09-02-2013, 11:25 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: India
Member: 1086393 Status: Offline Thanks Meter: 771 | nokia 206 after update to V 04.51- IMEI missing I try to update my nokia 206, After update it to version 04.51, IMEI missing and it shows Contact service. I update it because in new update, the phone support WhatsApp application. Need help! Code: Core : v1.69 , BB5XG FlashEngine : v5.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm873__04.51.mcusw PPM : rm873__04.51.ppm_m1 CNT : rm873__04.51.image_m1_059Q4F7 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Backup enabled, will read all certificates Error while read certificates, trying to skip ===Flashing [MCU]=== File : rm873__04.51.mcusw Image : rm873__04.51.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:02:14 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:35 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip ===Flashing [PPM]=== File : rm873__04.51.ppm_m1 Image : package_m1.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00680000 Erasing, wait ... Erase done, time : 00:00:29 Write , Start : 0x41A80000 , Len : 0x0049148C Flashing , wait ... Region flash done, time : 00:00:05 ===Flashing [CNT]=== File : rm873__04.51.image_m1_059Q4F7 Image : package_m1_059Q4F7.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:03:59 Write , Start : 0x42100000 , Len : 0x01080000 Flashing , wait ... Region flash done, time : 00:00:23 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:08 No write data, skip Flashing done! Total flash time : 00:08:04 Reboot phone now... Reading Phone Info.... Connected phone - 206 Software Info: V 04.51 31-05-13 RM-873 (c) Nokia IMEI: 12345610654321? PPM version : V 04.51 31-05-13 RM-873 (c) Nokia M1 Product code: 059R9M3 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security Damaged!!!!! :( Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Resetting LifeTimer Reset Done! Checking User Certificates... Total - 58 certs Data exist, skip certificate repair... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:09:50 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
09-02-2013, 11:32 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | As I can see - you flashed wrong RM-xxx. Flash back original RM-xxx, and phone will be ok. |
The Following 2 Users Say Thank You to Dzirt For This Useful Post: |
