04-06-2017, 13:28 | #1 (permalink) |
Major Poster Join Date: Dec 2010
Member: 1467041 Status: Offline Thanks Meter: 7 | Nokia 130 RM-1133 in flashing: DA Run failed please help me I try flash with BEST and error: Verify files ... MAUI : RM-1133_ROM_eMP_11.00.11 VIVA : RM-1133_VIVA_eMP_11.00.11 LANG : RM-1133_LANG_PACK_ROM_MA_eMP_11.00.11_001 CUST : RM-1133_CUSTPACK_ROM_MA_APAC_PH_eMP_11.00.11_001 JMPT : RM-1133_JUMP_TABLE_MA_APAC_PH_eMP_11.00.11_001 - > MODE : FullFlash Repair Mode is On Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 200 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : D9C53BEB277AD92E0F94B1F30D9EE476 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : LAGOS61D.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Dubai.fg DA_VERIFY : AA DA_JUMP : AAAAAAAA DA_AUTH : Fail! DA Run failed! Connect phone on selected interface... Boot Error Flashing failed! Connect phone on selected interface... |
04-11-2017, 15:45 | #4 (permalink) |
Freak Poster Join Date: Sep 2006 Location: Poland
Member: 360641 Status: Offline Thanks Meter: 38 | Hello problem DA_VERIFY : AA DA_JUMP : AAAAAAAA DA_AUTH : Fail! DA Run failed! Connect phone on selected interface... Bypass - Best 2.18 ver Verify files ... MAUI : RM-1134_ROM_eMP_13.00.11 VIVA : RM-1134_VIVA_eMP_13.00.11 LANG : RM-1134_LANG_PACK_ROM_EA_eMP_13.00.11_002 CUST : RM-1134_CUSTPACK_ROM_EA_EURO_PL_eMP_13.00.11_002 JMPT : RM-1134_JUMP_TABLE_EA_EURO_PL_eMP_13.00.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 126 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 6F708C4AE09DA66F2A4562CF409E73EF BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : LAGOS61D.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Lagos.fg DA_VERIFY : 00 DA_JUMP : 00100000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x00368000-0x003F7FFF , LEN : 0x00090000 SecureDecrypt : RM-1134_ROM_eMP_13.00.11 SecureDecrypt : RM-1134_VIVA_eMP_13.00.11 SecureDecrypt : RM-1134_LANG_PACK_ROM_EA_eMP_13.00.11_002 SecureDecrypt : RM-1134_CUSTPACK_ROM_EA_EURO_PL_eMP_13.00.11_002 SecureDecrypt : RM-1134_JUMP_TABLE_EA_EURO_PL_eMP_13.00.11_002 OVRLP : 000069B900000001 PHPID : LAGOS61D.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1134_ROM_eMP_13.00.11 Write : RM-1134_LANG_PACK_ROM_EA_eMP_13.00.11_002 Write : RM-1134_CUSTPACK_ROM_EA_EURO_PL_eMP_13.00.11_002 Write : RM-1134_JUMP_TABLE_EA_EURO_PL_eMP_13.00.11_002 Write : RM-1134_VIVA_eMP_13.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1134_ROM_eMP_13.00.11 [VERIFY] DONE : RM-1134_LANG_PACK_ROM_EA_eMP_13.00.11_002 [VERIFY] DONE : RM-1134_CUSTPACK_ROM_EA_EURO_PL_eMP_13.00.11_002 [VERIFY] DONE : RM-1134_JUMP_TABLE_EA_EURO_PL_eMP_13.00.11_002 [VERIFY] DONE : RM-1134_VIVA_eMP_13.00.11 CODE_VERIFY : Ok FORMAT FFS : skipped Rebooting phone now Flashing done! Total flash time : 00:00:48 Reboot phone Ok |
04-11-2017, 15:50 | #5 (permalink) |
Freak Poster Join Date: Jun 2011 Location: iran,golestan
