09-19-2016, 07:15 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: pakistan
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | nokia 205 rm-862 "error collect lock info, try again" help Code: Card found: S/N : 32E7998B , v0122 Registered to: gsm city Connect phone on selected interface... Core : v2.23 , BB5XG FlashEngine : v10.1 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm862__03.18.mcusw PPM : rm862__03.18.ppm_ma3 CNT : rm862__03.18.image_ma3_059Q046 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.55_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm862__03.18.mcusw Image : rm862__03.18.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:04 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x017C0000 Erasing, wait ... Erase done, time : 00:01:55 Write , Start : 0x40280000 , Len : 0x017C0000 Flashing , wait ... Region flash done, time : 00:00:32 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x107F ===Flashing [PPM]=== File : rm862__03.18.ppm_ma3 Image : package_ma3.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A40000 , Len : 0x00640000 Erasing, wait ... Erase done, time : 00:00:19 Write , Start : 0x41A40000 , Len : 0x003EF9A4 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xEC56 ===Flashing [CNT]=== File : rm862__03.18.image_ma3_059Q046 Image : package_ma3_059Q046.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42080000 , Len : 0x01DA0000 Erasing, wait ... Erase done, time : 00:03:51 Write , Start : 0x42080000 , Len : 0x00FC0000 Flashing , wait ... Region flash done, time : 00:00:24 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:07 No write data, skip CRC check passed , 0x1FE7 Flashing done! Total flash time : 00:07:22 Reboot phone now... Reading Phone Info.... Connected phone - 205 Software Info: V 03.18 02-12-12 RM-862 (c) Nokia IMEI: 355903053920423 PPM version : V 03.18 02-12-12 RM-862 (c) Nokia MA3 Product code: 059Q048 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 42 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:08:16 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - 205 Software ver : V 03.18 02-12-12 RM-862 (c) Nokia IMEI 1 : 355903053920423 IMEI 2 : 355903053920431 XappVer : 000008B6 PPM : V 03.18 02-12-12 RM-862 (c) Nokia MA3 CNT : Content: ma3_059Q046 V 03.18 02-12-12 RM-862 (c) Nokia Product SN : 96EEA82BI Product code : 059Q048 Base Prd.code: 059N267 Module code : 0205222 Long Prod.SN : 0 Hardware info======= HWID : 3050 Battery: 5034 mV CMT BT: 19b5-22012 LCDVer: TPO Lock info =========== IMEI : 355903053920423 IMEI spNet : 3A 55 09 03 35 29 40 02 IMEI svNet : 33 55 09 03 35 29 40 02 F5 Sl Conf : 001-01-00000000000 Sl Prof : 800000000004000-B Sl Aux : 000B0000 Hw Sig : 8D609780E329A718 Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Error collect lock info, try again CRT308 Backup Created CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL30 (20 digit) phone detected... User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Checking StartUp data ... ----------------------- CMLA Key status : CMLA key is Ok SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL30 (20 digit) phone detected... Done! |
