02-07-2020, 17:00 | #1 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,802 | Nokia 210 TA-1139 FLASHING DONE Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... Device not found ! Check cable, connection and drivers! Reconnect Power/Cable! Open VPLfile : TA-1139_059Z0X8_20.00.11.vpl Description : TA-1139 IC DeviceType : TA-1139 ProductCode : 059Z0X8 SoftwareVer : 20.00.11 PPM LangPack : [1] : Arabic (Saudi Arabia) [2] : French (France) [3] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM91) MODE : NOKIA USB SERIAL PORT : 91 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : AD6714354DA63A84EAF55E8A768C31CB BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : OUTRUN.20.00.11.p1 BOOT : SWR : 20.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : OUTRUN.20.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00C8 : 0060 : 0018 : 0000 NOR: [GigaDevice] GD25LQ128 NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_NOT_SUPPORT STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 20.00.11 [TA-1139] DEV SoftwareVersion : 20.00.11 SWInfo compare result : SAME Load FlashSet : MROM : TA-1139_ROM_eMP_20.00.11 LANG : TA-1139_LANG_PACK_ROM_IC_eMP_20.00.11_001 CUST : TA-1139_CUSTPACK_ROM_IC_eMP_20.00.11_001 JUMP : TA-1139_JUMP_TABLE_IC_eMP_20.00.11_001 VIVA : TA-1139_VIVA_eMP_20.00.11 Prepare FlashSet : DCR : TA-1139_ROM_eMP_20.00.11 DCR : TA-1139_LANG_PACK_ROM_IC_eMP_20.00.11_001 DCR : TA-1139_CUSTPACK_ROM_IC_eMP_20.00.11_001 DCR : TA-1139_JUMP_TABLE_IC_eMP_20.00.11_001 DCR : TA-1139_VIVA_eMP_20.00.11 Prepare Target SDS : OK : 0x00FF4000 : 0x0000C000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : TA-1139_ROM_eMP_20.00.11 Write : TA-1139_LANG_PACK_ROM_IC_eMP_20.00.11_001 Write : TA-1139_CUSTPACK_ROM_IC_eMP_20.00.11_001 Write : TA-1139_JUMP_TABLE_IC_eMP_20.00.11_001 Write : TA-1139_VIVA_eMP_20.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1139_ROM_eMP_20.00.11 Verify : TA-1139_LANG_PACK_ROM_IC_eMP_20.00.11_001 Verify : TA-1139_CUSTPACK_ROM_IC_eMP_20.00.11_001 Verify : TA-1139_JUMP_TABLE_IC_eMP_20.00.11_001 Verify : TA-1139_VIVA_eMP_20.00.11 Done! Elapsed: 00:02:32 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to profkefah For This Useful Post: |
