01-05-2016, 07:23 | #1 (permalink) |
No Life Poster Join Date: May 2014 Location: Tamil_Nadu Rasipuram
Member: 2185083 Status: Offline Sonork: 100.1670782:dineshras Thanks Meter: 185 | nokia 208.1 (rm-948) phone restriced ??? phone restriced means ? how to solve this problem ? i need help |
01-05-2016, 08:38 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Read RPL ( Xgold ) Read info, check result - seems as locked or something similar. Need logs. |
01-05-2016, 10:35 | #3 (permalink) |
Member: 2185083 Status: Offline Sonork: 100.1670782:dineshras Thanks Meter: 185 | Card found: S/N : CAEB8D84 , v0122 Registered to: dinesh Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Read and Check phone data... ---------------------- RAP_BOOT: 0000000000000000 RAP_PUB: 0000000000000000000000000000000000000000 CMT_ROOT: 00000000000000000000000000000000 RAP_PAPUB: 0000000000000000000000000000000000000000 ---------------------- Live Test Ok! ---------------------- CNT sector : 128 kb ------------------------ CMLA Key status : CMLA key is Ok SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL30 (20 digit) phone detected... |
01-05-2016, 19:43 | #5 (permalink) |
Member: 2185083 Status: Offline Sonork: 100.1670782:dineshras Thanks Meter: 185 | Card found: S/N : CAEB8D84 , v0122 Registered to: dinesh Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 208 Software ver : V 06.01 17-10-13 RM-948 (c) Nokia IMEI : 359191051241960 XappVer : 00000866 PPM : V 06.01 17-10-13 RM-948 (c) Nokia S4 CNT : Content: s4_059S5R7 V 06.01 17-10-13 RM-948 (c) Nokia Product SN : 55F9272BH Product code : 059V9C1 Base Prd.code: 059S0K8 Module code : 0205616 Long Prod.SN : 0 Hardware info======= HWID : 1001 Retu : PMU_MAXIM8939B Battery: 4019 mV CMT BT: 19e2-4702G12 LCDVer: TPO Lock info =========== IMEI : 359191051241960 IMEI spNet : 3A 95 91 01 15 42 91 06 IMEI svNet : 33 95 91 01 15 42 91 26 F2 Sl Conf : 525-05-00098242110 Sl Prof : 800000000004000-B Sl Aux : 000B0000 Hw Sig : 3182C01CC98A2FA1 Country : Singapore Operator : STARHUB Lock info: Block 1 L1:Close; Error collect lock info, try again CRT308 Backup Created CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL30 (20 digit) phone detected... User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
01-05-2016, 23:20 | #6 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: Apple pocket Age: 32
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | Quote:
i will give clear information regarding the issue the phone is called Sl3 phone Sl3 is 2 types security category Sl3 15 Digit ( to unlock this phone need to read bcl file to process code) Sl3 20 digit( it can be unlocked by only carrier and country) now see ur phone in red color mark area. i hope you will get info all in clear | |
The Following User Says Thank You to ..::Gsmideazone::.. For This Useful Post: |
01-06-2016, 05:16 | #7 (permalink) |
Member: 2185083 Status: Offline Sonork: 100.1670782:dineshras Thanks Meter: 185 | how to unlock is phone i need guid step by step |
The Following User Says Thank You to dineshras For This Useful Post: |
01-06-2016, 07:30 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Need seek for someone, who provide codes for this SP. Check in Infinity Online Services. |
02-24-2018, 13:38 | #9 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | Nokia 208.1 rm-948 phone restricted problem NOKIA 208.1 RM-948 PHONE RESTRICTED PROBLEM HOW TO SOLVE THIS PHONE PLEASE HELP ME SIR [IMG][/IMG] |
09-22-2021, 18:07 | #11 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Look to me like you either dont read, or dont understand, so which of these two is ? 1. PA_SL30 (20 digit) phone detected = You need to BUY CODE (if available) 2. PA_SL30 (15 digit) phone detected = You either need to locally bruteforce code, or pay to someone who still do SL3 bruteforcing. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
