06-25-2017, 11:36 | #1 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: 46000
Member: 197566 Status: Offline Thanks Meter: 89 | Nokia 105 rm-1133 contacy service after flash read rpl log Quote:
06-26-2017, 10:04 | #8 (permalink) | |
Member: 197566 Status: Offline Thanks Meter: 89 | I flash with same product code firmware v.10.01.11 but same problem-contact service Quote:
10-20-2017, 07:18 | #12 (permalink) |
Freak Poster Join Date: May 2017 Location: Afghanistan Jalal Abad Age: 21
Member: 2715631 Status: Offline Thanks Meter: 79 | same problem Connect phone on selected interface... Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1133_ROM_eMP_13.00.11 VIVA : RM-1133_VIVA_eMP_13.00.11 LANG : RM-1133_LANG_PACK_ROM_IJ_eMP_13.00.11_002 CUST : RM-1133_CUSTPACK_ROM_IJ_MEA_PK_eMP_13.00.11_002 JMPT : RM-1133_JUMP_TABLE_IJ_MEA_PK_eMP_13.00.11_002 - > MODE : FullFlash Repair Mode is On Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 36 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 6AC677A4FC56F786DAED13140D5130B2 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : LAGOS61D.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Lagos.fg DA_VERIFY : 00 DA_JUMP : 00100000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x00368000-0x003F7FFF , LEN : 0x00090000 SecureDecrypt : RM-1133_ROM_eMP_13.00.11 SecureDecrypt : RM-1133_VIVA_eMP_13.00.11 SecureDecrypt : RM-1133_LANG_PACK_ROM_IJ_eMP_13.00.11_002 SecureDecrypt : RM-1133_CUSTPACK_ROM_IJ_MEA_PK_eMP_13.00.11_002 SecureDecrypt : RM-1133_JUMP_TABLE_IJ_MEA_PK_eMP_13.00.11_002 OVRLP : 000069B900000001 PHPID : LAGOS61D.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1133_ROM_eMP_13.00.11 Write : RM-1133_LANG_PACK_ROM_IJ_eMP_13.00.11_002 Write : RM-1133_CUSTPACK_ROM_IJ_MEA_PK_eMP_13.00.11_002 Write : RM-1133_JUMP_TABLE_IJ_MEA_PK_eMP_13.00.11_002 Write : RM-1133_VIVA_eMP_13.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1133_ROM_eMP_13.00.11 [VERIFY] DONE : RM-1133_LANG_PACK_ROM_IJ_eMP_13.00.11_002 [VERIFY] DONE : RM-1133_CUSTPACK_ROM_IJ_MEA_PK_eMP_13.00.11_002 [VERIFY] DONE : RM-1133_JUMP_TABLE_IJ_MEA_PK_eMP_13.00.11_002 [VERIFY] DONE : RM-1133_VIVA_eMP_13.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00368000-0x003F7FFF , LEN : 0x00090000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:00:46 Reboot phone Ok Connect phone on selected interface... SSChannel : Create SC SSChannel : Failed to get info! Please, check ProductCode, which you enter. Probably it wrong ErroInfo : Unknown response received from SRV SSChannel : Create SC SSChannel : Failed to get info! Please, check ProductCode, which you enter. Probably it wrong ErroInfo : Unknown response received from SRV Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1133_ROM_eMP_10.01.11 VIVA : RM-1133_VIVA_eMP_10.01.11 LANG : RM-1133_LANG_PACK_ROM_MS_eMP_10.01.11_004 CUST : RM-1133_CUSTPACK_ROM_MS_MEA_BD_eMP_10.01.11_004 JMPT : RM-1133_JUMP_TABLE_MS_MEA_BD_eMP_10.01.11_004 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 36 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 6AC677A4FC56F786DAED13140D5130B2 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : LAGOS61D.13.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Lagos.fg DA_VERIFY : 00 DA_JUMP : 00100000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x00368000-0x003F7FFF , LEN : 0x00090000 SecureDecrypt : RM-1133_ROM_eMP_10.01.11 SecureDecrypt : RM-1133_VIVA_eMP_10.01.11 SecureDecrypt : RM-1133_LANG_PACK_ROM_MS_eMP_10.01.11_004 SecureDecrypt : RM-1133_CUSTPACK_ROM_MS_MEA_BD_eMP_10.01.11_004 SecureDecrypt : RM-1133_JUMP_TABLE_MS_MEA_BD_eMP_10.01.11_004 OVRLP : 000069B900000001 PHPID : LAGOS61D.13.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1133_ROM_eMP_10.01.11 Write : RM-1133_LANG_PACK_ROM_MS_eMP_10.01.11_004 Write : RM-1133_CUSTPACK_ROM_MS_MEA_BD_eMP_10.01.11_004 Write : RM-1133_JUMP_TABLE_MS_MEA_BD_eMP_10.01.11_004 Write : RM-1133_VIVA_eMP_10.01.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1133_ROM_eMP_10.01.11 [VERIFY] DONE : RM-1133_LANG_PACK_ROM_MS_eMP_10.01.11_004 [VERIFY] DONE : RM-1133_CUSTPACK_ROM_MS_MEA_BD_eMP_10.01.11_004 [VERIFY] DONE : RM-1133_JUMP_TABLE_MS_MEA_BD_eMP_10.01.11_004 [VERIFY] DONE : RM-1133_VIVA_eMP_10.01.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00368000-0x003F7FFF , LEN : 0x00090000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:00:48 Reboot phone Ok Connect phone on selected interface... |
10-20-2017, 11:09 | #14 (permalink) | |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,801 | Quote:
12-08-2017, 17:55 | #15 (permalink) |
Freak Poster Join Date: Sep 2005 Age: 50
Member: 178616 Status: Offline Thanks Meter: 90 | Rm-1133 contact service solution Just flash with ver 15.00.11 ur problem solved i solved today same case |
The Following User Says Thank You to gsmexpertgsmexp For This Useful Post: |
