07-27-2014, 08:11 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | All explained : Check your PC - if it REV1 ( no REV2 in PC name ) - you can flash ANY REV1. If it PC have REV2 - you can flash only REV2. By the way I sure it have rev1. |
07-27-2014, 08:42 | #3 (permalink) |
No Life Poster Join Date: Jan 2012 Location: YOUR HEART
Member: 1712884 Status: Offline Thanks Meter: 857 | thanks my phone good flashing and chenge language Code: Core : v1.92 , NXP FlashEngine : v1.5 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM980_1.1.2.2_059T9G0_IMEA_AE_variant.img Ok, Set : RM980_1.1.2.2_boot.img Ok, Set : RM980_1.1.2.2_cache.img Ok, Set : RM980_1.1.2.2_emmc_appsboot.mbn Ok, Set : RM980_1.1.2.2_emmc_appsboothd.mbn Ok, Set : RM980_1.1.2.2_fat.bin Ok, Set : RM980_1.1.2.2_oemsbl.mbn Ok, Set : RM980_1.1.2.2_oemsblhd.mbn Ok, Set : RM980_1.1.2.2_persist.img Ok, Set : RM980_1.1.2.2_preload.img Ok, Set : RM980_1.1.2.2_qcsbl.mbn Ok, Set : RM980_1.1.2.2_qcsblhd_cfgdata.mbn Ok, Set : RM980_1.1.2.2_recovery.img Ok, Set : RM980_1.1.2.2_system.img Ok, Set : RM980_1.1.2.2_udisk.bin Ok, Set : RM980_1.1.2.2_userdata.img File HW revision is : HW Revision V1 Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Press and hold 'Volume Down' and 'Power' buttons 3. When feel short vibra - release 'Power' button, but keep hold 'Volume Down' button 4. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : 5DEDC0ED Processing : RM980_1.1.2.2_qcsblhd_cfgdata.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_qcsbl.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_oemsblhd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_oemsbl.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM980_1.1.2.2_emmc_appsboothd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_emmc_appsboot.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM980_1.1.2.2_boot.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_recovery.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_persist.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_fat.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_system.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_cache.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_userdata.img Erase Partition : USERDATA Partition Erase Done Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_udisk.bin Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM980_1.1.2.2_preload.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_059T9G0_IMEA_AE_variant.img Init Ok, send data ... Data sent, start flashing Region Flash Done Rebooting phone now Flashing done! Total flash time : 00:04:57 Reboot phone Ok Connect phone on selected interface... dzirt please add my sonork id. |
