Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 05-29-2014, 16:19   #1 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Nokia 105, 108, 130, 215, 220, 225, 230 UserCode solution Without Data Lost!
Hi all.
In new BEST update ( from v1.90 ) you can reset UserCode (Security code) to default 12345 just with one button.
No format required , if you need preserve PhoneBook, Calls, Messages, Files in phone.
HowTo :
Press "Reset UserCode" button in MediaTek tab. Follow software instructions.
After operation done - code will be default (12345).
This feature not harm phone user data, user settings or any security part and fully safe.
All MTKx Nokia phones are supported.
The Following 29 Users Say Thank You to Dzirt For This Useful Post:
Old 05-29-2014, 20:20   #2 (permalink)
Member: 735781
Thanks Meter: 18
thank u so much mr. this z really great info......
Old 05-30-2014, 04:06   #3 (permalink)
Member: 1536588
Sonork: 100.1613366
Thanks Meter: 480
--- Insert USB cable now! ---
Wait for phone...
Phone found! [ 120 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6250_S0001
BB_CPU_SN : 6B3D68C20784B8D4F82E4139D125575F
BROM Protocol Version : 05
BROM Status : 1012
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL done
BL Version : 01
Setting...
Setting done , result code 0x000E
Project ID : Bree.11.01.11.p1
BROM/BL stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_eMP_Bree.fg
DA_VERIFY : 00
DA_JUMP : 00040000
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV
[0] : FLASH_DIE : 00EF 0040 0016 0000
[0] : FLASH_LEN : 0x00400000
FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000
Executing FFS FORMAT now...
DA_RET : DA_IN_PROGRESS
DA_RET : FORMAT_DONE
Old 05-30-2014, 04:10   #4 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BROM Status : 1012
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
DA_eMP_Bree.fg
DA_VERIFY : 00
DA_JUMP : 00040000
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
It is "Format" , which destroy UserData. All.
Here I explained about safe way, which not kill UserData.
The Following User Says Thank You to Dzirt For This Useful Post:
Old 06-06-2014, 05:35   #5 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Seems as way not correct works on Nokia 225 (6260 series).
It reset code only once from 2-3 try. But not made any harm. Just got a phone and will make it in near days
The Following 2 Users Say Thank You to Dzirt For This Useful Post:
Old 06-06-2014, 21:52   #6 (permalink)
Member: 237256
Thanks Meter: 91
Originally Posted by Dzirt View Post
Hi all.
HowTo :
Dzirt,
You may need to re-check this on Nokia 108 because it is not working on this phone. I had to use another software for mtk 625a to run this phone to remove code after several attempts with best dongle software
The Following User Says Thank You to pastor good For This Useful Post:
Old 06-07-2014, 04:59   #7 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Originally Posted by pastor good View Post
Dzirt,
It is working great. I recommend you throw your "108 cable" or rebuild it.
If you still sure - it "not working" - check success post/threads here. Them are enough to make sure on that.
Old 06-10-2014, 13:32   #8 (permalink)
Member: 237256
Thanks Meter: 91
Give me at least two success links.
Old 06-10-2014, 13:48   #9 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
http://forum.gsmhosting.com/vbb/sear...chid=161087719
Tag : Nokia 108 in that subforum - at least 100 success post you will find.
Old 06-10-2014, 14:45   #10 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
From BEST v1.91 possible reset UserCode on MTK6260 Phones as well.
Supported models MTK6260 :
RM-1011 - Nokia 225 DS
RM-1012 - Nokia 225 SS
RM-1043 - Nokia 225 DS
Supported models MTK6250 :
RM-944 - Nokia 108 DS
RM-945 - Nokia 108 SS
RM-969 - Nokia 220 DS
RM-970 - Nokia 220 SS
RM-971 - Nokia 220 SS
The Following 4 Users Say Thank You to Dzirt For This Useful Post:
Old 06-12-2014, 22:39   #11 (permalink)
Member: 237256
Thanks Meter: 91
link not accessable.
Old 06-13-2014, 03:45   #12 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
In that case I write, what to do : SEARCH with TAG.
Old 06-14-2014, 11:13   #13 (permalink)
Member: 237256
Thanks Meter: 91
Dzirt, you need to look into the problem of this mtk chip phones properly, i presently have a china box that can do these phones very well but for the sake of others who may not be interested in china phones, this may be a serious problem to them.
Old 06-14-2014, 11:40   #14 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
I not have them and no have idea what they do and what BEST not do.
Without logs and explanations - I even not understand what wrong with your phone and e.t.c.
Make other thread with explanation of problem or just use "working" boxes for them. All is simple.
Old 07-19-2014, 14:03   #15 (permalink)
adnanali's Avatar
Member: 207308
Thanks Meter: 471
Dead Mode is Selected
Waiting for USB device...
1. Phone should be Off!
2. Battery must be charged and inserted! ( if not used external power )
- > If phone can't switch to BL - use battery or flash from Local mode!
Wait for phone...
Device boot not done
Check Drivers
Try again
Boot Error
Flashing failed!
Connect phone on selected interface...
Phone found!
MTKx Nokia Phone detected
Read info... Ok
just install working driver and in 20mints flash ok
Core : v1.92 , MTKx FlashEngine : v4.2
Verify files ...
MAUI : RM-944_ROM_eMP_20.06.11
VIVA : RM-944_VIVA_eMP_20.06.11
LANG : RM-944_LANG_PACK_ROM_IC_eMP_20.06.11
CUST : RM-944_CUSTPACK_ROM_IC_MEA_SA_eMP_20.06.11
JMPT : RM-944_JUMP_TABLE_IC_MEA_SA_eMP_20.06.11
- > MODE : FullFlash
Software Info: 11.01.11 00-00-00 RM-944
Page generated in 0.26176 seconds with 8 queries
