12-19-2017, 22:43 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: algeria BBA BELIMOUR Age: 46
Member: 184351 Status: Offline Thanks Meter: 263 | nokia 105 flashing problem SW ver : V 03.65 25-04-14 RM-908 (c) Nokia IMEI : 3518xxxxxxxx PPM : V 03.65 25-04-14 RM-908 (c) Nokia IC PCode : 059W387 BPCode : 059W1Q1 HWID : 3000 LCDVer : BYD:BEIHAIv83 ST7735R2 IMEI : 35xxxxxxxxx Sl Conf : 001-01-00000000000 Sl Prof : 000000000004000-2 Sl Aux : 000B0000 Hw Sig : E81D818AB8C335B6 Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Done! Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm908_003.400 PPM : rm908_003.40ae CNT : rm9080_nai03.40ae Infineon flashing... -> Infineon XG110 : IMEI Backup Created Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 PBL : Dynamic Boot Ok , 01AB SBL : Dynamic Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH VEN : 000000C2 FLASH DIE : 00002537 FLASH ID : UNKNOW [Not In Base] Boot Done! ===Flashing [MCU]=== File : rm908_003.400 Image : hw_f31_rm908_62_mcusw_03.40_Best.fls Cert block found, sending.... Cert sent Found 3 region(s) Processing Region 1/3 Erase , Start : 0x00800000 , Len : 0x00210000 Erasing, wait ... Erase Error [02000508020000000F0003000000] - > Error... - > Check cable, flashfile Connect phone on selected interface... |
12-20-2017, 00:55 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. 4.35 not from this device at all. That flash id has been not included in loaders packages, which we got and added inside sw. Since loaders signed - there is no way to edit it for this IC. Will try ask some old sources, if there is a way nowdays to get something and will check if possible some alternative epp config. ETA - this weekend. Otherwise - SPI. |
12-20-2017, 13:10 | #4 (permalink) |
Member: 184351 Status: Offline Thanks Meter: 263 | by the way is there a workaround to fix the phone because when you open sound settings the phone power off and it is in silent mode i already tried factory reset but the same problem i mean other ways than flash |
12-24-2017, 13:38 | #7 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
12-24-2017, 20:35 | #8 (permalink) | |
Member: 184351 Status: Offline Thanks Meter: 263 | Quote: | |
