rprasanna03 | 09-30-2019 23:26 | tried different pc still same problem tried different pc still same problem Code:
Infinity-Box BEST Nokia [HMD] Module [NK2] v1.07
Open VPLfile : TA-1017_059Z1Z3_10.00.11.vpl
Description : TA-1017 IJ
DeviceType : TA-1017
ProductCode : 059Z1Z3
SoftwareVer : 10.00.11
Load Ok!
Operation : Write FirmWare [ v1.07 ]
Setting : UserData erase : False
1. Make sure device is powered off. Power off, if need. Wait 10 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : Nokia USB Serial Port (COM82)
MODE : NOKIA USB SERIAL
PORT : 82
BROM : Init BROM
BROM init passed!
CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001
BROM : SECCFG : 0x00000007
BROM : NOKIA USB SERIAL
BROM : 0x05 BL : 0x00
BROM : MEID : DB18EB9702F820C0B71FB5D97976009B
BROM : Run BootLoader ...
BOOT : Run BL ver. 01
BOOT : 0x05 BL : 0x01
BOOT : WD : 0005
BOOT : RTC : Setup ...
BOOT : RTC : 000E
BOOT : PRJ : KESA61A.11.02.11.p1
AGENT : Look for suitable BootChain in DA ...
AGENT : DEFAULT AUTO
AGENT : Found MT6261
AGENT : KESA61A.11.02.11.p1
BOOT : Sending 1st DA ...
BOOT : DA sent
BOOT : Transfer control to DA ...
DA : Agent : v03.02 on BBID : 0x8E
NOR: 00C2 : 0025 : 0037 : 0000
NOR: [MX] MX25U6435E
NOR:
TSIZE : 0x00800000 [ 8.00 MB ]
PSIZE : 0x00800000 [ 8.00 MB ]
STYPE : 0x00000000
FLOTP : DA_NOR_OTP_EXIST
STATUS : OK
BSTYLE : SF_FLASH_BOOT
Boot done!
Load FlashSet :
MROM : TA-1017_ROM_eMP_10.00.11
LANG : TA-1017_LANG_PACK_ROM_IJ_eMP_10.00.11_001
CUST : TA-1017_CUSTPACK_ROM_IJ_eMP_10.00.11_001
JUMP : TA-1017_JUMP_TABLE_IJ_eMP_10.00.11_001
VIVA : TA-1017_VIVA_eMP_10.00.11
Prepare FlashSet :
DCR : TA-1017_ROM_eMP_10.00.11
DCR : TA-1017_LANG_PACK_ROM_IJ_eMP_10.00.11_001
DCR : TA-1017_CUSTPACK_ROM_IJ_eMP_10.00.11_001
DCR : TA-1017_JUMP_TABLE_IJ_eMP_10.00.11_001
DCR : TA-1017_VIVA_eMP_10.00.11
Prepare Target
SDS : OK : 0x007F8000 : 0x00008000
Erase Target Flash
Erase done!
Write Target Flash
Write : TA-1017_ROM_eMP_10.00.11
Write : TA-1017_LANG_PACK_ROM_IJ_eMP_10.00.11_001
Write : TA-1017_CUSTPACK_ROM_IJ_eMP_10.00.11_001
Write : TA-1017_JUMP_TABLE_IJ_eMP_10.00.11_001
Write : TA-1017_VIVA_eMP_10.00.11
Flash_Write ERROR : DA_CBR_NOT_FOUND
Error : Flashing failed!
Make sure device HW is in normal condition, check battery and cable!
Reconnect Power/Cable!
Operation : Identify [ v1.07 ]
PORT : 82
BROM : Init BROM
BROM init passed!
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : KESA61A.10.00.11.p2
BOOT : BDDS : 20
BOOT : PSRM : Init
BOOT : PSRM : 0003
Boot done!
SWVer :
FLASH : 0000 : 0000 : 0000 : 0000
BBSN [RPL] :
BBSN [DEV] : DB18EB9702F820C0B71FB5D97976009B
-> Info : Device security area damaged!
-> Info : Write RPL backup, if it exists!
Done!
Elapsed: 00:00:37
PORT : 82
BROM : Init BROM
Error : Fail to init protocol!
Remove battery, cable. Check cable and connection. Repeat operation!
PORT : 82
BROM : Init BROM
BROM init passed!
BOOT : WD : 0005
BOOT : RTC : 000E
AGENT : KESA61A.10.00.11.p2
BOOT : 0x00000BB8 : DA SEND ERROR!
ERROR :
PORT : 82
BROM : Init BROM
BROM init passed!
BROM : BootLoader start Failed! Check device Battery and BSI line!
PORT : 82
BROM : Init BROM
BROM init passed!
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : DA sent
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
Load FlashSet :
Prepare FlashSet :
Prepare Target
Erase Target Flash
Erase done!
Write Target Flash
Operation : Reset Settings [ v1.07 ]
PORT : 82
BROM : Init BROM
PORT : 82
BROM : Init BROM
BROM init passed!
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : DA sent
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
FFS Info exists in MAUI : 0x00580000 : 0x00278000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:18
PORT : 82
BROM : Init BROM
BROM init passed!
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : DA sent
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
Load FlashSet :
Prepare FlashSet :
Prepare Target
Erase Target Flash
Erase done!
Write Target Flash
Reconnect Power/Cable! |
