09-16-2017, 10:22 | #2 (permalink) |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,053 | Done its cable problem. Code: Registered to: xerraco Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Device boot not done Check Drivers Try again Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 4 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 664E3A4289575018E67C0CB47DCAA8D9 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : LAGOS61D.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Lagos.fg DA_VERIFY : 00 DA_JUMP : 00100000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x00368000-0x003F7FFF , LEN : 0x00090000 Executing FFS FORMAT now... FAT_RANGE : 0x00368000-0x003F7FFF , LEN : 0x00090000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:24 Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 4 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 664E3A4289575018E67C0CB47DCAA8D9 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : LAGOS61D.10.01.11.p2 BROM/BL stage done Configure RAMINIT Ok Reading flash now ... Done! Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive :) Mobile Info IMEI : 353681081072027 BBUID : 664E3A4289575018E67C0CB47DCAA8D9 PCCode: 059X026 SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 353681081072027_MTKx.mtsec Read Done! Connect phone on selected interface... Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1134_ROM_eMP_13.00.11 VIVA : RM-1134_VIVA_eMP_13.00.11 LANG : RM-1134_LANG_PACK_ROM_ID_eMP_13.00.11_002 CUST : RM-1134_CUSTPACK_ROM_ID_MEA_ZA_eMP_13.00.11_002 JMPT : RM-1134_JUMP_TABLE_ID_MEA_ZA_eMP_13.00.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 4 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 664E3A4289575018E67C0CB47DCAA8D9 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : LAGOS61D.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Lagos.fg DA_VERIFY : 00 DA_JUMP : 00100000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x00368000-0x003F7FFF , LEN : 0x00090000 SecureDecrypt : RM-1134_ROM_eMP_13.00.11 SecureDecrypt : RM-1134_VIVA_eMP_13.00.11 SecureDecrypt : RM-1134_LANG_PACK_ROM_ID_eMP_13.00.11_002 SecureDecrypt : RM-1134_CUSTPACK_ROM_ID_MEA_ZA_eMP_13.00.11_002 SecureDecrypt : RM-1134_JUMP_TABLE_ID_MEA_ZA_eMP_13.00.11_002 OVRLP : 000069B900000001 PHPID : LAGOS61D.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1134_ROM_eMP_13.00.11 Write : RM-1134_LANG_PACK_ROM_ID_eMP_13.00.11_002 Write : RM-1134_CUSTPACK_ROM_ID_MEA_ZA_eMP_13.00.11_002 Write : RM-1134_JUMP_TABLE_ID_MEA_ZA_eMP_13.00.11_002 Write : RM-1134_VIVA_eMP_13.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1134_ROM_eMP_13.00.11 [VERIFY] DONE : RM-1134_LANG_PACK_ROM_ID_eMP_13.00.11_002 [VERIFY] DONE : RM-1134_CUSTPACK_ROM_ID_MEA_ZA_eMP_13.00.11_002 [VERIFY] DONE : RM-1134_JUMP_TABLE_ID_MEA_ZA_eMP_13.00.11_002 [VERIFY] DONE : RM-1134_VIVA_eMP_13.00.11 CODE_VERIFY : Ok FORMAT FFS : skipped Rebooting phone now Flashing done! Total flash time : 00:00:50 Reboot phone Ok |
The Following User Says Thank You to xerraco For This Useful Post: |
