10-04-2014, 08:00 | #31 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Simple formatting - not a way, if need just reset forgotten code. For reports exist thread : http://forum.gsmhosting.com/vbb/f641...-here-1088692/ |
10-12-2014, 15:11 | #32 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Nokia 225 user code done, working perfect- Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 64 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 2EC5112C6A4DB9F27AD8CDC8CF21169F BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... Br. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
10-19-2014, 13:01 | #33 (permalink) |
No Life Poster Join Date: Feb 2011 Location: ( United States Of Islam ) Age: 35
Member: 1519396 Status: Offline Sonork: 100.1612702 Thanks Meter: 1,951 | 225 UserCode solution Without Data Los don 225 UserCode solution Without Data Los don card found: S/N 4527:0118 registered to: Niaz Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 19 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 5EFD119C3FCC80E52973AD10C00993EF BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
The Following User Says Thank You to niaz muhammad For This Useful Post: |
11-02-2014, 09:05 | #34 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Nokia 225 Rm-1011 User Code Reset without less Data Code: Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 103 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 335550D0BA46F090548A5FF89A7FB501 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Wbr, AniAXN |
11-06-2014, 15:38 | #35 (permalink) |
Junior Member Join Date: Feb 2013 Location: varansi
Member: 1883835 Status: Offline Sonork: [email protected] Thanks Meter: 0 | plz help me nokia best bb5 tool ver 1.89 link |
11-06-2014, 15:48 | #36 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Latest is 1.98 , and it located on support area. Especially for blind : http://forum.gsmhosting.com/vbb/f641...-more-1870725/ |
The Following User Says Thank You to Dzirt For This Useful Post: |
01-05-2015, 09:09 | #38 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Nokia 108 cable schematic needed [QUOTE=Dzirt;10360294]It is working great. I recommend you throw your "108 cable" or rebuild it. I WANT TO REBUILD THAT CABLE GIVE ME TUTORIAL/SCHEMATIC THAXXXXXXXXXX |
01-05-2015, 14:06 | #39 (permalink) | |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote: Schematic inside BEST/DOC's folder. Just one thing need change - use phone original BATTERY instead of VCC from PC. And all will work. Or make BSI jumper via resistor, like old FBUS nokia cables. But I have no idea about resistor value, need take battery and measure. | |
02-16-2015, 14:36 | #40 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Nokia 215 from BEST v2.02 is Activated! Code: Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 52 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 92CF35B1EADB3D34498D76D363741F87 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
02-25-2015, 21:28 | #42 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: Ubá--Brazil Age: 34
Member: 194078 Status: Offline Sonork: no have Thanks Meter: 209 | after instal VolcanoBox_Nokia_MTK_Flash_Drivers working fine Quote:
02-26-2015, 05:46 | #43 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | @daroas , 2 little secrets : 1. It is very old drivers, which I made from normal mtk drivers. 2. They change nothing , because BEST not use them more, than 1 year. |
04-28-2015, 16:23 | #45 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Nokia 108 models and Nokia 220 models now, instead of 2 step procedure for user code reset, will just readout current User Code. Code: Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 52 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : EB7E4B7AF14CE0AD03C86F7B0A0F54D7 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Bree.20.06.11.p4 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 MT625x : Read User Code User Code : 88800011 Done! Connect phone on selected interface... |
