08-09-2020, 17:38 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Srilanka
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | TA-1032 Dead After flash. Infinity-Box BEST Nokia [HMD] Module [NK2] v1.19 Load : H:\Nokia\Nokia 3\NE1-5220-0-00WW-B02\NE1-5220-0-00WW-B02.nb0 Load Ok! Operation : Write FW [ v1.19 ] Setting : UserData preserve : False Setting : Flash Pre-Erase : True Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM45) MODE : PRELOADER PORT PORT : 45 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : BEST_Nokia_DA_v19_1711_06 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 90014A484147346132A51C81A464197B DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A484147346132A51C81A464847B EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A53CCDAB1C328884B6F7AD789F2A1C0F STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! DL_INFO : PMT present SEC_DL : False (CUST) SEC_ID : 0x67887C7972766E6888787678777B796E [FL] : HW verification passed! Erase : 0x0000000001C80000 : 0x0000000005680000 Erase : 0x0000000009B20000 : 0x000000017D4E0000 PMT Update : Skip Flashing now ... PROCESS : PRELOADER Unpack : NE1-0-5220-00WW-preloader_NE1.bin Flash : NE1-0-5220-00WW-preloader_NE1.bin Update bootloader code ... Update bootloader Ok! PROCESS : LK Unpack : NE1-0-5220-00WW-lk.img Flash : NE1-0-5220-00WW-lk.img PROCESS : BOOT Unpack : NE1-0-5220-00WW-boot.img Flash : NE1-0-5220-00WW-boot.img PROCESS : RECOVERY Unpack : NE1-0-5220-00WW-recovery.img Flash : NE1-0-5220-00WW-recovery.img PROCESS : LOGO Unpack : NE1-0-5220-logo.bin Flash : NE1-0-5220-logo.bin PROCESS : SECRO Unpack : NE1-0-5220-secro.img Flash : NE1-0-5220-secro.img PROCESS : TEE1 Unpack : NE1-0-5220-tee.img Flash : NE1-0-5220-tee.img PROCESS : TEE2 Unpack : NE1-0-5220-tee.img Flash : NE1-0-5220-tee.img PROCESS : SYS_INFO Unpack : fver Flash : fver PROCESS : SUTINFO Unpack : NE1-00WW-001-sutinfo.img Flash : NE1-00WW-001-sutinfo.img PROCESS : SYSTEM Unpack : NE1-0-5220-00WW-system.img Flash : NE1-0-5220-00WW-system.img PROCESS : CACHE Unpack : NE1-0-5220-00WW-cache.img Flash : NE1-0-5220-00WW-cache.img PROCESS : USERDATA Unpack : NE1-0-5220-00WW-userdata.img Flash : NE1-0-5220-00WW-userdata.img PMT Update : Skip SEC_DL : False (CUST) SEC_ID : 0x03041013EE0E00F800F21212EF110DFC Flashing finished! Done! Elapsed: 00:03:54 How to recover this set. Tx |
08-10-2020, 18:55 | #3 (permalink) |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | With infor Operation : Identify [ v1.19 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM16) MODE : PRELOADER PORT PORT : 16 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : BEST_Nokia_DA_v19_1711_06 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 90014A484147346132A51C81A464197B DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A484147346132A51C81A464847B EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A53CCDAB1C328884B6F7AD789F2A1C0F STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! --- SysInfoSub [PART A]: Patch Level : O00623 Display ID : 00WW_3_38B Ver. CodeName : REL Ver. Release : 8.0.0 Sec. Patch : 2018-08-05 Build Time : 1534420079 Product Model : NE1 Product Brand : alps Product Name : NE1_00WW_FIH Product Device : NE1 Product Manfct : alps Product Info : NE1 Board Platform : mt6737m --- SecuritySub : IMEI[0] : 353392091813224 IMEI[1] : 353392091893226 NVRAM check : Passed! Backup sensetive data [ 11 ] Backup path : Backup\MT6735__A53CCDAB1C328884B6F7AD789F2A1C0F\ [20] Read : SUTINFO [22] Read : CDA [2] Read : PROINFO [3] Read : NVRAM Backup done! Done! Elapsed: 00:00:49 How to identify the carrect firmware.because flash file ver is 8.0 .but in the support there is no TA_1032 8.0 file. Also it is in the diffrent file name. Could you please advice me. I did the mistake that Setting : Flash Pre-Erase : True Now any way bro to bring this set. Thanks |
08-16-2020, 19:04 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | NE1-5220-0-00WW-B02 is Android 9 firmware. Flash erasing have nothing to do, since BEST has been tuned up to work with Nokia devices. Does device can enter in preloader mode without holding volume keys? |
