10-31-2018, 06:44 | #1 (permalink) |
No Life Poster Join Date: Jul 2013 Location: Kamber, Sindh, Pakistan Age: 36
Member: 1983780 Status: Offline Thanks Meter: 353 | Need Help Ta-1034 Dead After Flash... Operation : Write FirmWare [ v1.08 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM10) MODE : NOKIA USB SERIAL PORT : 10 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : ABD46AD6D720B4D10E5CA69FFD4C6517 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : NONE [ROM ERASED] AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! Load FlashSet : MROM : TA-1034_ROM_eMP_10.02.11 LANG : TA-1034_LANG_PACK_ROM_IJ_eMP_10.02.11_001 CUST : TA-1034_CUSTPACK_ROM_IJ_eMP_10.02.11_001 JUMP : TA-1034_JUMP_TABLE_IJ_eMP_10.02.11_001 VIVA : TA-1034_VIVA_eMP_10.02.11 Prepare FlashSet : DCR : TA-1034_ROM_eMP_10.02.11 DCR : TA-1034_LANG_PACK_ROM_IJ_eMP_10.02.11_001 DCR : TA-1034_CUSTPACK_ROM_IJ_eMP_10.02.11_001 DCR : TA-1034_JUMP_TABLE_IJ_eMP_10.02.11_001 DCR : TA-1034_VIVA_eMP_10.02.11 Prepare Target SDS : FT_FILE_NOT_EXIST : 0x00000000 : 0x00000000 CBR : 0x00000004:0x00000001:0x00000000:0x00000000:0x0000 0010:0x00000002:0x00000000 Erase Target Flash Flash_PreErase ERROR : SECURITY_SF_RESTRICTED_AREA_ACCESS_FORBIDDEN Unknow Error! Make sure device HW is in normal condition, check battery and cable! Reconnect Power/Cable! plz share good solution how to solve it again.. |
10-31-2018, 08:39 | #3 (permalink) |
Member: 1983780 Status: Offline Thanks Meter: 353 | here is log before dead phone plz help ehy phone goas dead? also flash successful see the log ... Open VPLfile : TA-1034_059Z103_11.00.11.vpl Description : TA-1034 IC DeviceType : TA-1034 ProductCode : 059Z103 SoftwareVer : 11.00.11 Load Ok! Operation : Write FirmWare [ v1.08 ] Setting : UserData erase : False Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM10) MODE : NOKIA USB SERIAL PORT : 10 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : ABD46AD6D720B4D10E5CA69FFD4C6517 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.30.04.11.p1 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.30.04.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! Load FlashSet : MROM : TA-1034_ROM_eMP_11.00.11 LANG : TA-1034_LANG_PACK_ROM_IC_eMP_11.00.11_001 CUST : TA-1034_CUSTPACK_ROM_IC_eMP_11.00.11_001 JUMP : TA-1034_JUMP_TABLE_IC_eMP_11.00.11_001 VIVA : TA-1034_VIVA_eMP_11.00.11 Prepare FlashSet : DCR : TA-1034_ROM_eMP_11.00.11 DCR : TA-1034_LANG_PACK_ROM_IC_eMP_11.00.11_001 DCR : TA-1034_CUSTPACK_ROM_IC_eMP_11.00.11_001 DCR : TA-1034_JUMP_TABLE_IC_eMP_11.00.11_001 DCR : TA-1034_VIVA_eMP_11.00.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 Erase Target Flash Erase done! Write Target Flash Write : TA-1034_ROM_eMP_11.00.11 Write : TA-1034_LANG_PACK_ROM_IC_eMP_11.00.11_001 Write : TA-1034_CUSTPACK_ROM_IC_eMP_11.00.11_001 Write : TA-1034_JUMP_TABLE_IC_eMP_11.00.11_001 Write : TA-1034_VIVA_eMP_11.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1034_ROM_eMP_11.00.11 Verify : TA-1034_LANG_PACK_ROM_IC_eMP_11.00.11_001 Verify : TA-1034_CUSTPACK_ROM_IC_eMP_11.00.11_001 Verify : TA-1034_JUMP_TABLE_IC_eMP_11.00.11_001 Verify : TA-1034_VIVA_eMP_11.00.11 Done! Elapsed: 00:01:00 |
10-31-2018, 10:10 | #4 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Somewhere
Member: 22466 Status: Offline Thanks Meter: 282 | according to log the device had 30.04.11 "BOOT : PRJ : N103.30.04.11.p1" Simple just flash back 30.04.11 Nokia 105 (TA-1034, TA-1010) Compatibility: 30.04.11 <=> 30.04.11 Only 10.02.11 <=> 11.00.11 <=> 12.00.11 u can flash between |
The Following 3 Users Say Thank You to aleksa55 For This Useful Post: |
10-31-2018, 11:12 | #5 (permalink) |
Member: 1983780 Status: Offline Thanks Meter: 353 | thanx for reply bro, 10.02.11 ver firmware i have but failed to write and other ver i dont have.... still searching in google .... |
10-31-2018, 11:33 | #6 (permalink) | |
No Life Poster Join Date: Apr 2015 Location: LOOLCANO Taba Day.
Member: 2385819 Status: Offline Sonork: No More Used Thanks Meter: 827 | Quote:
https://mega.nz/#!YtBl2a4I!LFbT_cSat...-703jm3fCSR_A4 | |
The Following 3 Users Say Thank You to ahmer5050 For This Useful Post: |
10-31-2018, 11:46 | #7 (permalink) | |
Member: 1983780 Status: Offline Thanks Meter: 353 | Quote:
PTFN : Nokia USB Serial Port (COM10) MODE : NOKIA USB SERIAL PORT : 10 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : ABD46AD6D720B4D10E5CA69FFD4C6517 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.30.04.11.p1 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : N103.11.00.11.p1 FLASH : 00C2 : 0025 : 0036 : 0000 BBSN : ABD46AD6D720B4D10E5CA69FFD4C6517 PRDC : 059Z0S0 IMEI[1] : 3590140944xxxxx IMEI[2] : 3590140954xxxxx now what should i do bro..... still i want help | |
10-31-2018, 12:12 | #8 (permalink) | |
10-31-2018, 12:38 | #10 (permalink) |
Member: 2385819 Status: Offline Sonork: No More Used Thanks Meter: 827 | Try This one Sir. https://mega.nz/#!8sAWgSyR!uLGB1nU7t...xT3A33g-7aDXRE |
The Following 12 Users Say Thank You to ahmer5050 For This Useful Post: |
10-31-2018, 12:46 | #11 (permalink) | |
The Following 5 Users Say Thank You to Ayaz Hussain For This Useful Post: |
11-01-2018, 05:59 | #12 (permalink) | |
Junior Member Join Date: Dec 2016 Location: swat,pakistan Age: 31
Member: 2662044 Status: Offline Thanks Meter: 10 | ta-1034 dead after flash Quote:
Thank you sir......its working and good file .. | |
01-17-2019, 10:30 | #14 (permalink) |
Junior Member Join Date: Jun 2016 Location: Chichawatni,Pakistan
Member: 2582282 Status: Offline Sonork: 100.1673899 Thanks Meter: 1 | ta 1034 dead after flash soloution 100% ok i flashed ta 1034 urdu file phone gone dead i find another phone and make backup and write backup mob gone done i can't share link because i haven't 10 posts i shared my video on youtube and file link in description you can check video by searching "ta 1034 dead after flash soloution 100% tested/ta 1034 tested flash file" |
