte(s) readed - Ok Record 6: 1 byte(s) readed - Ok Record 7: 1 byte(s) readed - Ok Record 8: 2 byte(s) readed - Ok Record 9: 1 byte(s) readed - Ok Record 10: 1 byte(s) readed - Ok Record 11: 48 byte(s) readed - Ok Record 12: 4 byte(s) readed - Ok Record 13: 1 byte(s) readed - Ok Record 14: 1 byte(s) readed - Ok Record 15: 886 byte(s) readed - Ok Record 16: 2 byte(s) readed - Ok Record 17: 1 byte(s) readed - Ok Record 18: 1 byte(s) readed - Ok Record 19: 8 byte(s) readed - Ok Record 20: 1 byte(s) readed - Ok Record 21: 1 byte(s) readed - Ok Record 22: 1 byte(s) readed - Ok Record 23: 1 byte(s) readed - Ok Record 24: 1 byte(s) readed - Ok Record 25: 2 byte(s) readed - Ok Record 26: 1 byte(s) readed - Ok Record 27: 1 byte(s) readed - Ok Record 28: 1 byte(s) readed - Ok Record 29: 1 byte(s) readed - Ok Record 30: 1 byte(s) readed - Ok Record 31: 1 byte(s) readed - Ok Record 32: 1 byte(s) readed - Ok Record 33: 1 byte(s) readed - Ok Record 34: 1 byte(s) readed - Ok Record 35: 1 byte(s) readed - Ok Record 36: 1 byte(s) readed - Ok Record 37: 4 byte(s) readed - Ok Record 38: 1 byte(s) readed - Ok Record 39: 1 byte(s) readed - Ok Record 40: 1 byte(s) readed - Ok Record 41: 1 byte(s) readed - Ok Record 42: 4 byte(s) readed - Ok Record 43: 4 byte(s) readed - Ok Record 44: 1 byte(s) readed - Ok Record 45: 4 byte(s) readed - Ok Record 46: 4 byte(s) readed - Ok Record 47: 1 byte(s) readed - Ok Record 48: 4 byte(s) readed - Ok Record 49: 1 byte(s) readed - Ok Record 50: 1 byte(s) readed - Ok Record 51: 1 byte(s) readed - Ok Record 52: 2 byte(s) readed - Ok Record 53: 4 byte(s) readed - Ok Record 54: 4 byte(s) readed - Ok Record 55: 1 byte(s) readed - Ok Record 56: 1 byte(s) readed - Ok Record 57: 1 byte(s) readed - Ok Record 58: 2 byte(s) readed - Ok Record 59: 1 byte(s) readed - Ok Record 60: 4 byte(s) readed - Ok Record 61: 4 byte(s) readed - Ok Record 62: 1 byte(s) readed - Ok Record 63: 4 byte(s) readed - Ok Record 64: 4 byte(s) readed - Ok Record 65: 1 byte(s) readed - Ok Record 66: 4 byte(s) readed - Ok Record 67: 4 byte(s) readed - Ok Record 68: 1 byte(s) readed - Ok Record 69: 1 byte(s) readed - Ok Record 70: 1 byte(s) readed - Ok Record 71: 4 byte(s) readed - Ok Record 72: 4 byte(s) readed - Ok Record 73: 1 byte(s) readed - Ok Record 74: 4 byte(s) readed - Ok Record 75: 2 byte(s) readed - Ok Record 76: 2 byte(s) readed - Ok Record 77: 2 byte(s) readed - Ok Record 78: 1 byte(s) readed - Ok Record 79: 1 byte(s) readed - Ok Record 80: 1 byte(s) readed - Ok Record 81: 1 byte(s) readed - Ok Record 82: 1 byte(s) readed - Ok Record 83: 2 byte(s) readed - Ok Record 84: 1 byte(s) readed - Ok Record 85: 4 byte(s) readed - Ok Record 86: 4 byte(s) readed - Ok Record 87: 2 byte(s) readed - Ok Record 88: 1 byte(s) readed - Ok Record 89: 4 byte(s) readed - Ok Record 90: 4 byte(s) readed - Ok Record 91: 2 byte(s) readed - Ok Record 92: 1 byte(s) readed - Ok Record 93: 4 byte(s) readed - Ok Record 94: 4 byte(s) readed - Ok Record 95: 2 byte(s) readed - Ok Record 96: 1 byte(s) readed - Ok Record 97: 4 byte(s) readed - Ok Record 98: 4 byte(s) readed - Ok Record 99: 2 byte(s) readed - Ok Record 100: 4 byte(s) readed - Ok Record 101: 2 byte(s) readed - Ok Record 102: 1 byte(s) readed - Ok Record 103: 4 byte(s) readed - Ok Record 104: 4 byte(s) readed - Ok Record 105: 4 byte(s) readed - Ok Record 106: 4 byte(s) readed - Ok Record 107: 4 byte(s) readed - Ok Record 108: 2 byte(s) readed - Ok Record 109: 4 byte(s) readed - Ok Record 110: 4 byte(s) readed - Ok Record 111: 4 byte(s) readed - Ok Record 112: 2 byte(s) readed - Ok Record 113: 4 byte(s) readed - Ok Record 114: 4 byte(s) readed - Ok Record 115: 1 byte(s) readed - Ok Record 116: 1 byte(s) readed - Ok Record 117: 1 byte(s) readed - Ok Record 118: 4 byte(s) readed - Ok Record 119: 4 byte(s) readed - Ok Record 120: 1 byte(s) readed - Ok Record 121: 1 byte(s) readed - Ok Record 122: 1 byte(s) readed - Ok Record 123: 8 byte(s) readed - Ok Record 124: 1 byte(s) readed - Ok Record 125: 1 byte(s) readed - Ok Record 126: 1 byte(s) readed - Ok Record 127: 1 byte(s) readed - Ok Record 128: 1 byte(s) readed - Ok Record 129: 4 byte(s) readed - Ok Record 130: 4 byte(s) readed - Ok Record 131: 1 byte(s) readed - Ok Record 132: 1 byte(s) readed - Ok Record 133: 2 byte(s) readed - Ok Record 134: 1 byte(s) readed - Ok Record 135: 2 byte(s) readed - Ok Record 136: 1 byte(s) readed - Ok Record 137: 1 byte(s) readed - Ok Record 138: 4 byte(s) readed - Ok Record 139: 4 byte(s) readed - Ok Record 140: 1 byte(s) readed - Ok Record 141: 1 byte(s) readed - Ok Record 142: 1 byte(s) readed - Ok Record 143: 1 byte(s) readed - Ok Record 144: 4 byte(s) readed - Ok Record 145: 8 byte(s) readed - Ok Record 146: 4 byte(s) readed - Ok Record 147: 4 byte(s) readed - Ok Record 148: 1 byte(s) readed - Ok Record 149: 1 byte(s) readed - Ok Record 150: 1 byte(s) readed - Ok Record 151: 1 byte(s) readed - Ok Record 152: 1 byte(s) readed - Ok Record 153: 1 byte(s) readed - Ok Record 154: 1 byte(s) readed - Ok Record 155: 1 byte(s) readed - Ok Record 156: 1 byte(s) readed - Ok Record 157: 1 byte(s) readed - Ok Record 158: 1 byte(s) readed - Ok Record 159: 2 byte(s) readed - Ok Record 160: 2 byte(s) readed - Ok Record 161: 1 byte(s) readed - Ok Record 162: 1 byte(s) readed - Ok Record 163: 1 byte(s) readed - Ok Record 164: 1 byte(s) readed - Ok Record 165: 1 byte(s) readed - Ok Record 166: 1 byte(s) readed - Ok Field [42] 27 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Record 17: 40 byte(s) readed - Ok Record 18: 40 byte(s) readed - Ok Record 19: 40 byte(s) readed - Ok Record 20: 40 byte(s) readed - Ok Record 21: 40 byte(s) readed - Ok Record 22: 40 byte(s) readed - Ok Record 23: 40 byte(s) readed - Ok Record 24: 40 byte(s) readed - Ok Record 25: 40 byte(s) readed - Ok Record 26: 40 byte(s) readed - Ok Field [54] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [96] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 20 byte(s) readed - Ok Field [107] 6 Record(s) Record 0: 21 byte(s) readed - Ok Record 1: 89 byte(s) readed - Ok Record 2: 69 byte(s) readed - Ok Record 3: 70 byte(s) readed - Ok Record 25: 136 byte(s) readed - Ok Record 26: 12 byte(s) readed - Ok Field [116] 17 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [120] 4 Record(s) Record 0: 944 byte(s) readed - Ok Record 1: 160 byte(s) readed - Ok Record 2: 130 byte(s) readed - Ok Record 3: 112 byte(s) readed - Ok Field [193] 4 Record(s) Record 2: 8 byte(s) readed - Ok Record 3: 32 byte(s) readed - Ok Record 4: 32 byte(s) readed - Ok Record 9: 64 byte(s) readed - Ok Field [217] 1 Record(s) Record 0: 32 byte(s) readed - Ok Field [218] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [238] 1 Record(s) Record 1: 1 byte(s) readed - Ok Field [301] 17 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [308] 8 Record(s) Record 0: 1 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 5: 10 byte(s) readed - Ok Record 6: 1 byte(s) readed - Ok Record 7: 1 byte(s) readed - Ok Record 8: 1 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Field [322] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [354] 1 Record(s) Record 0: 15 byte(s) readed - Ok Field [355] 1 Record(s) Record 0: 2886 byte(s) readed - Ok Field [364] 27 