Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 06-14-2014, 13:11   #1 (permalink)
.:Sanjh Phoenix:.'s Avatar
Member: 1728736
Sonork: 100.1615042
Thanks Meter: 1,098
Nokia 105 NO POWER ON WITH BATTERY AFTER FLASH
UFS S/N XXXXX boot - Ok
Connect phone on selected interface...
Read and Check phone data...
Infineon checking...
Booting phone now....
Sync Ok , A2
CPU ID : XGOLD , A200341100
PBL : Dynamic
Boot Ok , 01AB
SBL : Dynamic
Algo Ok , 01
SBL mode Ok
SBL : Default_RAM_Bootloader
EPP CFG [Bering]...
FLASH VEN : 0000002C
FLASH DIE  : 0000CB17
FLASH ID : SPI , 25W064A
Boot Done!
   ===Flashing [MCU]===
File : rm908_02.700
Image : hw_b1_rm908_02.700.fls
Cert block found, sending....
Cert sent
Found 3 region(s)
Processing Region 1/3
Erase , Start : 0x00800000 , Len : 0x00210000
Erasing, wait ...
Erase done
Write , Start : 0x00800000 , Len : 0x00210000
Flashing , wait ...
Region flash done
Processing Region 2/3
Erase , Start : 0x00C60000 , Len : 0x00250000
Erasing, wait ...
Erase done
Write , Start : 0x00C60000 , Len : 0x00221240
Flashing , wait ...
Region flash done
Processing Region 3/3
Erase , Start : 0x00FFC000 , Len : 0x00004000
Erasing, wait ...
Erase done
Write , Start : 0x00FFC000 , Len : 0x00000040
Flashing , wait ...
Region flash done
Check : A59F
   ===Flashing [PPM]===
File : rm908_02.70ij
Image : hw_b1_rm908_02.70ij.fls
Cert sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x00210000 , Len : 0x00250000
Erasing, wait ...
Erase done
Write , Start : 0x00210000 , Len : 0x0018A340
Flashing , wait ...
Region flash done
Check : 96E9
   ===Flashing [CNT]===
File : rm908_nai02.70ij
Image : hw_b1_rm908_nai02.70ij.fls
Cert sent
Found 1 region(s)
Erase , Start : 0x00EB0000 , Len : 0x000D0000
Erasing, wait ...
Erase done
Write , Start : 0x00EB0000 , Len : 0x000661C0
Flashing , wait ...
Region flash done
Check : A3FD
Flashing done, rebooting...
-> Infineon info : Do FullFactory Sets after flashing
Flashing Done!
BUT WITH CABLE ITS POWER ON
PLEASE HELP
Old 06-14-2014, 13:34   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Battery or try other FlashFiles and make factory sets.
The Following User Says Thank You to Dzirt For This Useful Post:
Old 06-14-2014, 13:44   #3 (permalink)
Member: 1728736
Sonork: 100.1615042
Thanks Meter: 1,098
i already changed battery , and also other flash file,
if you have good flash file please provide link
Thank In Advance
Old 06-14-2014, 13:49   #4 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
On BEST support all files, what I made is good.
Try other battery for start.
Old 06-14-2014, 13:54   #5 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
check BSI track or rehot the cpu
Old 06-14-2014, 13:56   #6 (permalink)
Member: 1728736
Sonork: 100.1615042
Thanks Meter: 1,098
i will try with other file then i post result
Old 06-14-2014, 15:43   #7 (permalink)
Member: 1728736
Sonork: 100.1615042
Thanks Meter: 1,098
Please sir
my phone product code
rm-908-059R489
but no file for this product code
if you have provide
Old 06-14-2014, 15:46   #8 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
On BEST support area files sorted via Language Packages.
Old 06-14-2014, 16:00   #9 (permalink)
Nasir Mobiles's Avatar
Member: 355782
Thanks Meter: 1,265
Originally Posted by .:Sanjh Phoenix:. View Post
Please sir
rm-908-059R489
if you have provide
Flash with different version not only different flash files no matter whats product code...
currently you are trying 2.70 try to flash with 3.40 and post result...
BTW your phone @ local mode due to wrong file version.
Old 06-14-2014, 16:10   #10 (permalink)
Member: 1728736
Sonork: 100.1615042
Thanks Meter: 1,098
bro already flashed with 3.40 and 2.70 but problem same
Old 06-14-2014, 16:13   #11 (permalink)
Member: 355782
Thanks Meter: 1,265
why you flashed the phone?
I mean what was the condition of phone before flash ?
Old 06-14-2014, 16:18   #12 (permalink)
Member: 1728736
Sonork: 100.1615042
Thanks Meter: 1,098
its security lock , i tried to factory setting but i cant,
so i flashed the phone
Old 06-14-2014, 16:20   #13 (permalink)
mobite's Avatar
Member: 1800009
Sonork: 100.1654307
Thanks Meter: 806
Its a bsi line problem 100% many time this type problem come in 6300 and 3110
Old 06-14-2014, 16:23   #14 (permalink)
maxmobilephone's Avatar
Member: 1969978
Sonork: 100.1613242
Thanks Meter: 693
Chenge lcd.........................
Old 06-14-2014, 16:23   #15 (permalink)
Member: 1728736
Sonork: 100.1615042
Thanks Meter: 1,098
bsi line is ok. and i am also tried remove resistor
but same
Page generated in 0.19911 seconds with 8 queries
