04-07-2015, 07:38 | #1 (permalink) |
Freak Poster Join Date: Dec 2008 Location: lahore
Member: 923792 Status: Offline Thanks Meter: 20 | need help nokia 225 contact service problem Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 14 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 6FCCC71B14B655C8D10403AC87208179 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.20.10.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive Mobile Info : IMEI : 356467067960725 BBUID : 6FCCC71B14B655C8D10403AC87208179 SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 356467067960725_MTK_2nd.mtsec Read Done! Connect phone on selected interface... sir any soluation please help me.thanks |
04-07-2015, 07:48 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. Connect powered on phone and make "SelfTest". Check results after. Flash latest FW , make Format FS. If still problems - that mean something wrong with HW. |
04-07-2015, 08:33 | #3 (permalink) |
Member: 923792 Status: Offline Thanks Meter: 20 | Reading Phone Info.... Software ver : 20.10.11 00-00-00 RM-1011 IMEI 1 : 123456789012345 IMEI 2 : 123456789012345 XappVer : 00000802 Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : IJ CNT : PEARL.20.10.11.p1 Product SN : 3D1C50CAU Product code : 059V6J3 Base Prd.code: 059W429 Module code : 0206308 Hardware info======= HWID : 3001 LCDVer: TPO Lock info =========== IMEI : 123456789012345 IMEI spNet : 0A 00 00 00 00 00 00 00 Lock info: SimLock status : Ok Security status : Damaged!!!!! Done! |
05-21-2016, 05:21 | #10 (permalink) |
Major Poster Join Date: Dec 2015 Location: India
Member: 2503159 Status: Offline Thanks Meter: 14 | flash with infinity best with correct rom, now contact service. nokia 225 rm 1011. before flashing phn was alive, only pre intalled browser was corrupted. any solution plz? |
