09-18-2012, 15:46 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: P A K I S T A N
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | need help 3110 contact service SX4 SERVER OFFLINE ALWAYS here is bus check log Read and Check phone data... SDD Key status : SDData is Ok CMLA Key status : CMLA key is Ok SimLock status : SimLock is Ok Security status : Security Damaged!!!!! - > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual ) ----------------------- PA_SimLock Version : PA_SL phone detected Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 22400119EAA87C568CF96405E6AB5C485B716FDC CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89810089 , CMT , NOR CMT Flash ID : 89810089 < INTEL => NU48F256 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : C0E691EA16A7593A9BB28832D7312A39F7ED668D05 Transmission mode : Dual (Ddr, TX2) Boot Done! PrReq : NOR , 00 Init Service mode... Wait... Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok and i pres server SX4 many hour ago this prblem show Processing Server SX4 Auth Checking SDD key... Check SD : Key is Ok Operating mode is OK, no need change... Connecting to server... Connection error #1 Server not found... SX4 Auth error pliz best team fix this problem as soon as |
09-19-2012, 05:19 | #3 (permalink) |
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | her is log local sx4 see Phone found! Series 40 Device detected! read info... - Ok Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 356852025304662 Key file exists, no need to read... Step 1... Step 2... Step 3... SX4 Auth - Ok Upload PM checked Uploading RF/Battery tune to phone... Using : RM-237.pm Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED - > Try "Restore CCC/HWC" option, after SX4 again Done! Elapsed: 00:00:06 Upload done and upload tune log see Uploading RF/Battery tune to phone... Using : RM-237.pm Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED - > Try "Restore CCC/HWC" option, after SX4 again Done! Elapsed: 00:00:06 and then i try restore ccc/hwc see log Will Write CCC/HWC keys now... Using : RM-237.rpl CCC Data found! HWC Data found! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 22400119EAA87C568CF96405E6AB5C485B716FDC CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89810089 , CMT , NOR CMT Flash ID : 89810089 < INTEL => NU48F256 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : C0E691EA16A7593A9BB28832D7312A39F7ED668D05 Transmission mode : Dual (Ddr, TX2) Boot Done! Preparing for write certificates... CMT : CCC erase Ok Writing CCC... Ok CMT : HWC erase Ok Writing HWC... Ok Done! Elapsed: 00:00:16 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok then again bus check Will Write CCC/HWC keys now... Using : RM-237.rpl CCC Data found! HWC Data found! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 22400119EAA87C568CF96405E6AB5C485B716FDC CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 89810089 , CMT , NOR CMT Flash ID : 89810089 < INTEL => NU48F256 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : C0E691EA16A7593A9BB28832D7312A39F7ED668D05 Transmission mode : Dual (Ddr, TX2) Boot Done! Preparing for write certificates... CMT : CCC erase Ok Writing CCC... Ok CMT : HWC erase Ok Writing HWC... Ok Done! Elapsed: 00:00:16 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok My Problem not solved ??? |
