01-30-2018, 11:14 | #1 (permalink) |
No Life Poster Join Date: Mar 2016 Location: Ukraine
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Nokia 130 [TA-1017] Format Settings Error Identify Code: Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 10.00.11 00-00-00 TA-1017 IMEI 1 : 357281082692281 IMEI 2 : 357281082692299 XappVer : 000008F2 Ape Ver : NEMO G 4122fe8d/1 (00000000+0) T Thu Dec 29 01:31:09 2016 U d61db836 PPM : EI CNT : KESA61A.10.00.11.p2 Product SN : 1544B5FBU Product code : 059Z2P2 Base Prd.code: 059X9S7 Module code : 0207222 Hardware info======= HWID : 1000 LCDVer: TPO Lock info =========== IMEI : 357281082692281 IMEI spNet : 3A 75 82 01 28 96 22 18 Conf key : 800000000004000B Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; SimLock status : Ok Security status : Ok Done! Code: Software Info: 10.00.11 00-00-00 TA-1017 IMEI: 357281082692281 PPM version : EI Product code: 059Z2P2 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 71 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 4D5D3BB76E796485FF2627F0EF19B4DD BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : KESA61A.10.00.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Dubai.fg DA_VERIFY : AA DA_JUMP : AAAAAAAA DA_AUTH : Fail! DA Run failed! Connect phone on selected interface... |
01-30-2018, 12:18 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Reset User Code from SW. Then, if need - format from device settings. That is most safe and secure way. |
