03-25-2014, 10:54 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: IN {HUMEN}WORLD
Member: 510445 Status: Offline Sonork: 100.1638301 Thanks Meter: 353 | nokia 205 rm-921 nokia hange and white solved i selected 4 files here is logs Connect phone on selected interface... Core : v1.85 , BB5XG FlashEngine : v9.8 Selected FlashSettings : Manual File [Ok] : rm921_11.1.1.mcusw.fpsx File [Ok] : rm921_11.1.1_059S603_m4.rofs.fpsx File [Ok] : rm921_11.1.1_059S603_m4.image.fpsx File [Ok] : rm921_11.1.1_059S603_m4_SD_4GB.fpsimage.fpsx Dead Mode is Selected Waiting for USB device... If PC not detect phone - Insert Cable first, then Insert battery If stuck on boot - remove MicroSD card from phone! --- Press phone's power button or insert cable & charger! --- 1st Boot Done, processing booting now ASIC ID_F : 00000C2016100040C98224098A9CA9124C33DED5 ASIC ID_E : 00000C2016100040 PUBLIC ID : 61FA83FFE56EFEF2C98224098A9CA9124C33DED5 XGCHIP ID : 61FA83FFE56EFEF2 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok IMEI [1] : 358149052179861 IMEI [2] : 358149052179879 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\358149052179861_2n d_XG223_CRT.rpl PAPUBkeys : 7EC22006F565793C24924878FBAB9CA6CBE42C35 ID : 6 , Product : RM-921 , SWver : 11.1.1 , ProductCode : 059V3Z4 , Region : m1_2032 === PPM_ID Check === - > PPM_ID LOWER, THAN IN PHONE!!! - > Find other ID version and try again! - > Stop killing phone, break flashing! === PPM_ID Check === Error During flashing Connect phone on selected interface... Core : v1.85 , BB5XG FlashEngine : v9.8 Selected FlashSettings : Manual File [Ok] : 1D50CD68_rm921_11.1.1.mcusw.fpsx File [Ok] : 374F11A9_rm921_11.1.1_059S4B4_m1_2032_01_323642.ro fs.fpsx File [Ok] : 018847CE_rm921_11.1.1_059S4B4_m1_2032_01_323642.im age.fpsx File [Ok] : E673D488_rm921_11.1.1_059S4B4_m1_SD_4GB_2032_01_32 3642.fpsimage.fpsx Dead Mode is Selected Waiting for USB device... If PC not detect phone - Insert Cable first, then Insert battery If stuck on boot - remove MicroSD card from phone! --- Press phone's power button or insert cable & charger! --- 1st Boot Done, processing booting now ASIC ID_F : 00000C2016100040C98224098A9CA9124C33DED5 ASIC ID_E : 00000C2016100040 PUBLIC ID : 61FA83FFE56EFEF2C98224098A9CA9124C33DED5 XGCHIP ID : 61FA83FFE56EFEF2 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok IMEI [1] : 358149052179861 IMEI [2] : 358149052179879 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\358149052179861_2n d_XG223_CRT.rpl PAPUBkeys : 7EC22006F565793C24924878FBAB9CA6CBE42C35 === SW Version Check === - > REFLASHING === SW Version Check === === Flashing MCU === Processing file : 1D50CD68_rm921_11.1.1.mcusw.fpsx Erasing... Writing... Total blocks : 81 Writing RKH CRT [ISSW] Writing RKH CRT [MEMSET] Writing RKH CRT [PRIMAPP] Writing RKH CRT [LOADER] Writing RKH CRT [PASUBTOC] Writing RKH CRT [PAPUBKEYS] [PAKeys : 7EC22006F565793C24924878FBAB9CA6CBE42C35] Writing RKH CRT [UPDAPP] Writing RKH CRT [MCUSW] File processed Ok, 80 blocks were writen === Flashing PPM === Processing file : 374F11A9_rm921_11.1.1_059S4B4_m1_2032_01_323642.ro fs.fpsx Erasing... Writing... Total blocks : 12 Writing RKH CRT [PPM] File processed Ok, 12 blocks were writen === Flashing CNT === Processing file : 018847CE_rm921_11.1.1_059S4B4_m1_2032_01_323642.im age.fpsx Erasing... Writing... Total blocks : 54 File processed Ok, 54 blocks were writen === Flashing MMC === Processing file : E673D488_rm921_11.1.1_059S4B4_m1_SD_4GB_2032_01_32 3642.fpsimage.fpsx Erasing... Writing... Total blocks : 125 Write data block error : 82126B00 Write data block failed at 5 Error During flashing [-1] Flashing done , total time : 00:00:49 Reboot phone to service mode... |
