07-21-2014, 10:54 | #1 (permalink) |
No Life Poster Join Date: Jan 2011 Location: in your Heart
Member: 1484062 Status: Offline Sonork: 1610135 Thanks Meter: 218 | Noia 220 Hang on Nokia How to Recover it its Rm-969? Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 264 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : F5918829CE57FA3DAE81270683C44589 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL failed! (CMD not accepted, 0xAA) Check Power / Cable! BootLoader Init Failed (HW/Connection Error) Connect phone on selected interface... Boot Error Flashing failed! Connect phone on selected interface... |
07-21-2014, 11:43 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. Probably it is some HW damage, because I tested on my phones in all cases in variants - if phone hw alive - it connect and work. Anyway - try with BEST 1.93. Will be after few hours. |
The Following User Says Thank You to Dzirt For This Useful Post: |
