Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 10-04-2014, 08:00   #31 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Main idea of this thread is - REMOVING User Code WITHOUT data lost.
Simple formatting - not a way, if need just reset forgotten code.
For reports exist thread : http://forum.gsmhosting.com/vbb/f641...-here-1088692/
Old 10-12-2014, 15:11   #32 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Nokia 225 user code done, working perfect-
Connect phone on selected interface...
Dead Mode is Selected
Waiting for USB device...
1. Phone should be Off!
2. Battery must be charged and inserted! ( if not used external power )
- > If phone can't switch to BL - use battery or flash from Local mode!
--- Insert USB cable now! ---
Wait for phone...
Phone found! [ 64 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0001
BB_CPU_SN : 2EC5112C6A4DB9F27AD8CDC8CF21169F
BROM Protocol Version : 05
BROM Status : 0000
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
All done! Remove USB cable
All Security Settings deactivated!
Code set to default : 12345
Done!
Br.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 10-19-2014, 13:01   #33 (permalink)
niaz muhammad's Avatar
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,951
225 UserCode solution Without Data Los don
card found: S/N 4527:0118
registered to: Niaz
Wait for phone...
Phone found! [ 19 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_SN : 5EFD119C3FCC80E52973AD10C00993EF
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
Done!
The Following User Says Thank You to niaz muhammad For This Useful Post:
Old 11-02-2014, 09:05   #34 (permalink)
AniAxn's Avatar
Member: 1045758
Sonork: 100.1613661(Offline)
Thanks Meter: 4,307
Nokia 225 Rm-1011 User Code Reset without less Data
Wait for phone...
Phone found! [ 103 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_SN : 335550D0BA46F090548A5FF89A7FB501
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
Done!
Wbr,
AniAXN
Old 11-06-2014, 15:38   #35 (permalink)
Member: 1883835
plz help me nokia best bb5 tool ver 1.89 link
Old 11-06-2014, 15:48   #36 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Latest is 1.98 , and it located on support area.
Especially for blind : http://forum.gsmhosting.com/vbb/f641...-more-1870725/
The Following User Says Thank You to Dzirt For This Useful Post:
Old 11-21-2014, 09:07   #37 (permalink)
Member: 2295505
where i found the working driver?
if you have please upload
Old 01-05-2015, 09:09   #38 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Nokia 108 cable schematic needed
[QUOTE=Dzirt;10360294]It is working great. I recommend you throw your "108 cable" or rebuild it.
I WANT TO REBUILD THAT CABLE GIVE ME TUTORIAL/SCHEMATIC
THAXXXXXXXXXX
Old 01-05-2015, 14:06   #39 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
THAXXXXXXXXXX
How solder 4 wires?
Schematic inside BEST/DOC's folder.
Just one thing need change - use phone original BATTERY instead of VCC from PC. And all will work. Or make BSI jumper via resistor, like old FBUS nokia cables. But I have no idea about resistor value, need take battery and measure.
Old 02-16-2015, 14:36   #40 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Nokia 215 from BEST v2.02 is Activated!
Wait for phone...
Phone found! [ 52 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_SN : 92CF35B1EADB3D34498D76D363741F87
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
Done!
Old 02-25-2015, 20:58   #41 (permalink)
daroas's Avatar
Member: 194078
Sonork: no have
Thanks Meter: 209
already installed the drive but the computer recognizes the 225 RM-1043 and known then. What should I do?
Old 02-25-2015, 21:28   #42 (permalink)
daroas's Avatar
Member: 194078
Sonork: no have
Thanks Meter: 209
after instal VolcanoBox_Nokia_MTK_Flash_Drivers working fine
Wait for phone...
Phone found! [ 236 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_SN : 7FCE26286950CB47322C7246A5F9A692
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
Done!
Old 02-26-2015, 05:46   #43 (permalink)
JayDi's Avatar
Member: 462970
@daroas , 2 little secrets :
1. It is very old drivers, which I made from normal mtk drivers.
2. They change nothing , because BEST not use them more, than 1 year.
Old 04-28-2015, 13:23   #44 (permalink)
naveedsialkoti's Avatar
Member: 2375239
Sonork: 100.1662985
Thanks Meter: 962
infinty best always a head of first
Old 04-28-2015, 16:23   #45 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Nokia 108 models and Nokia 220 models now, instead of 2 step procedure for user code reset, will just readout current User Code.
Wait for phone...
Phone found! [ 52 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6250_S0001
BB_CPU_SN : EB7E4B7AF14CE0AD03C86F7B0A0F54D7
BROM Status : 1012
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
Setting done , result code 0x8000
Project ID : Bree.20.06.11.p4
BROM/BL stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_eMP_Bree.fg
DA_VERIFY : 00
DA_JUMP   : 00040000
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x88
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV
[0] : FLASH_DIE : 00EF 0040 0016 0000
[0] : FLASH_LEN : 0x00400000
FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000
MT625x : Read User Code
User Code : 88800011
Done!
It save much time, if exists problems with cable ( for Nokia 108 ) or some strange Nokia 220 models.
Page generated in 0.24049 seconds with 8 queries