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Record 17: 40 byte(s) readed - Ok Record 18: 40 byte(s) readed - Ok Record 19: 40 byte(s) readed - Ok Record 20: 40 byte(s) readed - Ok Record 21: 40 byte(s) readed - Ok Record 22: 40 byte(s) readed - Ok Record 23: 40 byte(s) readed - Ok Record 24: 40 byte(s) readed - Ok Record 25: 40 byte(s) readed - Ok Record 26: 40 byte(s) readed - Ok Field [365] 17 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [373] 1 Record(s) Record 0: 44 byte(s) readed - Ok Field [374] 1 Record(s) Record 0: 4 byte(s) readed - Ok Field [383] 243 Record(s) Record 1: 256 byte(s) readed - Ok Record 3: 256 byte(s) readed - Ok Record 4: 256 byte(s) readed - Ok Record 5: 256 byte(s) readed - Ok Record 6: 256 byte(s) readed - Ok Record 7: 256 byte(s) readed - Ok Record 8: 256 byte(s) readed - Ok Record 9: 256 byte(s) readed - Ok Record 10: 256 byte(s) readed - Ok Record 11: 256 byte(s) readed - Ok Record 12: 256 byte(s) readed - Ok Record 13: 256 byte(s) readed - Ok Record 14: 256 byte(s) readed - Ok Record 15: 256 byte(s) readed - Ok Record 16: 256 byte(s) readed - Ok Record 17: 256 byte(s) readed - Ok Record 18: 256 byte(s) readed - Ok Record 19: 256 byte(s) readed - Ok Record 20: 256 byte(s) readed - Ok Record 21: 256 byte(s) readed - Ok Record 22: 256 byte(s) readed - Ok Record 23: 256 byte(s) readed - Ok Record 24: 256 byte(s) readed - Ok Record 25: 256 byte(s) readed - Ok Record 26: 256 byte(s) readed - Ok Record 27: 256 byte(s) readed - Ok Record 28: 256 byte(s) readed - Ok Record 29: 256 byte(s) readed - Ok Record 30: 256 byte(s) readed - Ok Record 31: 256 byte(s) readed - Ok Record 32: 256 byte(s) readed - Ok Record 33: 256 byte(s) readed - Ok Record 34: 256 byte(s) readed - Ok Record 35: 256 byte(s) readed - Ok Record 36: 256 byte(s) readed - Ok Record 37: 256 byte(s) readed - Ok Record 38: 256 byte(s) readed - Ok Record 39: 256 byte(s) readed - Ok Record 40: 256 byte(s) readed - Ok Record 41: 256 byte(s) readed - Ok Record 42: 256 byte(s) readed - Ok Record 43: 256 byte(s) readed - Ok Record 44: 256 byte(s) readed - Ok Record 45: 256 byte(s) readed - Ok Record 46: 256 byte(s) readed - Ok Record 47: 256 byte(s) readed - Ok Record 48: 256 byte(s) readed - Ok Record 49: 256 byte(s) readed - Ok Record 50: 256 byte(s) readed - Ok Record 51: 256 byte(s) readed - Ok Record 52: 256 byte(s) readed - Ok Record 53: 256 byte(s) readed - Ok Record 54: 256 byte(s) readed - Ok Record 55: 256 byte(s) readed - Ok Record 56: 256 byte(s) readed - Ok Record 57: 256 byte(s) readed - Ok Record 58: 256 byte(s) readed - Ok Record 59: 256 byte(s) readed - Ok Record 60: 256 byte(s) readed - Ok Record 61: 256 byte(s) readed - Ok Record 62: 256 byte(s) readed - Ok Record 63: 256 byte(s) readed - Ok Record 64: 256 byte(s) readed - Ok Record 65: 256 byte(s) readed - Ok Record 66: 256 byte(s) readed - Ok Record 67: 256 byte(s) readed - Ok Record 68: 256 byte(s) readed - Ok Record 69: 256 byte(s) readed - Ok Record 70: 256 byte(s) readed - Ok Record 71: 256 byte(s) readed - Ok Record 72: 256 byte(s) readed - Ok Record 73: 256 byte(s) readed - Ok Record 74: 256 byte(s) readed - Ok Record 75: 256 byte(s) readed - Ok Record 76: 256 byte(s) readed - Ok Record 77: 256 byte(s) readed - Ok Record 78: 256 byte(s) readed - Ok Record 79: 256 byte(s) readed - Ok Record 80: 256 byte(s) readed - Ok Record 81: 256 byte(s) readed - Ok Record 82: 256 byte(s) readed - Ok Record 83: 256 byte(s) readed - Ok Record 84: 256 byte(s) readed - Ok Record 85: 256 byte(s) readed - Ok Record 86: 256 byte(s) readed - Ok Record 87: 256 byte(s) readed - Ok Record 88: 256 byte(s) readed - Ok Record 89: 256 byte(s) readed - Ok Record 90: 256 byte(s) readed - Ok Record 91: 256 byte(s) readed - Ok Record 92: 256 byte(s) readed - Ok Record 93: 256 byte(s) readed - Ok Record 94: 256 byte(s) readed - Ok Record 95: 256 byte(s) readed - Ok Record 96: 256 byte(s) readed - Ok Record 97: 256 byte(s) readed - Ok Record 98: 256 byte(s) readed - Ok Record 99: 256 byte(s) readed - Ok Record 100: 256 byte(s) readed - Ok Record 101: 256 byte(s) readed - Ok Record 102: 256 byte(s) readed - Ok Record 103: 256 byte(s) readed - Ok Record 104: 256 byte(s) readed - Ok Record 105: 256 byte(s) readed - Ok Record 106: 256 byte(s) readed - Ok Record 107: 256 byte(s) readed - Ok Record 108: 256 byte(s) readed - Ok Record 109: 256 byte(s) readed - Ok Record 110: 256 byte(s) readed - Ok Record 111: 256 byte(s) readed - Ok Record 112: 256 byte(s) readed - Ok Record 113: 256 byte(s) readed - Ok Record 114: 256 byte(s) readed - Ok Record 115: 256 byte(s) readed - Ok Record 116: 256 byte(s) readed - Ok Record 117: 256 byte(s) readed - Ok Record 118: 256 byte(s) readed - Ok Record 119: 256 byte(s) readed - Ok Record 120: 256 byte(s) readed - Ok Record 121: 256 byte(s) readed - Ok Record 122: 256 byte(s) readed - Ok Record 123: 256 byte(s) readed - Ok Record 124: 256 byte(s) readed - Ok Record 125: 256 byte(s) readed - Ok Record 126: 256 byte(s) readed - Ok Record 127: 256 byte(s) readed - Ok Record 128: 256 byte(s) readed - Ok Record 129: 256 byte(s) readed - Ok Record 130: 256 byte(s) readed - Ok Record 131: 256 byte(s) readed - Ok Record 132: 256 byte(s) readed - Ok Record 133: 256 byte(s) readed - Ok Record 134: 256 byte(s) readed - Ok Record 135: 256 byte(s) readed - Ok Record 136: 256 byte(s) readed - Ok Record 137: 256 byte(s) readed - Ok Record 138: 256 byte(s) readed - Ok Record 139: 256 byte(s) readed - Ok Record 140: 256 byte(s) readed - Ok Record 141: 256 byte(s) readed - Ok Record 142: 256 byte(s) readed - Ok Record 143: 256 byte(s) readed - Ok Record 144: 256 byte(s) readed - Ok Record 145: 256 byte(s) readed - Ok Record 146: 256 byte(s) readed - Ok Record 147: 256 byte(s) readed - Ok Record 148: 256 byte(s) readed - Ok Record 149: 256 byte(s) readed - Ok Record 150: 256 byte(s) readed - Ok Record 151: 256 byte(s) readed - Ok Record 152: 256 byte(s) readed - Ok Record 153: 256 byte(s) readed - Ok Record 154: 256 byte(s) readed - Ok Record 155: 256 byte(s) readed - Ok Record 156: 256 byte(s) readed - Ok Record 157: 256 byte(s) readed - Ok Record 158: 256 byte(s) readed - Ok Record 159: 256 byte(s) readed - Ok Record 160: 256 byte(s) readed - Ok Record 161: 256 byte(s) readed - Ok Record 162: 256 byte(s) readed - Ok Record 163: 256 byte(s) readed - Ok Record 164: 256 byte(s) readed - Ok Record 165: 256 byte(s) readed - Ok Record 166: 256 byte(s) readed - Ok Record 167: 256 byte(s) readed - Ok Record 168: 256 byte(s) readed - Ok Record 169: 256 byte(s) readed - Ok Record 170: 256 byte(s) readed - Ok Record 171: 256 byte(s) readed - Ok Record 172: 256 byte(s) readed - Ok Record 173: 256 byte(s) readed - Ok Record 174: 256 byte(s) readed - Ok Record 175: 256 byte(s) readed - Ok Record 176: 256 byte(s) readed - Ok Record 177: 256 byte(s) readed - Ok Record 178: 256 byte(s) readed - Ok Record 179: 256 byte(s) readed - Ok Record 180: 256 byte(s) readed - Ok Record 181: 256 byte(s) readed - Ok Record 182: 256 byte(s) readed - Ok Record 183: 256 byte(s) readed - Ok Record 184: 256 byte(s) readed - Ok Record 185: 256 byte(s) readed - Ok Record 186: 256 byte(s) readed - Ok Record 187: 256 byte(s) readed - Ok Record 188: 256 byte(s) readed - Ok Record 189: 256 byte(s) readed - Ok Record 