07-27-2014, 07:17 | #16 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2229249 Status: Offline Thanks Meter: 0 | nokia 220 RM-969 nokia 220 RM-969 can not write flash ,,I try more phone and more driver still same,,,,,,, it show as below,, Connect phone on selected interface... Dead Mode is Selected card found: S/N xxxxxxx registered to: xxxxxxxx Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Device boot not done Check Drivers Try again Boot Error Flashing failed! Connect phone on selected interface... Last edited by hunterwcx; 07-27-2014 at 07:25. |
07-27-2014, 19:23 | #17 (permalink) |
No Life Poster Join Date: Sep 2005 Location: PAKISTAN Age: 39
Member: 181886 Status: Offline Sonork: 100.1579817 Thanks Meter: 1,007 | This is Bug in new version i think i have same problem but after use this version (InfinityBox_install_BEST_v1.92) All work fine Here Is LOG card found: S/N xxxxxxxx registered to: xxxxxxxxxxxxx Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Software Info: 10.01.11 00-00-00 RM-1011 IMEI: 3523530628xxxxx PPM version : IJ Product code: 059V5V2 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 142 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 5C0F57112817DE0530E61A05FFE0D501 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
The Following User Says Thank You to sajidali For This Useful Post: |
07-29-2014, 22:05 | #19 (permalink) | |
Freak Poster Join Date: Feb 2005 Location: Poland
Member: 112498 Status: Offline Thanks Meter: 33 | Quote:
... I tryed with several PCs and stil the same problem - phone can not boot in flash mode. Emilkawa | |
08-06-2014, 10:12 | #20 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Algeria
Member: 329483 Status: Offline Sonork: 100 Thanks Meter: 443 | Quote:
Code: Verify files ... MAUI : RM-944_ROM_eMP_22.00.11 VIVA : RM-944_VIVA_eMP_22.00.11 LANG : RM-944_LANG_PACK_ROM_IC_eMP_22.00.11 CUST : RM-944_CUSTPACK_ROM_IC_MEA_DZ_eMP_22.00.11 JMPT : RM-944_JUMP_TABLE_IC_MEA_DZ_eMP_22.00.11 - > MODE : FullFlash Software Info: 12.06.11 00-00-00 RM-944 IMEI: 352366062296420 PPM version : IC Product code: 059S7Q0 Rebooting phone to FlashMode... Wait for phone... Device boot not done Check Drivers Try again Boot Error Flashing failed! Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok | |
08-07-2014, 04:40 | #22 (permalink) | |
Insane Poster Join Date: Mar 2008
Member: 726263 Status: Offline Thanks Meter: 6 | mtk ver 1.94 work again work again tahnk best team Quote:
09-04-2014, 08:05 | #25 (permalink) |
Freak Poster Join Date: Nov 2006 Location: pkistan
Member: 395389 Status: Offline Sonork: no idi Thanks Meter: 193 | registered to: szktk Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 14 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 41BB2597E0CC6DEE5266C3FE42166C95 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Rivendell.10.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 Executing FFS FORMAT now... FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE |
The Following User Says Thank You to szktk For This Useful Post: |
09-15-2014, 17:27 | #26 (permalink) |
Freak Poster Join Date: Apr 2011 Location: pk
Member: 1565811 Status: Offline Sonork: 786 Thanks Meter: 8 | driver download?????? Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Device boot not done Check Drivers Try again Boot Error Flashing failed! Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok just install working driver and in 20mints flash ok Core : v1.92 , MTKx FlashEngine : v4.2 |
10-04-2014, 06:47 | #30 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Pakistan
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Working to me on nokia 225 Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 22 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : EF474FBA76D0C80D87F5B9235E4A4665 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : PEARL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 Executing FFS FORMAT now... FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Connect phone on selected interface... BR |
