05-25-2015, 09:08 | #54 (permalink) |
No Life Poster Join Date: Apr 2015 Location: FLORENCE ITALY
Member: 2375239 Status: Offline Sonork: 100.1662985 Thanks Meter: 962 | mr Drizt i have problem change the language of nokia 225 RM-1011 i flashed fone with latest software fone work everthing ok but i want arabic language in this fone but always show error when i select the change language Connect phone on selected interface... Core : v2.06 , MTKx FlashEngine : v7.4 Verify files ... MAUI : RM-1011_ROM_eMP_21.00.11 VIVA : RM-1011_VIVA_eMP_21.00.11 LANG : RM-1011_LANG_PACK_ROM_EC_eMP_21.00.11_002 CUST : RM-1011_CUSTPACK_ROM_EC_EURO_CZ_eMP_21.00.11_002 JMPT : RM-1011_JUMP_TABLE_EC_EURO_CZ_eMP_21.00.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 9 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 793C12DE0B25DCA11130A0DC186F34EA BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.21.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 SecureDecrypt : RM-1011_ROM_eMP_21.00.11 SecureDecrypt : RM-1011_VIVA_eMP_21.00.11 SecureDecrypt : RM-1011_LANG_PACK_ROM_EC_eMP_21.00.11_002 SecureDecrypt : RM-1011_CUSTPACK_ROM_EC_EURO_CZ_eMP_21.00.11_002 SecureDecrypt : RM-1011_JUMP_TABLE_EC_EURO_CZ_eMP_21.00.11_002 OVRLP : 000069B900000001 PHPID : PEARL.21.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x00040000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1011_ROM_eMP_21.00.11 Write : RM-1011_LANG_PACK_ROM_EC_eMP_21.00.11_002 Write : RM-1011_CUSTPACK_ROM_EC_EURO_CZ_eMP_21.00.11_002 Write : RM-1011_JUMP_TABLE_EC_EURO_CZ_eMP_21.00.11_002 Write : RM-1011_VIVA_eMP_21.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1011_ROM_eMP_21.00.11 [VERIFY] DONE : RM-1011_LANG_PACK_ROM_EC_eMP_21.00.11_002 [VERIFY] DONE : RM-1011_CUSTPACK_ROM_EC_EURO_CZ_eMP_21.00.11_002 [VERIFY] DONE : RM-1011_JUMP_TABLE_EC_EURO_CZ_eMP_21.00.11_002 [VERIFY] DONE : RM-1011_VIVA_eMP_21.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:02:57 Reboot phone Ok - > Hint : If phone shows Battery charge icon - press and hold PowerOn button 10 seconds |
05-25-2015, 09:17 | #55 (permalink) |
Member: 2375239 Status: Offline Sonork: 100.1662985 Thanks Meter: 962 | here is flashing error when i change the language Connect phone on selected interface... Core : v2.06 , MTKx FlashEngine : v7.4 Verify files ... MAUI : RM-1011_ROM_eMP_21.00.11 VIVA : RM-1011_VIVA_eMP_21.00.11 LANG : RM-1011_LANG_PACK_ROM_IC_eMP_20.10.11_002 CUST : RM-1011_CUSTPACK_ROM_EC_EURO_CZ_eMP_21.00.11_002 JMPT : RM-1011_JUMP_TABLE_EC_EURO_CZ_eMP_21.00.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 9 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 793C12DE0B25DCA11130A0DC186F34EA BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.21.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 SecureDecrypt : RM-1011_ROM_eMP_21.00.11 SecureDecrypt : RM-1011_VIVA_eMP_21.00.11 SecureDecrypt : RM-1011_LANG_PACK_ROM_IC_eMP_20.10.11_002 SecureDecrypt : RM-1011_CUSTPACK_ROM_EC_EURO_CZ_eMP_21.00.11_002 SecureDecrypt : RM-1011_JUMP_TABLE_EC_EURO_CZ_eMP_21.00.11_002 OVRLP : 000069B900000001 PHPID : PEARL.21.00.11.p1 === Backup Enabled Reading RPL backup... Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive Mobile Info : IMEI : 356467067875246 BBUID : 793C12DE0B25DCA11130A0DC186F34EA SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 356467067875246_MTK_2nd.mtsec === Backup OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 [ERROR] : DA_NOR_PROGRAM_REGION_IS_OVERLAP Error While erase area!!! Flashing failed! Connect phone on selected interface... |
05-25-2015, 13:46 | #57 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
DON'T MIX THE FILES!!! Flash WHOLE FW from need version. Downgrade can be done by simple flashing of need version. Too sad ;( | |
05-30-2015, 14:31 | #58 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | sucessfull reset code to factory nokia 108 reset user code sucesfully http://forum.gsmhosting.com/vbb/11080772-post8598.html thanks to infinity team |
06-22-2015, 17:57 | #60 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | |
