06-18-2015, 08:21 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: City of Temples
Member: 729381 Status: Offline Thanks Meter: 248 | Nokia 108 ,how to fix ? Code: Core : v2.08 , MTKx FlashEngine : v7.5 Verify files ... MAUI : RM-944_ROM_eMP_20.06.11 VIVA : RM-944_VIVA_eMP_20.06.11 LANG : RM-944_LANG_PACK_ROM_IC_eMP_20.06.11 CUST : RM-944_CUSTPACK_ROM_IC_MEA_SA_eMP_20.06.11 JMPT : RM-944_JUMP_TABLE_IC_MEA_SA_eMP_20.06.11 - > MODE : FullFlash Repair Mode is On Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 86 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 22CA44713555474FEEDED76152C0B878 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL failed! (CMD not accepted, 0xAA) Check Power / Cable! BootLoader Init Failed (HW/Connection Error) Connect phone on selected interface... Boot Error Flashing failed! Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 86 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 22CA44713555474FEEDED76152C0B878 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL failed! (CMD not accepted, 0xAA) Check Power / Cable! BootLoader Init Failed (HW/Connection Error) Connect phone on selected interface... Connect phone on selected interface... |