190: 256 byte(s) readed - Ok Record 191: 256 byte(s) readed - Ok Record 192: 256 byte(s) readed - Ok Record 193: 256 byte(s) readed - Ok Record 194: 256 byte(s) readed - Ok Record 195: 256 byte(s) readed - Ok Record 196: 256 byte(s) readed - Ok Record 197: 256 byte(s) readed - Ok Record 198: 256 byte(s) readed - Ok Record 199: 256 byte(s) readed - Ok Record 200: 256 byte(s) readed - Ok Record 201: 256 byte(s) readed - Ok Record 202: 256 byte(s) readed - Ok Record 203: 256 byte(s) readed - Ok Record 204: 256 byte(s) readed - Ok Record 205: 256 byte(s) readed - Ok Record 206: 256 byte(s) readed - Ok Record 207: 256 byte(s) readed - Ok Record 208: 256 byte(s) readed - Ok Record 209: 256 byte(s) readed - Ok Record 210: 256 byte(s) readed - Ok Record 211: 256 byte(s) readed - Ok Record 212: 256 byte(s) readed - Ok Record 213: 256 byte(s) readed - Ok Record 214: 256 byte(s) readed - Ok Record 215: 256 byte(s) readed - Ok Record 216: 256 byte(s) readed - Ok Record 217: 256 byte(s) readed - Ok Record 218: 256 byte(s) readed - Ok Record 219: 256 byte(s) readed - Ok Record 220: 256 byte(s) readed - Ok Record 221: 256 byte(s) readed - Ok Record 222: 256 byte(s) readed - Ok Record 223: 256 byte(s) readed - Ok Record 224: 256 byte(s) readed - Ok Record 225: 256 byte(s) readed - Ok Record 226: 256 byte(s) readed - Ok Record 227: 256 byte(s) readed - Ok Record 228: 256 byte(s) readed - Ok Record 229: 256 byte(s) readed - Ok Record 230: 256 byte(s) readed - Ok Record 231: 256 byte(s) readed - Ok Record 232: 256 byte(s) readed - Ok Record 233: 256 byte(s) readed - Ok Record 234: 256 byte(s) readed - Ok Record 235: 256 byte(s) readed - Ok Record 236: 256 byte(s) readed - Ok Record 237: 256 byte(s) readed - Ok Record 238: 256 byte(s) readed - Ok Record 239: 256 byte(s) readed - Ok Record 240: 256 byte(s) readed - Ok Record 241: 256 byte(s) readed - Ok Record 242: 256 byte(s) readed - Ok Record 243: 256 byte(s) readed - Ok Record 244: 256 byte(s) readed - Ok Field [390] 180 Record(s) Record 0: 256 byte(s) readed - Ok Record 2: 256 byte(s) readed - Ok Record 3: 256 byte(s) readed - Ok Record 4: 256 byte(s) readed - Ok Record 5: 256 byte(s) readed - Ok Record 6: 256 byte(s) readed - Ok Record 7: 256 byte(s) readed - Ok Record 8: 256 byte(s) readed - Ok Record 9: 256 byte(s) readed - Ok Record 10: 256 byte(s) readed - Ok Record 11: 256 byte(s) readed - Ok Record 12: 256 byte(s) readed - Ok Record 13: 256 byte(s) readed - Ok Record 14: 256 byte(s) readed - Ok Record 15: 256 byte(s) readed - Ok Record 16: 256 byte(s) readed - Ok Record 17: 256 byte(s) readed - Ok Record 18: 256 byte(s) readed - Ok Record 19: 256 byte(s) readed - Ok Record 20: 256 byte(s) readed - Ok Record 21: 256 byte(s) readed - Ok Record 22: 256 byte(s) readed - Ok Record 23: 256 byte(s) readed - Ok Record 24: 256 byte(s) readed - Ok Record 25: 256 byte(s) readed - Ok Record 26: 256 byte(s) readed - Ok Record 27: 256 byte(s) readed - Ok Record 28: 256 byte(s) readed - Ok Record 29: 256 byte(s) readed - Ok Record 30: 256 byte(s) readed - Ok Record 31: 256 byte(s) readed - Ok Record 32: 256 byte(s) readed - Ok Record 33: 256 byte(s) readed - Ok Record 34: 256 byte(s) readed - Ok Record 35: 256 byte(s) readed - Ok Record 36: 256 byte(s) readed - Ok Record 37: 256 byte(s) readed - Ok Record 38: 256 byte(s) readed - Ok Record 39: 256 byte(s) readed - Ok Record 40: 256 byte(s) readed - Ok Record 41: 256 byte(s) readed - Ok Record 42: 256 byte(s) readed - Ok Record 43: 256 byte(s) readed - Ok Record 44: 256 byte(s) readed - Ok Record 45: 256 byte(s) readed - Ok Record 46: 256 byte(s) readed - Ok Record 47: 256 