03-12-2012, 11:46 | #1 (permalink) |
No Life Poster Join Date: Sep 2008
Member: 870664 Status: Offline Sonork: 100.1614707 Thanks Meter: 56 | nokia 201 rm-799 CAN'Tdecrypte for LBF Series 60 Device detected! read info... - Ok Phone Imei: 358260041462472 Checking locks... Conf key : 8181000802000000 Provider key : 0018000001FFFFFF Provider : Unknown Provider Counters : Key 0 [3] , Fbus 0 [10] Blocks : 0 ============================= LOCKS : Damaged! ============================= PA_SL3 (15 digit) phone detected... - > Power Off phone, dissconnect it and connect Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : Verify Error Try again... -> Error answer from BootRom Fetching failed! Connect phone on selected interface... UFSx error, reconnect and try again... Error...! NOT: SECURITY IS NOT DAMAGED |
03-12-2012, 12:53 | #2 (permalink) |
Member: 870664 Status: Offline Sonork: 100.1614707 Thanks Meter: 56 | problem solved by editing setting.ini Phone found! Series 40 Device detected! read info... - Ok Phone Imei: 358260041462472 Checking locks... Sl Conf : 208-10-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : 5592A827BE229D33 Provider : SFR;France Lock info: Block 1 L1:Close; Block 2 L1:Close; Check communication with phone.... Communication verify done... Preparing... Reboot.... Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : SGOLD 213 2nd : Custom 2nd boot Ok, 01 2nd ready, AA Sending Algo ALG : Custom Algo sent Ok BL : Quantum_Bootloader_2.5_M1S1 Boot done! Create Log file for local calculation... File C:\InfinityBox\BEST\Local_calc\358260041462472.bcl created - Ok File C:\InfinityBox\BEST\Local_calc\ighashgpu_358260041 462472.bat created - Ok File C:\InfinityBox\BEST\Local_calc\oclHashcat_35826004 1462472.bat created - Ok Done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following User Says Thank You to amar22 For This Useful Post: |
04-03-2012, 06:44 | #4 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | for some reason when trying to unlock this model, if using the option Upload job from phone, the process would not upload it to the server. Had to upload it manually. Using version 1.42. |
04-03-2012, 15:49 | #6 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | Here it is mate... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Link to my account: http://user.infinity-best.com:82/ Login: ************* Password: ******** Connecting to server... user: ********* credit: *** jobs in progress: 0 jobs done: 34 Check client version... Compatible: 1.41.0. or higer... Upload Job procedure started... Phone Imei: 358260043297926 Checking locks... Sl Conf : 272-11-00115105064 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : 373B0C5569B5D84B Provider : Unknown providers Lock info: Block 1 L1:Close; Block 2 L1:Close; L2:Close; Check communication with phone.... Communication verify done... Preparing... Reboot.... Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : SGOLD 213 2nd : Custom 2nd boot Ok, 01 2nd ready, AA Sending Algo ALG : Custom Algo sent Ok BL : Quantum_Bootloader_2.5_M1S1 Boot done! Create Log file for local calculation... File c:\InfinityBox\BEST\Local_calc\358260043297926.bcl created - Ok File c:\InfinityBox\BEST\Local_calc\ighashgpu_358260043 297926.bat created - Ok File c:\InfinityBox\BEST\Local_calc\oclHashcat_35826004 3297926.bat created - Ok Done! Tried several times and at the end had to upload it manually. |
01-24-2013, 00:35 | #7 (permalink) |
Junior Member Join Date: Jun 2011
Member: 1605677 Status: Offline Thanks Meter: 0 | help to unlock nokia 201 with best tools. Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 201 Software ver : V 11.56 26-03-12 RM-799 (c) Nokia IMEI : 353276051418456 PPM : V 11.56 26-03-12 RM-799 (c) Nokia C1 CNT : Content: meteor IE SL V 11.56 26-03-12 RM-799 (c) Nokia Product SN : 3C41F85BI Product code : 059N5M2 Base Prd.code: 059J2K2 Module code : 0205022 Long Prod.SN : 0 Hardware info======= HWID : 2205 Batery: 3952 mV CMT BT: 19e2-47026 LCDVer: TPO Lock info =========== IMEI : 353276051418456 IMEI spNet : 3A 35 72 06 15 14 48 05 IMEI svNet : 33 35 72 06 15 14 48 05 F4 Sl Conf : 272-03-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : C8E76792BFD4D8DC Country : Ireland Operator : METEOR Lock info: Block 1 L1:Close; CRT308 Backup Created INFINEON : SuperDongle not exist (It is Ok) CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! please help me my unlock button not highlight???? as you can see on attachment |
01-24-2013, 02:47 | #8 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: U.S.A.
Member: 893209 Status: Offline Thanks Meter: 274 | @shusen Quote:
That UNIT is not SL1 or SL2 you can UNLOCK INFINEON PHONE via LBF,,, Br,. Rhyan | |