03-25-2014, 10:58 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. Remove from list file : MMC : E673D488_rm921_11.1.1_059S4B4_m1_SD_4GB_2032_01_32 3642.fpsimage.fpsx Because you flash Memory Card content WITHOUT memory card!!! |
03-25-2014, 11:13 | #3 (permalink) |
Member: 510445 Status: Offline Sonork: 100.1638301 Thanks Meter: 353 | i removed this MMC : E673D488_rm921_11.1.1_059S4B4_m1_SD_4GB_2032_01_32 3642.fpsimage.fpsx but same and phone not go to local mode any solution here is logs without 4emm files Connect phone on selected interface... Core : v1.85 , BB5XG FlashEngine : v9.8 Selected FlashSettings : Manual File [Ok] : rm921_11.1.1.mcusw.fpsx File [Ok] : rm921_11.1.1_059S601_m2.rofs.fpsx File [Ok] : rm921_11.1.1_059S601_m2.image.fpsx Dead Mode is Selected Waiting for USB device... If PC not detect phone - Insert Cable first, then Insert battery If stuck on boot - remove MicroSD card from phone! --- Press phone's power button or insert cable & charger! --- 1st Boot Done, processing booting now ASIC ID_F : 00000C2016100040C98224098A9CA9124C33DED5 ASIC ID_E : 00000C2016100040 PUBLIC ID : 61FA83FFE56EFEF2C98224098A9CA9124C33DED5 XGCHIP ID : 61FA83FFE56EFEF2 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok IMEI [1] : 358149052179861 IMEI [2] : 358149052179879 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\358149052179861_XG 223_CRT.rpl PAPUBkeys : 7EC22006F565793C24924878FBAB9CA6CBE42C35 === SW Version Check === - > REFLASHING === SW Version Check === === Flashing MCU === Processing file : rm921_11.1.1.mcusw.fpsx Erasing... Writing... Total blocks : 81 Writing RKH CRT [ISSW] Writing RKH CRT [MEMSET] Writing RKH CRT [PRIMAPP] Writing RKH CRT [LOADER] Writing RKH CRT [PASUBTOC] Writing RKH CRT [PAPUBKEYS] [PAKeys : 7EC22006F565793C24924878FBAB9CA6CBE42C35] Writing RKH CRT [UPDAPP] Writing RKH CRT [MCUSW] File processed Ok, 80 blocks were writen === Flashing PPM === Processing file : rm921_11.1.1_059S601_m2.rofs.fpsx Erasing... Writing... Total blocks : 15 Writing RKH CRT [PPM] File processed Ok, 15 blocks were writen === Flashing CNT === Processing file : rm921_11.1.1_059S601_m2.image.fpsx Erasing... Writing... Total blocks : 48 File processed Ok, 48 blocks were writen Flashing done , total time : 00:00:49 Reboot phone to service mode... |
03-25-2014, 11:39 | #4 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | It showns Nokia or White LCD and then goes off? Phone original was: ID : 6 , Product : RM-921 , SWver : 11.1.1 , ProductCode : 059V3Z4 , Region : m1_2032 Which ID you flash inside? Make Read RPL now and show log. |
03-25-2014, 11:40 | #5 (permalink) |
Member: 510445 Status: Offline Sonork: 100.1638301 Thanks Meter: 353 | best team plz edit my post i posted 205 sorry model is nokia 502 rm-921 correct this model plz and tell me how to solved this problem |
03-25-2014, 11:41 | #6 (permalink) |
Member: 510445 Status: Offline Sonork: 100.1638301 Thanks Meter: 353 | yes its show white lcd and goes off here is rpl read logs Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : Verify Error -> Error answer from BootRom Detected XGOLD 223 platform , switching Remove MicroSD card, if face any boot problem ASIC ID_F : 00000C2016100040C98224098A9CA9124C33DED5 ASIC ID_E : 00000C2016100040 PUBLIC ID : 61FA83FFE56EFEF2C98224098A9CA9124C33DED5 XGCHIP ID : 61FA83FFE56EFEF2 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok ID : 6 , Product : RM-921 , SWver : 11.1.1 , ProductCode : 059V3Z4 , Region : m1_2032 IMEI [1] : 358149052179861 IMEI [2] : 358149052179879 Reboot phone to service mode... |
