07-25-2013, 12:12 | #1 (permalink) |
Freak Poster Join Date: May 2009 Location: Vendas Novas, Portugal
Member: 1023337 Status: Offline Sonork: 100.1617970 Thanks Meter: 16 | nokia 1280 backup problem i have a problem, i want backup rpl but i canīt. here the log.. "Opening Connection... Device Location: 00000061 Connect Ok! Initializing Connection... JAF Firmware: 01.B4 Authentificate JAF BOX... TEA Authentication Completed... JAF S/N ODJAF000 boot - Ok Switch jaf to FBUS... FbusMode set Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... SW ver : V 04.20 07-05-10 RM-647 (c) Nokia IMEI : 354308047955553 PPM : V 04.20 07-05-10 RM-647 (c) Nokia EJ PCode : 0592227 BPCode : 0589577 HWID : 3001 LCDVer : WIN:SERI:90 NT7542 IMEI : 354308047955553 Sl Conf : 001-01-00000000000 Sl Prof : 000000000003000-2 Sl Aux : 000B0000 Hw Sig : EE13D8AF9043E53F Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Done! Backup Certificates now... -> Infineon XG110 : IMEI Backup Created Checking BUS... Switch jaf to FlashMode... FlashMode set Ok Booting phone... Switch jaf to FlashMode... FlashMode set Ok Booting phone... Switch jaf to FlashMode... FlashMode set Ok Booting phone... Switch jaf to FlashMode... FlashMode set Ok Booting phone... Switch jaf to FlashMode... FlashMode set Ok Booting phone... Switch jaf to FlashMode... FlashMode set Ok Booting phone... BOOT 1ST : 00 Error finding required loader... Switch jaf to FBUS... FbusMode set Ok Phone not found " then, after search in forum, i tried with jaf as a com port, but without success. give me another error.. "Phone found! Series 40 Device detected! read info... - Ok Backup Certificates now... Backup CRT308 data... -> Infineon XG110 : IMEI Backup Created Check communication with phone.... ADL not support backup mode, rpl reading impossible Elapsed: 00:00:01 Connect phone on selected interface... " any solution? br. |
07-25-2013, 12:32 | #3 (permalink) | |
Member: 1023337 Status: Offline Sonork: 100.1617970 Thanks Meter: 16 | Quote:
i tried with jaf com emulator. | |
07-25-2013, 12:45 | #5 (permalink) |
Member: 1023337 Status: Offline Sonork: 100.1617970 Thanks Meter: 16 | okay! i think that is cable problem, i use ufc v2. now i tried flash without backup and failed... "Connect phone on selected interface... port COM12 open OK Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core : v1.66 , BB5XG FlashEngine : v5.3 Selected FlashSettings : Files Set for Flashing : MCU : rm647_007.000 PPM : rm647_007.00ej CNT : rm6470_nai07.00ej Infineon flashing... Booting phone now.... Phone must be POWER OFF Insert Cable or Press PowerON Button! Boot failed, phone not found -> Try again few times, check cable -> Try start flashing and insert cable in box during boot Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok " |
