12-30-2015, 09:49 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | nokia 1030 flashing problem Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM1030_1.2.3.1_059V6Q7_IMEA_PK_variant.img Ok, Set : RM1030_1.2.3.1_boot.img Ok, Set : RM1030_1.2.3.1_cache.img Ok, Set : RM1030_1.2.3.1_emmc_appsboot.mbn Ok, Set : RM1030_1.2.3.1_emmc_appsboothd.mbn Ok, Set : RM1030_1.2.3.1_fat.bin Ok, Set : RM1030_1.2.3.1_oemsbl.mbn Ok, Set : RM1030_1.2.3.1_oemsblhd.mbn Ok, Set : RM1030_1.2.3.1_persist.img Ok, Set : RM1030_1.2.3.1_preload.img Ok, Set : RM1030_1.2.3.1_qcsbl.mbn Ok, Set : RM1030_1.2.3.1_qcsblhd_cfgdata.mbn Ok, Set : RM1030_1.2.3.1_recovery.img Ok, Set : RM1030_1.2.3.1_system.img Ok, Set : RM1030_1.2.3.1_udisk.bin Ok, Set : RM1030_1.2.3.1_userdata.img File HW revision is : HW Revision V1 Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Version : Processing : RM1030_1.2.3.1_qcsblhd_cfgdata.mbn Partition Init Not Done Flash Error Break flashing! |
12-30-2015, 10:21 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Close ALL ADB.EXE/FastBoot.Exe services and other tools, which can use them. Check cable and drivers. |
