09-30-2011, 00:32 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Nokia 101 Flashing with BEST ;) Code: Phone found! Series 40 Device detected! read info... - Ok Core version : 1.29 Rev : 1.0 Selected FlashSettings : FullFlash Files Set for Flashing : MCU : rm769_006.250 PPM : rm769_006.25ei CNT : rm7690_nai06.25ei Infineon flashing... -> Infineon XG110 : IMEI Backup Created Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 PBL : Dynamic Boot Ok , 01AB SBL : Dynamic Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH ID : 0020000000048800 FLASH ID : UNKNOW [Not In Base] Boot Done! ===Flashing [MCU]=== File : rm769_006.250 Image : hw_f3_rm769_r06.250.fls Cert block found, sending.... Cert sent Found 3 region(s) Processing Region 1/3 Erase , Start : 0x00000000 , Len : 0x00020000 Erasing, wait ... Erase done Write , Start : 0x00000000 , Len : 0x00006000 Flashing , wait ... Region flash done Processing Region 2/3 Erase , Start : 0x00800000 , Len : 0x00400000 Erasing, wait ... Erase done Write , Start : 0x00800000 , Len : 0x003F0000 Flashing , wait ... Region flash done Processing Region 3/3 Erase , Start : 0x00C5D000 , Len : 0x00203000 Erasing, wait ... Erase done Write , Start : 0x00C5D000 , Len : 0x0019E700 Flashing , wait ... Region flash done Check : 81BE ===Flashing [PPM]=== File : rm769_006.25ei Image : hw_f3_rm769_006.25ei.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00100000 , Len : 0x00700000 Erasing, wait ... Erase done Write , Start : 0x00100000 , Len : 0x00523100 Flashing , wait ... Region flash done Check : 2166 ===Flashing [CNT]=== File : rm7690_nai06.25ei Image : hw_f3_rm7690_nai06.25ei.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00E60000 , Len : 0x00100000 Erasing, wait ... Erase done Write , Start : 0x00E60000 , Len : 0x000B5100 Flashing , wait ... Region flash done Check : A9CC Flashing done, rebooting... -> Infineon info : Do FullFactory Sets after flashing Flashing Done! Init Service mode... Wait... Afterflash settings... SW ver : V 06.25 25-08-11 RM-769 (c) Nokia IMEI : 357916042227385 PCode : 059H0J9 Settings After Flash Defaults... Settings Full Factory Defaults... Settings Software Upgrade Defaults... Settings Production Tune Defaults... All done! Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... SW ver : V 06.25 25-08-11 RM-769 (c) Nokia IMEI : 357хххххххххх PPM : V 06.25 25-08-11 RM-769 (c) Nokia EI PCode : 059H0J9 BPCode : 059F6L6 HWID : 3000 LCDVer : WIN:BARACOAv95 NT39121 IMEI : 357916042227385 Sl Conf : 001-01-00000000000 Sl Prof : 000000000004000-2 Sl Aux : 000B0000 Hw Sig : 33A42633478927E0 Provider : Default Test Operator Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Done! |
The Following 43 Users Say Thank You to Dzirt For This Useful Post: |
10-02-2011, 23:00 | #11 (permalink) |
No Life Poster Join Date: Aug 2006 Location: melbourne australia thailand Age: 48
Member: 338192 Status: Offline Sonork: 1678261 Thanks Meter: 154 | [QUOTE=Dzirt;7761335][code]Phone found! Series 40 Device detected! read info... - Ok Core version : 1.29 Rev : 1.0 Selected FlashSettings : FullFlash Files Set for Flashing : MCU : rm769_006.250 PPM : rm769_006.25ei CNT : rm7690_nai06.25ei Infineon flashing... -> Infineon XG110 : IMEI Backup Created Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 PBL : Dynamic Boot Ok , 01AB SBL : Dynamic Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH ID : 0020000000048800 FLASH ID : UNKNOW [Not In Base] Boot Done! ===Flashing [MCU]=== File : rm769_006.250 Image : hw_f3_rm769_r06.250.fls Cert block found, sending.... Cert sent Found 3 region(s) Processing Region 1/3 Erase , Start : 0x00000000 , Len : 0x00020000 Erasing, wait ... Erase done Write , Start : 0x00000000 , Len : 0x00006000 Flashing , wait ... Region flash done Processing Region 2/3 Erase , Start : 0x00800000 , Len : 0x00400000 Erasing, wait ... Erase done Write , Start : 0x00800000 , Len : 0x003F0000 Flashing , wait ... Region flash done Processing Region 3/3 Erase , Start : 0x00C5D000 , Len : 0x00203000 Erasing, wait ... Erase done Write , Start : 0x00C5D000 , Len : 0x0019E700 Flashing , wait ... Region flash done Check : 81BE ===Flashing [PPM]=== File : rm769_006.25ei Image : hw_f3_rm769_006.25ei.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00100000 , Len : 0x00700000 Erasing, wait ... Erase done Write , Start : 0x00100000 , Len : 0x00523100 Flashing , wait ... Region flash done Check : 2166 ===Flashing [CNT]=== File : rm7690_nai06.25ei Image : hw_f3_rm7690_nai06.25ei.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00E60000 , Len : 0x00100000 Erasing, wait ... Erase done Write , Start : 0x00E60000 , Len : 0x000B5100 Flashing , wait ... Region flash done Check : A9CC Flashing done, rebooting... -> Infineon info : Do FullFactory Sets after flashing Flashing Done! Init Service mode... Wait... Afterflash settings... SW ver : V 06.25 25-08-11 RM-769 (c) Nokia IMEI : 357916042227385 PCode : 059H0J9 Settings After Flash Defaults... Settings Full Factory Defaults... Settings Software Upgrade Defaults... Settings Production Tune Defaults... All done! Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... SW ver : V 06.25 25-08-11 RM-769 (c) Nokia IMEI : 357хххххххххх PPM : V 06.25 25-08-11 RM-769 (c) Nokia EI PCode : 059H0J9 BPCode : 059F6L6 HWID : 3000 LCDVer : WIN:BARACOAv95 NT39121 IMEI : 357916042227385 Sl Conf : 001-01-00000000000 Sl Prof : 000000000004000-2 Sl Aux : 000B0000 Hw Sig : 33A42633478927E0 Provider : Default Test Operator Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; its relay best off best INFINITY TOO GOOD |
10-03-2011, 17:06 | #12 (permalink) | |
Junior Member Join Date: May 2010 Location: Ukraine Age: 53
Member: 1295551 Status: Offline Thanks Meter: 7 | Reading Phonebook Nokia 101 Code:
The Following User Says Thank You to mizuk01 For This Useful Post: |