Member: 1601654 Status: Offline Thanks Meter: 16 | i have same problem in best v 2.27: Code: ------------------------------------------------------- Core : v2.27 , MTKx FlashEngine : v11.5 Verify files ... MAUI : RM-1133_ROM_eMP_13.00.11 VIVA : RM-1133_VIVA_eMP_13.00.11 LANG : RM-1133_LANG_PACK_ROM_IJ_eMP_13.00.11_002 CUST : RM-1133_CUSTPACK_ROM_IJ_MEA_IR_eMP_13.00.11_002 JMPT : RM-1133_JUMP_TABLE_IJ_MEA_IR_eMP_13.00.11_002 - > MODE : Language Change Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 17 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 35ED196907AF5479707C37A329BB170A BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : LAGOS61D.13.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Dubai.fg DA_VERIFY : AA DA_JUMP : AAAAAAAA DA_AUTH : Fail! DA Run failed! Connect phone on selected interface... Boot Error Flashing failed! Connect phone on selected interface... Core : v2.27 , MTKx FlashEngine : v11.5 Verify files ... LANG : RM-1133_LANG_PACK_ROM_IJ_eMP_13.00.11_002 CUST : RM-1133_CUSTPACK_ROM_IJ_MEA_IR_eMP_13.00.11_002 JMPT : RM-1133_JUMP_TABLE_IJ_MEA_IR_eMP_13.00.11_002 - > MODE : Language Change Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 17 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 35ED196907AF5479707C37A329BB170A BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : LAGOS61D.13.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Dubai.fg DA_VERIFY : AA DA_JUMP : AAAAAAAA DA_AUTH : Fail! DA Run failed! Connect phone on selected interface... Boot Error Flashing failed! Connect phone on selected interface... Core : v2.27 , MTKx FlashEngine : v11.5 Verify files ... LANG : RM-1133_LANG_PACK_ROM_IJ_eMP_13.00.11_002 CUST : RM-1133_CUSTPACK_ROM_IJ_MEA_IR_eMP_13.00.11_002 JMPT : RM-1133_JUMP_TABLE_IJ_MEA_IR_eMP_13.00.11_002 - > MODE : Language Change Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Device boot not done Check Drivers Try again Boot Error Flashing failed! Connect phone on selected interface... Core : v2.27 , MTKx FlashEngine : v11.5 Verify files ... MAUI : RM-1133_ROM_eMP_13.00.11 VIVA : RM-1133_VIVA_eMP_13.00.11 LANG : RM-1133_LANG_PACK_ROM_IJ_eMP_13.00.11_002 CUST : RM-1133_CUSTPACK_ROM_IJ_MEA_IR_eMP_13.00.11_002 JMPT : RM-1133_JUMP_TABLE_IJ_MEA_IR_eMP_13.00.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 17 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 35ED196907AF5479707C37A329BB170A BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : LAGOS61D.13.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Dubai.fg DA_VERIFY : AA DA_JUMP : AAAAAAAA DA_AUTH : Fail! DA Run failed! Connect phone on selected interface... Boot Error Flashing failed! Connect phone on selected interface... Core : v2.27 , MTKx FlashEngine : v11.5 Verify files ... MAUI : 97D97FFE_RM-1133_ROM_eMP_10.01.11 VIVA : 3965C75D_RM-1133_VIVA_eMP_10.01.11 LANG : D9E4981F_RM-1133_LANG_PACK_ROM_IJ_eMP_10.01.11_004 CUST : 38F55F96_RM-1133_CUSTPACK_ROM_IJ_MEA_IR_eMP_10.01.11_004 JMPT : 646D4527_RM-1133_JUMP_TABLE_IJ_MEA_IR_eMP_10.01.11_004 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 17 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 35ED196907AF5479707C37A329BB170A BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : LAGOS61D.13.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Dubai.fg DA_VERIFY : AA DA_JUMP : AAAAAAAA DA_AUTH : Fail! DA Run failed! Connect phone on selected interface... Boot Error Flashing failed! Connect phone on selected interface... |
The Following User Says Thank You to arian gsm For This Useful Post: |
