Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 07-27-2014, 07:17   #16 (permalink)
Member: 2229249
nokia 220 RM-969
need help ,,,,,,,,,
nokia 220 RM-969 can not write flash ,,I try more phone and more driver still same,,,,,,, it show as below,,
Connect phone on selected interface...
Dead Mode is Selected
card found: S/N xxxxxxx
registered to: xxxxxxxx
Waiting for USB device...
1. Phone should be Off!
2. Battery must be charged and inserted! ( if not used external power )
- > If phone can't switch to BL - use battery or flash from Local mode!
--- Insert USB cable now! ---
Wait for phone...
Device boot not done
Check Drivers
Try again
Boot Error
Flashing failed!
Old 07-27-2014, 19:23   #17 (permalink)
sajidali's Avatar
Member: 181886
Sonork: 100.1579817
Thanks Meter: 1,007
This is Bug in new version i think i have same problem but after use this version (InfinityBox_install_BEST_v1.92) All work fine
Here Is LOG
card found: S/N xxxxxxxx
registered to: xxxxxxxxxxxxx
Phone found!
MTKx Nokia Phone detected
Read info... Ok
Software Info: 10.01.11 00-00-00 RM-1011
IMEI: 3523530628xxxxx
PPM version : IJ
Product code: 059V5V2
Rebooting phone to FlashMode...
Wait for phone...
Phone found! [ 142 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0001
BB_CPU_SN : 5C0F57112817DE0530E61A05FFE0D501
BROM Protocol Version : 05
BROM Status : 0000
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
All done! Remove USB cable
All Security Settings deactivated!
Code set to default : 12345
Done!
The Following User Says Thank You to sajidali For This Useful Post:
Old 07-28-2014, 06:23   #18 (permalink)
Member: 2229249
ok now it work 100% with V1.92
Old 07-29-2014, 22:05   #19 (permalink)
emilkawa's Avatar
Member: 112498
Thanks Meter: 33
Wait for phone...
Check Drivers
Try again
Boot Error
Flashing failed!
Phone found!
Read info... Ok
just install working driver and in 20mints flash ok
Core : v1.92 , MTKx FlashEngine : v4.2
Verify files ...
MAUI : RM-944_ROM_eMP_20.06.11
VIVA : RM-944_VIVA_eMP_20.06.11
LANG : RM-944_LANG_PACK_ROM_IC_eMP_20.06.11
CUST : RM-944_CUSTPACK_ROM_IC_MEA_SA_eMP_20.06.11
JMPT : RM-944_JUMP_TABLE_IC_MEA_SA_eMP_20.06.11
- > MODE : FullFlash
Software Info: 11.01.11 00-00-00 RM-944
what exactely driver did you instaled? Give me link please, becauce I'm trying and looping around. Don't write about driver from support, please, give me name of driver.
... I tryed with several PCs and stil the same problem - phone can not boot in flash mode.
Emilkawa
Old 08-06-2014, 10:12   #20 (permalink)
..::khaled::..'s Avatar
Member: 329483
Sonork: 100
Thanks Meter: 443
Emilkawa
same problem phone can not boot in flash mode.
Verify files ...
MAUI : RM-944_ROM_eMP_22.00.11
VIVA : RM-944_VIVA_eMP_22.00.11
LANG : RM-944_LANG_PACK_ROM_IC_eMP_22.00.11
CUST : RM-944_CUSTPACK_ROM_IC_MEA_DZ_eMP_22.00.11
JMPT : RM-944_JUMP_TABLE_IC_MEA_DZ_eMP_22.00.11
Software Info:     12.06.11 00-00-00 RM-944
IMEI:  352366062296420
PPM version :   IC
Product code:  059S7Q0
Wait for phone...
Check Drivers
Try again
Boot Error
Flashing failed!
Phone found!
Read info... Ok
Old 08-06-2014, 12:34   #21 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
WakeUp!
1.94 out. All is Working as should.
Old 08-07-2014, 04:40   #22 (permalink)
Member: 726263
Thanks Meter: 6
mtk ver 1.94 work again
work again tahnk best team
Wait for phone...
Check Drivers
Try again
Phone found!
Read info... Ok
IMEI: 358971054052188
PPM version : ME
Product code: 059T923
Wait for phone...
Phone found! [ 226 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6250_S0001
BB_CPU_SN : B204DF2C9ABE21F3C824C64B7C19B627
BROM Status : 1012
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
Setting done , result code 0x000E
Project ID : Bree.12.06.11.p1
BROM/BL stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_eMP_Bree.fg
DA_VERIFY : 00
DA_JUMP : 00040000
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E
[0] : FLASH_DIE : 00C2 0025 0036 0000
[0] : FLASH_LEN : 0x00400000
FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000
Data prepared!
First Step Done, Now Re-connect power/cable!
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BROM Status : 1012
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
DA_eMP_Bree.fg
DA_VERIFY : 00
DA_JUMP : 00040000
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
Done!
Phone found!
Read info... Ok
PPM version : ME
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BROM Status : 1012
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
DA_eMP_Bree.fg
DA_VERIFY : 00
DA_JUMP : 00040000
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
Executing FFS FORMAT now...
DA_RET : DA_IN_PROGRESS
DA_RET : FORMAT_DONE
Old 08-07-2014, 19:14   #23 (permalink)
rasheedc007's Avatar
Member: 1245320
Sonork: 100.1612126
Thanks Meter: 140
i cant conect.driver install but again asking driver.pls give proper driver for new nokia 220 rm-696..
Old 08-08-2014, 06:52   #24 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
On support. Nokia Serial Driver.
Old 09-04-2014, 08:05   #25 (permalink)
Member: 395389
Sonork: no idi
Thanks Meter: 193
registered to: szktk
Wait for phone...
Phone found! [ 14 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_SN : 41BB2597E0CC6DEE5266C3FE42166C95
BROM Status : 1012
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
Project ID : Rivendell.10.03.11.p1
BROM/BL stage done
DA_eMP_Rivendell.fg
DA_VERIFY : 00
DA_JUMP : 00040000
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW
[0] : FLASH_DIE : 00EF 0060 0018 0000
[0] : FLASH_LEN : 0x01000000
FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000
The Following User Says Thank You to szktk For This Useful Post:
Old 09-15-2014, 17:27   #26 (permalink)
Member: 1565811
Sonork: 786
Thanks Meter: 8
driver download??????
Wait for phone...
Check Drivers
Try again
Boot Error
Flashing failed!
Phone found!
Read info... Ok
Old 09-22-2014, 08:55   #27 (permalink)
goondy's Avatar
Member: 203747
Thanks Meter: 94
nokia 108
Hi
i have a 108 for flash search for pinouts in google is it the same for BEST like other tools if not
can some upload it pls
Old 09-22-2014, 09:31   #28 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Hi, it inside BEST DOC's folder.
Old 09-22-2014, 09:54   #29 (permalink)
goondy's Avatar
Member: 203747
Thanks Meter: 94
hi
Hi TY SIR
didnt know that
Old 10-04-2014, 06:47   #30 (permalink)
gsmcrazy1's Avatar
Member: 897524
Sonork: 100,1609543
Thanks Meter: 172
Working to me on nokia 225
Wait for phone...
Phone found! [ 22 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_SN : EF474FBA76D0C80D87F5B9235E4A4665
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
Project ID : PEARL.10.01.11.p2
BROM/BL stage done
DA_eMP_Pearl.fg
DA_VERIFY : 00
DA_JUMP : 00040000
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G
[0] : FLASH_DIE : 00C2 0025 0038 0000
FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000
Page generated in 0.22814 seconds with 8 queries
