Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 10-11-2019, 09:14   #1 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,801
nokia 105 spd SC6531EFM cpu ta 1174 not supported
hi
have device in hand
best 2 or 1 not see phone
tried cm2 also same issue
selected sp6531 same issue
but when i use UFST box
it see and read info
in same time when make read info by cm2 in service mode get this log
Chinese Miracle II [SPD module] v 1.27
Operation : Check/Read Info [ v1.27 ]
Normal
Normal , 1 : Power On phone. Insert USB cable ( Normal USB cable )
Service
Service , 1 : Insert USB cable ( Use adapter or special cable )
Service , 2 : Insert battery
Service , 3 : If boot not start - press 'Power' button shortly
==== Wait for phone...
Phone found! [ 579 ]
Port Opened
Sync...
Normal Mode init
Sync...
Phone Initial Info :
Platform : MOCOR_16A.KING_W19.27.4_Release
ExtInfo : 10.00.17.02
HWInfo : SC6531EFM_BAR
Compile : 05-07-2019 14:48:12
Phone Security Info :
IMEI [1] : 355752106391987
IMEI [2] : 355752108391985
BT_ADDR : 000000000000
any help
have 2 phone one with no issue
other with security code
Old 10-12-2019, 08:45   #3 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,801
any help team
waiting for reply
Old 10-12-2019, 10:51   #4 (permalink)
Member: 1087456
Thanks Meter: 39
Infinity-box CM2SCR
Nokia 105 spd SC6531EFM cpu ta 1174 supported
Old 10-12-2019, 14:22   #5 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,801
Originally Posted by mijanur_017 View Post
Infinity-box CM2SCR
u tried or tested
if yes show log
if not because i tested both cm2 spd and sc cm2 same issue
Old 10-13-2019, 18:58   #6 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,801
any help team
waiting for reply
Old 10-15-2019, 13:28   #7 (permalink)
saqib2009's Avatar
Member: 515406
Sonork: 100.1603457
Thanks Meter: 883
i think this is new chip spd use this exe for
http://forum.gsmhosting.com/vbb/f296.../#post13860935
Old 10-15-2019, 19:43   #8 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,801
same issue
Normal
Service
Phone found! [ 592 ]
Port Opened
Sync...
Normal Mode init
Sync...
Done
Reconnect Power/Cable!
Operation : Read FullFlash [ v1.27 ]
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
Port Opened
Sync...
Initial Boot Failed!
Boot not done, reason : Wrong BootKeys
Hint : Reset power and use ANOTHER BootKey ( VOL up or VOL down )
Operation : Read User Code [ v1.27 ]
3. Insert battery
Port Opened
Sync...
Operation : Read PhoneBook [ v1.27 ]
3. Insert battery
Port Opened
Sync...
Connect Powered Off phone. Insert battery ( If not used VPP )
Port Opened
Wait for phone ...
Device boot failed
Check Cable/Connection
Try again
Set mode to : SPD6531
Port Opened
Wait for phone ...
new sw
no detection
Old 10-15-2019, 19:57   #9 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,801
Normal
Service
Port Opened
Sync...
Normal Mode init
Sync...
Done
3. Insert battery
Port Opened
Sync...
3. Insert battery
Port Opened
Sync...
3. Insert battery
Port Opened
Sync...
Port Opened
Wait for phone ...
Device boot failed
Try again
Port Opened
Wait for phone ...
Old 10-16-2019, 07:30   #10 (permalink)
saqib2009's Avatar
Member: 515406
Sonork: 100.1603457
Thanks Meter: 883
download and try this exe
https://mega.nz/#!icFEjYYa!3m0JsL1oJ...Ck3pv8cUQp5hIk
spd scr 1.05 exe
Old 10-16-2019, 12:58   #11 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,801
i tried this before u post same issue
Old 10-16-2019, 19:44   #12 (permalink)
Member: 148515
Thanks Meter: 19,534
for your ref: BEST has special algorithms especially for nk models. People should understand that in most cases each brand has it's own tricks. Do you know that ?
In post #1 you say you can use other software for this unit.
If you really can - just use tool that do the job. What is the result with other tool ?
Old 10-16-2019, 19:58   #13 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,801
I trust best
u van check my video and report
what i meant by other tool is
but when i use ufst box
Old 10-16-2019, 19:59   #14 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,801
My point from ufst was to explain when cm2 can read phone
SINCE CM2 NOT BOOT OR READ PHONE
in which time
that is all
any advice for solution
Old 10-16-2019, 20:13   #15 (permalink)
Member: 148515
in which time
that is all
I did not understand well.
Do you mean you can make all functions well with other tool ?
Page generated in 0.24119 seconds with 8 queries
