11-26-2014, 16:53 | #20 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Cannot readout files from working phone I can't readout a working phone to makee Nokia 106 flash pack Here is the log: Code: card found: S/N 07xx:0xx8 registered to: debeliamark Connect phone on selected interface... UFS S/N xxxxx boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... SW ver : V 03.35 27-01-14 RM-962 (c) Nokia IMEI : 35235506775xxx1 PPM : V 03.35 27-01-14 RM-962 (c) Nokia EA PCode : 059T2F6 BPCode : 059V8V5 HWID : 2300 LCDVer : TPO:BARACOAv90 HX5081 IMEI : 352355067754111 Sl Conf : 001-01-00000000000 Sl Prof : 000000000004000-2 Sl Aux : 000B0000 Hw Sig : 724824CC930BFC45 Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Done! Processing XG110 Flash Read Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 Boot Ok , 01 Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader FlashIc Size : 0x00800000 Read Flash , Len : 0x00800000 Read done, collect initial info... SN : F9CA805BI PC : 059V8V5 IMEI : 35235506775xxx1 Pure size : 0x00800000 Save file to : Phones_Data\Readout\35235506775xxx1_XG110.bin Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Processing initial checking Product : RM-962 supported for FlashFile creation ===== FlashFile info : SMCU Version : 03.35 Product : RM-962 , Version : 03.35 , LangId : EA , ProductCode : 059V8V5 Languages inside PMM : English , French , Deutsch , Hungarian , Polish , Russian , Romanian , Bulgarian ==== Verifying flash content ... [ MCU ] : Validation FAILED, area NOT fit to region [ PPM ] : Validation FAILED, area NOT fit to region [ CNT ] : Validation FAILED, area NOT fit to region ==== Create FlashFiles : [MCU] : area is out of region, create skipped [PPM] : area is out of region, create skipped [CNT] : area is out of region, create skipped All done! |
11-26-2014, 17:12 | #21 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello, problem is in big block size of regions. If for CNT we can cut it to known signed areas - we can't do that for PPM and MCU. Loaders, which exists now for SPI Nokia on public have limited space and we can put in them smallest blocks, but not bigger, as in Nokia 106. Probably - soon few 106 factory files come out and it will be possible for Nokia 106 as well, but not sure - when it happens. |
The Following 3 Users Say Thank You to Dzirt For This Useful Post: |
12-08-2015, 13:47 | #24 (permalink) | |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 941 | Quote:
br | |
The Following User Says Thank You to Formingus For This Useful Post: |
12-13-2015, 17:01 | #25 (permalink) |
No Life Poster Join Date: Nov 2014 Location: (pakistan)(chichawatni) Age: 38
Member: 2293727 Status: Offline Sonork: 100.1660528 Thanks Meter: 451 | nokia 106 rm-962 flash with rm963 warking file |
The Following User Says Thank You to shabirahmad22 For This Useful Post: |
