03-21-2014, 13:21 | #1 (permalink) |
No Life Poster Join Date: Jul 2011 Location: ۞_ KERALA__۞_INDIA
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | Nokia 114 XG213 Dead Fone Forensic Sucessfully Done.. Code: card found: S/N 000000000 registered to: TUSHAR Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : Verify Error :( -> Error answer from BootRom Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : Verify Error :( -> Error answer from BootRom Backup Certificates now... Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF EBL Loader : Custom Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL : Custom EBL sent Ok EBL : Quantum_Bootloader_10.56_M1S1 Boot done! Read CRT block... Read EEPROM block... SL3 Simlock found (XGOLD) ... WMDRM Key found ... CMLA Key found ... ===== USER CODE ===== Executing Code extraction... - > Phone Lock Code : 12345 ===== USER CODE ===== MMC password not found (not set) NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\355494053257669_XG213.rpl Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Executing Dump Read Check communication with phone.... Communication verify done... Preparing... Reboot.... -> If Phone start charge - just reinsert battery fast Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF EBL Loader : Custom EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL EBL : Custom EBL sent Ok EBL : Quantum_Bootloader_2.5_M1S1 Boot done! Reading Done! Saved to : 355494053257669_X213.bin ===== USER CODE ===== Executing Code extraction... - > Phone Lock Code : 12345 ===== USER CODE ===== MMC password not found (not set) ===== RPL DATA ===== Executing RPL Data extraction... SL3 Simlock found (XGOLD) ... WMDRM Key found ... CMLA Key found ... IMEI 1 : 355494053257669 IMEI 2 : 355494053257677 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\355494053257669_2nd_XG213.rpl Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Open file "C:\InfinityBox\BEST\Phones_Data\Readout\355494053257669_X213.bin" - Ok Prepare... Scan image... Disc found, Size: 27M Search... Miriel detect phonebook type now ... Data proceed ok... CSV file saved to C:\InfinityBox\BEST\Phones_Data\Readout\\355494053257669_X213.csv 1000 records are found :) S40 PhoneBook saved to : 355494053257669_X213.s4pb Done!!! Phone disconected! Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : Verify Error :( -> Error answer from BootRom Backup Certificates now... Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF EBL Loader : Custom Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL : Custom EBL sent Ok EBL : Quantum_Bootloader_10.56_M1S1 Boot done! Read CRT block... Read EEPROM block... SL3 Simlock found (XGOLD) ... WMDRM Key found ... CMLA Key found ... ===== USER CODE ===== Executing Code extraction... - > Phone Lock Code : 12345 ===== USER CODE ===== MMC password not found (not set) NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\355494053257669_2nd_XG213.rpl Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok BackUp UserData : [PhoneBook] Generation mode : [S40] === Cnt Server Info === Used : 529 records [1000] Free : 471 records [1000] Total : 1000 records === Cnt Server Info === Scanning FileSystem ... Setting mode #2 Read pure data ... Ok Miriel detect phonebook type now ... Data proceed ok... csv file save to C:\InfinityBox\BEST\RM-827 114_355494053257669.csv 1000 phonebook records are found! VCF Records saved to : BEST\Phones_Data\IMEI\ File saved to : C:\InfinityBox\BEST\RM-827 114_355494053257669.S4pb Read done ;) Done... Phone disconected! THANK YOU Dzirt |
The Following 2 Users Say Thank You to .::EXTREME::. For This Useful Post: |