byte(s) readed - Ok Record 48: 256 byte(s) readed - Ok Record 49: 256 byte(s) readed - Ok Record 50: 256 byte(s) readed - Ok Record 51: 256 byte(s) readed - Ok Record 52: 256 byte(s) readed - Ok Record 53: 256 byte(s) readed - Ok Record 54: 256 byte(s) readed - Ok Record 55: 256 byte(s) readed - Ok Record 56: 256 byte(s) readed - Ok Record 57: 256 byte(s) readed - Ok Record 58: 256 byte(s) readed - Ok Record 59: 256 byte(s) readed - Ok Record 60: 256 byte(s) readed - Ok Record 61: 256 byte(s) readed - Ok Record 62: 256 byte(s) readed - Ok Record 63: 256 byte(s) readed - Ok Record 64: 256 byte(s) readed - Ok Record 65: 256 byte(s) readed - Ok Record 66: 256 byte(s) readed - Ok Record 67: 256 byte(s) readed - Ok Record 68: 256 byte(s) readed - Ok Record 69: 256 byte(s) readed - Ok Record 70: 256 byte(s) readed - Ok Record 71: 256 byte(s) readed - Ok Record 72: 256 byte(s) readed - Ok Record 73: 256 byte(s) readed - Ok Record 74: 256 byte(s) readed - Ok Record 75: 256 byte(s) readed - Ok Record 76: 256 byte(s) readed - Ok Record 77: 256 byte(s) readed - Ok Record 78: 256 byte(s) readed - Ok Record 79: 256 byte(s) readed - Ok Record 80: 256 byte(s) readed - Ok Record 81: 256 byte(s) readed - Ok Record 82: 256 byte(s) readed - Ok Record 83: 256 byte(s) readed - Ok Record 84: 256 byte(s) readed - Ok Record 85: 256 byte(s) readed - Ok Record 86: 256 byte(s) readed - Ok Record 87: 256 byte(s) readed - Ok Record 88: 256 byte(s) readed - Ok Record 89: 256 byte(s) readed - Ok Record 90: 256 byte(s) readed - Ok Record 91: 256 byte(s) readed - Ok Record 92: 256 byte(s) readed - Ok Record 93: 256 byte(s) readed - Ok Record 94: 256 byte(s) readed - Ok Record 95: 256 byte(s) readed - Ok Record 96: 256 byte(s) readed - Ok Record 97: 256 byte(s) readed - Ok Record 98: 256 byte(s) readed - Ok Record 99: 256 byte(s) readed - Ok Record 100: 256 byte(s) readed - Ok Record 101: 256 byte(s) readed - Ok Record 102: 256 byte(s) readed - Ok Record 103: 256 byte(s) readed - Ok Record 104: 256 byte(s) readed - Ok Record 105: 256 byte(s) readed - Ok Record 106: 256 byte(s) readed - Ok Record 107: 256 byte(s) readed - Ok Record 108: 256 byte(s) readed - Ok Record 109: 256 byte(s) readed - Ok Record 110: 256 byte(s) readed - Ok Record 111: 256 byte(s) readed - Ok Record 112: 256 byte(s) readed - Ok Record 113: 256 byte(s) readed - Ok Record 114: 256 byte(s) readed - Ok Record 115: 256 byte(s) readed - Ok Record 116: 256 byte(s) readed - Ok Record 117: 256 byte(s) readed - Ok Record 118: 256 byte(s) readed - Ok Record 119: 256 byte(s) readed - Ok Record 120: 256 byte(s) readed - Ok Record 121: 256 byte(s) readed - Ok Record 122: 256 byte(s) readed - Ok Record 123: 256 byte(s) readed - Ok Record 124: 256 byte(s) readed - Ok Record 125: 256 byte(s) readed - Ok Record 126: 256 byte(s) readed - Ok Record 127: 256 byte(s) readed - Ok Record 128: 256 byte(s) readed - Ok Record 129: 256 byte(s) readed - Ok Record 130: 256 byte(s) readed - Ok Record 131: 256 byte(s) readed - Ok Record 132: 256 byte(s) readed - Ok Record 133: 256 byte(s) readed - Ok Record 134: 256 byte(s) readed - Ok Record 135: 256 byte(s) readed - Ok Record 136: 256 byte(s) readed - Ok Record 137: 256 byte(s) readed - Ok Record 138: 256 byte(s) readed - Ok Record 139: 256 byte(s) readed - Ok Record 140: 256 byte(s) readed - Ok Record 141: 256 byte(s) readed - Ok Record 142: 256 byte(s) readed - Ok Record 143: 256 byte(s) readed - Ok Record 144: 256 byte(s) readed - Ok Record 145: 256 byte(s) readed - Ok Record 146: 256 byte(s) readed - Ok Record 147: 256 byte(s) readed - Ok Record 148: 256 byte(s) readed - Ok Record 149: 256 