05-29-2014, 16:19 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Nokia 105, 108, 130, 215, 220, 225, 230 UserCode solution Without Data Lost! In new BEST update ( from v1.90 ) you can reset UserCode (Security code) to default 12345 just with one button. No format required , if you need preserve PhoneBook, Calls, Messages, Files in phone. HowTo : Press "Reset UserCode" button in MediaTek tab. Follow software instructions. After operation done - code will be default (12345). This feature not harm phone user data, user settings or any security part and fully safe. All MTKx Nokia phones are supported. |
The Following 29 Users Say Thank You to Dzirt For This Useful Post: |
05-30-2014, 04:06 | #3 (permalink) |
No Life Poster Join Date: Mar 2011 Location: Manila,Philippines
Member: 1536588 Status: Offline Sonork: 100.1613366 Thanks Meter: 480 | --- Insert USB cable now! --- Wait for phone... Phone found! [ 120 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 6B3D68C20784B8D4F82E4139D125575F BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Bree.11.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE |
05-30-2014, 04:10 | #4 (permalink) | |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
Here I explained about safe way, which not kill UserData. | |
The Following User Says Thank You to Dzirt For This Useful Post: |
06-06-2014, 05:35 | #5 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Seems as way not correct works on Nokia 225 (6260 series). It reset code only once from 2-3 try. But not made any harm. Just got a phone and will make it in near days |
The Following 2 Users Say Thank You to Dzirt For This Useful Post: |
06-06-2014, 21:52 | #6 (permalink) | |
No Life Poster Join Date: Feb 2006
Member: 237256 Status: Offline Thanks Meter: 91 | Quote:
You may need to re-check this on Nokia 108 because it is not working on this phone. I had to use another software for mtk 625a to run this phone to remove code after several attempts with best dongle software | |
The Following User Says Thank You to pastor good For This Useful Post: |
06-07-2014, 04:59 | #7 (permalink) | |
If you still sure - it "not working" - check success post/threads here. Them are enough to make sure on that. | |
06-10-2014, 13:48 | #9 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | http://forum.gsmhosting.com/vbb/sear...chid=161087719 Tag : Nokia 108 in that subforum - at least 100 success post you will find. |
06-10-2014, 14:45 | #10 (permalink) | |
Supported models MTK6260 : Code: RM-1011 - Nokia 225 DS RM-1012 - Nokia 225 SS RM-1043 - Nokia 225 DS Code: RM-944 - Nokia 108 DS RM-945 - Nokia 108 SS RM-969 - Nokia 220 DS RM-970 - Nokia 220 SS RM-971 - Nokia 220 SS | |
The Following 4 Users Say Thank You to Dzirt For This Useful Post: |
06-12-2014, 22:39 | #11 (permalink) | |
06-14-2014, 11:13 | #13 (permalink) |
Member: 237256 Status: Offline Thanks Meter: 91 | Dzirt, you need to look into the problem of this mtk chip phones properly, i presently have a china box that can do these phones very well but for the sake of others who may not be interested in china phones, this may be a serious problem to them. |
06-14-2014, 11:40 | #14 (permalink) | |
Without logs and explanations - I even not understand what wrong with your phone and e.t.c. Make other thread with explanation of problem or just use "working" boxes for them. All is simple. | |
07-19-2014, 14:03 | #15 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Gujjar AJK
Member: 207308 Status: Offline Thanks Meter: 471 | Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Device boot not done Check Drivers Try again Boot Error Flashing failed! Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok just install working driver and in 20mints flash ok Core : v1.92 , MTKx FlashEngine : v4.2 Verify files ... MAUI : RM-944_ROM_eMP_20.06.11 VIVA : RM-944_VIVA_eMP_20.06.11 LANG : RM-944_LANG_PACK_ROM_IC_eMP_20.06.11 CUST : RM-944_CUSTPACK_ROM_IC_MEA_SA_eMP_20.06.11 JMPT : RM-944_JUMP_TABLE_IC_MEA_SA_eMP_20.06.11 - > MODE : FullFlash Software Info: 11.01.11 00-00-00 RM-944 |