03-25-2014, 12:28 | #8 (permalink) |
Member: 510445 Status: Offline Sonork: 100.1638301 Thanks Meter: 353 | thanks finally i solved with original product number Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : Verify Error -> Error answer from BootRom Detected XGOLD 223 platform , switching Remove MicroSD card, if face any boot problem ASIC ID_F : 00000C2016100040C98224098A9CA9124C33DED5 ASIC ID_E : 00000C2016100040 PUBLIC ID : 61FA83FFE56EFEF2C98224098A9CA9124C33DED5 XGCHIP ID : 61FA83FFE56EFEF2 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok ID : 6 , Product : RM-921 , SWver : 11.1.1 , ProductCode : 059V3Z4 , Region : m1_2032 IMEI [1] : 358149052179861 IMEI [2] : 358149052179879 Reboot phone to service mode... - > BootUp in service mode Failed! Connect phone on selected interface... Error init service mode, flex part can not be readed Connect phone on selected interface... Core : v1.85 , BB5XG FlashEngine : v9.8 Selected FlashSettings : Manual File [Ok] : rm921_11.1.1.mcusw.fpsx File [Ok] : rm921_11.1.1_059S601_m2.rofs.fpsx File [Ok] : rm921_11.1.1_059S601_m2.image.fpsx Dead Mode is Selected Waiting for USB device... If PC not detect phone - Insert Cable first, then Insert battery If stuck on boot - remove MicroSD card from phone! --- Press phone's power button or insert cable & charger! --- 1st Boot Done, processing booting now ASIC ID_F : 00000C2016100040C98224098A9CA9124C33DED5 ASIC ID_E : 00000C2016100040 PUBLIC ID : 61FA83FFE56EFEF2C98224098A9CA9124C33DED5 XGCHIP ID : 61FA83FFE56EFEF2 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok IMEI [1] : 358149052179861 IMEI [2] : 358149052179879 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\358149052179861_2n d_XG223_CRT.rpl PAPUBkeys : 7EC22006F565793C24924878FBAB9CA6CBE42C35 === SW Version Check === === SW Version Check === - > REFLASHING === SW Version Check === === Flashing MCU === Processing file : rm921_11.1.1.mcusw.fpsx Erasing... Writing... Total blocks : 81 Writing RKH CRT [ISSW] Writing RKH CRT [MEMSET] Writing RKH CRT [PRIMAPP] Writing RKH CRT [LOADER] Writing RKH CRT [PASUBTOC] Writing RKH CRT [PAPUBKEYS] [PAKeys : 7EC22006F565793C24924878FBAB9CA6CBE42C35] Writing RKH CRT [UPDAPP] Writing RKH CRT [MCUSW] File processed Ok, 80 blocks were writen === Flashing PPM === Processing file : rm921_11.1.1_059S601_m2.rofs.fpsx Erasing... Writing... Total blocks : 15 Writing RKH CRT [PPM] File processed Ok, 15 blocks were writen === Flashing CNT === Processing file : rm921_11.1.1_059S601_m2.image.fpsx Erasing... Writing... Total blocks : 48 File processed Ok, 48 blocks were writen Flashing done , total time : 00:00:49 Reboot phone to service mode... Reading Phone Info.... Connected phone - 502 Software Info: V 11.1.1 23-10-13 RM-921 (c) Nokia IMEI: 358149052179861 PPM version : 4e5a15fde5ee49db7b9e93413d482f18a7832b04 Product code: 059S601 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 61 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Connect phone on selected interface... |
03-25-2014, 12:39 | #9 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Sure, because it ID is :12 , not 6, as you try. Next time check that : http://forum.gsmhosting.com/vbb/f641...tcode-1774101/ |
The Following User Says Thank You to Dzirt For This Useful Post: |