byte(s) readed - Ok Record 150: 256 byte(s) readed - Ok Record 151: 256 byte(s) readed - Ok Record 152: 256 byte(s) readed - Ok Record 153: 256 byte(s) readed - Ok Record 154: 256 byte(s) readed - Ok Record 155: 256 byte(s) readed - Ok Record 156: 256 byte(s) readed - Ok Record 157: 256 byte(s) readed - Ok Record 158: 256 byte(s) readed - Ok Record 159: 256 byte(s) readed - Ok Record 160: 256 byte(s) readed - Ok Record 161: 256 byte(s) readed - Ok Record 162: 256 byte(s) readed - Ok Record 163: 256 byte(s) readed - Ok Record 164: 256 byte(s) readed - Ok Record 165: 256 byte(s) readed - Ok Record 166: 256 byte(s) readed - Ok Record 167: 256 byte(s) readed - Ok Record 168: 256 byte(s) readed - Ok Record 169: 256 byte(s) readed - Ok Record 170: 256 byte(s) readed - Ok Record 171: 256 byte(s) readed - Ok Record 172: 256 byte(s) readed - Ok Record 173: 256 byte(s) readed - Ok Record 174: 256 byte(s) readed - Ok Record 175: 256 byte(s) readed - Ok Record 176: 256 byte(s) readed - Ok Record 177: 256 byte(s) readed - Ok Record 178: 256 byte(s) readed - Ok Record 179: 256 byte(s) readed - Ok Record 180: 256 byte(s) readed - Ok Field [391] 141 Record(s) Record 0: 256 byte(s) readed - Ok Record 2: 256 byte(s) readed - Ok Record 3: 256 byte(s) readed - Ok Record 4: 256 byte(s) readed - Ok Record 5: 256 byte(s) readed - Ok Record 6: 256 byte(s) readed - Ok Record 7: 256 byte(s) readed - Ok Record 8: 256 byte(s) readed - Ok Record 9: 256 byte(s) readed - Ok Record 10: 256 byte(s) readed - Ok Record 11: 256 byte(s) readed - Ok Record 12: 256 byte(s) readed - Ok Record 13: 256 byte(s) readed - Ok Record 14: 256 byte(s) readed - Ok Record 15: 256 byte(s) readed - Ok Record 16: 256 byte(s) readed - Ok Record 17: 256 byte(s) readed - Ok Record 18: 256 byte(s) readed - Ok Record 19: 256 byte(s) readed - Ok Record 20: 256 byte(s) readed - Ok Record 21: 256 byte(s) readed - Ok Record 22: 256 byte(s) readed - Ok Record 23: 256 byte(s) readed - Ok Record 24: 256 byte(s) readed - Ok Record 25: 256 byte(s) readed - Ok Record 26: 256 byte(s) readed - Ok Record 27: 256 byte(s) readed - Ok Record 28: 256 byte(s) readed - Ok Record 29: 256 byte(s) readed - Ok Record 30: 256 byte(s) readed - Ok Record 31: 256 byte(s) readed - Ok Record 32: 256 byte(s) readed - Ok Record 33: 256 byte(s) readed - Ok Record 34: 256 byte(s) readed - Ok Record 35: 256 byte(s) readed - Ok Record 36: 256 byte(s) readed - Ok Record 37: 256 byte(s) readed - Ok Record 38: 256 byte(s) readed - Ok Record 39: 256 byte(s) readed - Ok Record 40: 256 byte(s) readed - Ok Record 41: 256 byte(s) readed - Ok Record 42: 256 byte(s) readed - Ok Record 43: 256 byte(s) readed - Ok Record 44: 256 byte(s) readed - Ok Record 45: 256 byte(s) readed - Ok Record 46: 256 byte(s) readed - Ok Record 47: 256 byte(s) readed - Ok Record 48: 256 byte(s) readed - Ok Record 49: 256 byte(s) readed - Ok Record 50: 256 byte(s) readed - Ok Record 51: 256 byte(s) readed - Ok Record 52: 256 byte(s) readed - Ok Record 53: 256 byte(s) readed - Ok Record 54: 256 byte(s) readed - Ok Record 55: 256 byte(s) readed - Ok Record 56: 256 byte(s) readed - Ok Record 57: 256 byte(s) readed - Ok Record 58: 256 byte(s) readed - Ok Record 59: 256 byte(s) readed - Ok Record 60: 256 byte(s) readed - Ok Record 61: 256 byte(s) readed - Ok Record 62: 256 byte(s) readed - Ok Record 63: 256 byte(s) readed - Ok Record 64: 256 byte(s) readed - Ok Record 65: 256 byte(s) readed - Ok Record 66: 256 byte(s) readed - Ok Record 67: 256 byte(s) readed - Ok Record 68: 256 byte(s) readed - Ok Record 69: 256 byte(s) readed - Ok Record 70: 256 byte(s) readed - Ok Record 71: 256 byte(s) readed - Ok Record 72: 256 byte(s) readed - Ok Record 73: 256 byte(s) readed - Ok Record 74: 256 byte(s) readed - Ok Record 75: 256 byte(s) readed - Ok Record 76: 256 byte(s) readed - Ok Record 77: 256 byte(s) readed - Ok Record 78: 256 byte(s) readed - Ok Record 79: 256 byte(s) readed - Ok Record 80: 256 byte(s) readed - Ok Record 81: 256 byte(s) readed - Ok Record 82: 256 byte(s) readed - Ok Record 83: 256 byte(s) readed - Ok Record 84: 256 byte(s) readed - Ok Record 85: 256 byte(s) readed - Ok Record 86: 256 byte(s) readed - Ok Record 87: 256 byte(s) readed - Ok Record 88: 256 byte(s) readed - Ok Record 89: 256 byte(s) readed - Ok Record 90: 256 byte(s) readed - Ok Record 91: 256 byte(s) readed - Ok Record 92: 256 byte(s) readed - Ok Record 93: 256 byte(s) readed - Ok Record 94: 256 byte(s) readed - Ok Record 95: 256 byte(s) readed - Ok Record 96: 256 byte(s) readed - Ok Record 97: 256 byte(s) readed - Ok Record 98: 256 byte(s) readed - Ok Record 99: 256 byte(s) readed - Ok Record 100: 256 byte(s) readed - Ok Record 101: 256 byte(s) readed - Ok Record 102: 256 byte(s) readed - Ok Record 103: 256 byte(s) readed - Ok Record 104: 256 byte(s) readed - Ok Record 105: 256 byte(s) readed - Ok Record 106: 256 byte(s) readed - Ok Record 107: 256 byte(s) readed - Ok Record 108: 256 byte(s) readed - Ok Record 109: 256 byte(s) readed - Ok Record 110: 256 byte(s) readed - Ok Record 111: 256 byte(s) readed - Ok Record 112: 256 byte(s) readed - Ok Record 113: 256 byte(s) readed - Ok Record 114: 256 byte(s) readed - Ok Record 115: 256 byte(s) readed - Ok Record 116: 256 byte(s) readed - Ok Record 117: 256 byte(s) readed - Ok Record 118: 256 byte(s) readed - Ok Record 119: 256 byte(s) readed - Ok Record 120: 256 byte(s) readed - Ok Record 121: 256 byte(s) readed - Ok Record 122: 256 byte(s) readed - Ok Record 123: 256 byte(s) readed - Ok Record 124: 256 byte(s) readed - Ok Record 125: 256 byte(s) readed - Ok Record 126: 256 byte(s) readed - Ok Record 127: 256 byte(s) readed - Ok Record 128: 256 byte(s) readed - Ok Record 129: 256 byte(s) readed - Ok Record 130: 256 byte(s) readed - Ok Record 131: 256 byte(s) readed - Ok Record 132: 256 byte(s) readed - Ok Record 133: 256 byte(s) readed - Ok Record 134: 256 byte(s) readed - Ok Record 135: 256 byte(s) readed - Ok Record 136: 256 byte(s) readed - Ok Record 137: 256 byte(s) readed - Ok Record 138: 256 byte(s) readed - Ok Record 139: 256 byte(s) readed - Ok Record 140: 256 byte(s) readed - Ok Record 141: 256 byte(s) readed - Ok Saved as C:\InfinityBox\BEST\Backup\RM-607 C1-01_353799047813787_0_400.pm Done! Elapsed: 00:00:05 Backup Certificates now... Backup CRT308 data... CRT308 Backup Created Check communication with phone.... Communication verify done... Preparing... SL3 Simlock read (XGOLD) ... Ok Reboot.... Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF EBL Loader : Custom Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL : Custom EBL sent Ok EBL : Quantum_Bootloader_10.56_M1S1 Boot done! Read CRT block... Read EEPROM block... SL3 Simlock found (XGOLD) ... ===== USER CODE ===== Executing Code extraction... - > Phone Lock Code : 12345 ===== USER CODE ===== MMC password not found (not set) NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\353799047813787_2nd_XG213.rpl Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Resetting life Timer... Reset Done! Done Reading LifeTimer data... Looks like LifeTimer already reset... Last calls : Last call : 00:00:00 Total received calls : 00:00:00 Total sent calls : 00:00:00 Done Set phone in Normal mode... Restarting... Done! Connect phone on selected interface... |
