nokia 206 help i need cable pin out nokia 206 rm-872 any one have schematic |
Nokia 206 Thanks man nice work |
rashel.ahamma nokia 206 i neid flash pinout plez help:rolleyes: |
done good working ATF Number of Image Files: 3 Processing Image File : rm872__03.58.mcusw Processing Image File : rm872__03.58.ppm_m4 Processing Image File : rm872__03.58.image_m4_059Q4L3 []: Found 1 active devices. [Nokia X2-02 USB Phonet]: Opening Connection [Nokia X2-02 USB Phonet]: Port opened OK! SW: V 03.58 05-12-12 RM-872 (c) Nokia IMEI: 355922051571400 START FULL PM BACKUP Please Wait... Reading : PM 0~400... OK! FULL PM Backup Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355922051571400\USB_FULL_BACK UP_V 03.58 05-12-12 RM-872 (c) Nokia_355922051571400__75159.pm Reading Battery Value : 5092 mV Rebooting Phone... AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Unique Data: 12200C02A116281B Original Product Code: 059Q8K7 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355922051571400\3559220515714 00_75211.rpl Certificate Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355922051571400\3559220515714 00_CERTIFICATE_9DC93620.bin PM Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355922051571400\3559220515714 00_PMM_PROT_89117E3C.bin Security Code: 12345 Data Sections : 04 Current File : rm872__03.58.mcusw Compile Name: rm872__03.58.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 26480008 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: AFC6 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7A66 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: 5169 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 FIRMWARE Erase Block: 0x40280000~0x41A7FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 25165824 bytes Data Checksum: 3E66 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 05 FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Data Sections : 01 Current File : rm872__03.58.ppm_m4 Compile Name: package_m4.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 5714012 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 PPM Erase Block: 0x41A80000~0x420FFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 5710668 bytes Data Checksum: B665 Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Data Sections : 01 Current File : rm872__03.58.image_m4_059Q4L3 Compile Name: package_m4_059Q4L3.image.fls Image Type : CONTENT Package Data Size : 15731984 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 CONTENT Erase Block: 0x42100000~0x43E1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 15728640 bytes Data Checksum: E098 Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Processing Section 02 CONTENT Erase Block: 0x43E60000~0x43F3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:07:02 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 03.58 05-12-12 RM-872 (c) Nokia IMEI Plain : 355922051571400 IMEI Spare : A355922051571400 IMEI SV : 33559220515714005F IMEI (2nd) : 355922051571418 IMEI Spare : A355922051571410 IMEI SV : 33559220515714105F Phone Model: Kƒ 206 Category : Entry Phone Type : RM-872 ================================================ Extended Phone Information ================================================ Product Serial Number: E944E7CAH Product Code : 059Q8K7 Module Code : 0205283 Basic Production Code: 059P6H1 Long Production SN : 0 PPM SW Version : V 03.58 05-12-12 RM-872 (c) Nokia M4 BT MCM Version : 19b5-22012 MCU SW Version : V 03.58 05-12-12 RM-872 (c) Nokia HW Version : 1600 RFIC Version : 68 LCD Version : TPO Content Pack Version : Content: m4_059Q4L3 V 03.58 05-12-12 RM-872 (c) Nokia Bluetooth ID : 4C:25:78:A3:6E:4E CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000004000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 0FD00F22 DCC Ver: 004004 Status : OK ================================================== ==== Selected VPL File: RM872_059Q4L3_03.58_016.vpl ================================================== ==== Variant Details : RM-872 MEA_M4_BLACK_ARABIC_BH Software Version : 03.58 Product Type : RM-872 Product Code : 059Q4L3 Variant Version : 016 FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK RESET LIFE TIMER TO : 0000:00 OK Changing Phone Mode... (Wait for 10 seconds) Successfully set to : Normal |
BEST can read hash for BF/Server unlock. |
Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 03.58 05-12-12 RM-872 (c) Nokia IMEI Plain : 356324053232868 IMEI Spare : A356324053232860 IMEI SV : 33563240532328605F IMEI (2nd) : 356324053232876 IMEI Spare : A356324053232870 IMEI SV : 33563240532328705F Phone Model: K 206 Category : Entry Phone Type : RM-872 ================================================ Extended Phone Information ================================================ Product Serial Number: F0FAE71AH Module Code : 0205283 Basic Production Code: 059P6H2 Long Production SN : 0 PPM SW Version : V 03.58 05-12-12 RM-872 (c) Nokia S3 BT MCM Version : 19b5-22012 MCU SW Version : V 03.58 05-12-12 RM-872 (c) Nokia HW Version : 1600 RFIC Version : 68 LCD Version : TPO Content Pack Version : Content: s3_059Q477 V 03.58 05-12-12 RM-872 (c) Nokia Bluetooth ID : 3C:C2:43:47:79:33 CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0000000000000000 PROFILE_BITS : 0000000000040000 ASIC : 11 PROVIDER : Unknown Provider Unable to read SP Data.. SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : FAILED SECURITY_TEST : PASSED SECURITY_CODE : ENCRYPTED PHONE_MODE : TEST help help help |
bro this sl3 type first backup rpl file then rewrite same file post result |
