Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 06-22-2015, 18:13   #61 (permalink)
Member: 2000524
Sonork: 100.1679849
Thanks Meter: 13
Infinity box is necessary for that bro ? i have ATF box :-(
Old 06-22-2015, 20:13   #62 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Just get out from here with your "extra smart" questions.
Old 07-13-2015, 08:37   #63 (permalink)
JayDi's Avatar
Member: 462970
From BEST v2.09 possible reset user code on following phones without ANY byte of UserData Lost :
Nokia 105 SS [RM-1133]
Nokia 105 DS [RM-1134]
Nokia 105 SS [RM-1135]
The Following User Says Thank You to JayDi For This Useful Post:
Old 07-13-2015, 09:30   #64 (permalink)
ij_cell's Avatar
Member: 1937038
Sonork: QQ 2045657399
Thanks Meter: 4,492
i am sure i will post result first of it
Old 07-13-2015, 10:22   #65 (permalink)
Member: 1043909
Thanks Meter: 60,926
[BEST] v2.09 released - http://forum.gsmhosting.com/vbb/f641...-more-1968671/
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 07-24-2015, 11:41   #66 (permalink)
ij_cell's Avatar
Member: 1937038
Thanks Meter: 4,492
Nokia 130 security code reset without data lose done.
Connect phone on selected interface...
Dead Mode is Selected
Waiting for USB device...
1. Phone should be Off!
2. Battery must be charged and inserted! ( if not used external power )
- > If phone can't switch to BL - use battery or flash from Local mode!
--- Insert USB cable now! ---
Wait for phone...
Phone found! [ 468 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0001
BB_CPU_SN : 85AEAC6D73B41D3209B4CBF1657C44B5
BROM Protocol Version : 05
BROM Status : 0000
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
MT626x : Reset User Code
All done! Remove USB cable
All Security Settings deactivated!
Code set to default : 12345
Done!
The Following User Says Thank You to ij_cell For This Useful Post:
Old 07-28-2015, 21:41   #67 (permalink)
JayDi's Avatar
Member: 462970
Nokia 105 DS , Reset UserCode WITHOUT Data Lost.
Wait for phone...
Phone found! [ 16 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0001
BB_CPU_SN : EABB74F587812ED2027FE99F2FE9F3FD
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
Done!
The Following 4 Users Say Thank You to JayDi For This Useful Post:
Old 08-17-2015, 18:35   #68 (permalink)
Member: 2266730
sir pls give me nokia 108 and nk 220 usb driver its urgent,i tried many driver but not succesed pls help.
Old 08-17-2015, 18:43   #69 (permalink)
JayDi's Avatar
Member: 462970
All drivers on support area. Nokia Serial driver called.
Old 08-18-2015, 07:18   #70 (permalink)
Member: 636786
Sonork: 100.1576399
Thanks Meter: 34
good news for me
thanks for BEST
Old 08-18-2015, 11:34   #71 (permalink)
nans1981's Avatar
Member: 629558
Thanks Meter: 53
RM-969 - Nokia 220 DS
Hang Logo Done
Operation : Check / Read Info [ v1.25 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 95 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6250_S0000
BB_CPU_SN : 1C1FB29CAEAA7DDF37F53AC5227DBAD4
BROM Status : 1012
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
Setting done , result code 0x8000
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_eMP_Nk1.fg
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G
[0] : FLASH_DIE : 00C2 0025 0038 0000
[0] : FLASH_LEN : 0x01000000
Done!
Elapsed: 00:00:12
Reconnect Power/Cable!
Operation : Format FileSystem [ v1.25 ]
Wait for phone...
Phone found! [ 95 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BROM Status : 1012
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
BROM stage done
DA_eMP_Nk1.fg
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
Executing FFS FORMAT now...
FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000
DA_RET : DA_IN_PROGRESS
DA_RET : FORMAT_DONE
Done!
Elapsed: 00:01:04
The Following User Says Thank You to nans1981 For This Useful Post:
Old 08-23-2015, 12:49   #72 (permalink)
Member: 2448515
yes i agreed that fault is cable i tested 3 time error the reset and finally i changed the cable then my problem is solved dont use uart combo cable only use usb fbuss cable sorry for my bad english
Old 10-04-2015, 10:15   #73 (permalink)
Member: 2448268
need nokia 130 contact service solution
Old 10-04-2015, 15:30   #74 (permalink)
JayDi's Avatar
Member: 462970
Easy - just buy new phone for customer.
Old 01-11-2016, 17:22   #75 (permalink)
Member: 2168928
Thanks Meter: 8
the lastet version update to ver 2.15
Page generated in 0.23445 seconds with 8 queries
