07-17-2017, 08:23 | #1 (permalink) | |
No Life Poster Join Date: Aug 2011 Location: Afghanistan
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | NOKIA 216 RM-1187 and NOKIA RM-1190 Contact Service even with higher version Quote:
WBR | |
07-17-2017, 08:53 | #3 (permalink) | |
Freak Poster Join Date: Jan 2016 Location: Afghanistan
Member: 2520139 Status: Offline Sonork: masoudsoftware Thanks Meter: 300 | Quote:
remove battry Check in sticker prodoct code find some and flash phone will be ok tested i have some problom now fixed | |
07-17-2017, 11:47 | #5 (permalink) |
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | Both phone were fixed with lower version ij files its own version was 11 with 12 it became CS but with 10 it fixed this confuse me if version not matter what is important ? |
07-17-2017, 15:03 | #6 (permalink) | |
Those phones may have 2 version of firmware (old and new sec) Nokia 150 (it has legacy and hmd version) Nokia 105, Nokia 130, Nokia 216, Nokia 222, Nokia 230: probably two versions are available CS problem after flashing may be a result of flashing different version. Just reflash to another one ( SW10: LEGACY, SW11 and newer: HMD ) | |
The Following User Says Thank You to masoudsoftwrae For This Useful Post: |
07-18-2017, 09:21 | #7 (permalink) |
Freak Poster Join Date: Nov 2007 Location: Bangladesh
Member: 638097 Status: Offline Sonork: 100.1649741 Thanks Meter: 43 | Sir i m in this problem , customer told me that he flashed it for change language , now i flashed it by hier v loer v but same , guide me sir thanks its my log Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1035_ROM_eMP_11.00.11 VIVA : RM-1035_VIVA_eMP_11.00.11 LANG : RM-1035_LANG_PACK_ROM_AH_eMP_11.00.11_002 CUST : RM-1035_CUSTPACK_ROM_AH_EURO_GR_eMP_11.00.11_002 JMPT : RM-1035_JUMP_TABLE_AH_EURO_GR_eMP_11.00.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 24 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : B6AE1660D422BA1372F749FBBFE156A4 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_11.00.11 SecureDecrypt : RM-1035_VIVA_eMP_11.00.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_AH_eMP_11.00.11_002 SecureDecrypt : RM-1035_CUSTPACK_ROM_AH_EURO_GR_eMP_11.00.11_002 SecureDecrypt : RM-1035_JUMP_TABLE_AH_EURO_GR_eMP_11.00.11_002 OVRLP : 000069B900000001 PHPID : CRYSTAL.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_11.00.11 Write : RM-1035_LANG_PACK_ROM_AH_eMP_11.00.11_002 Write : RM-1035_CUSTPACK_ROM_AH_EURO_GR_eMP_11.00.11_002 Write : RM-1035_JUMP_TABLE_AH_EURO_GR_eMP_11.00.11_002 Write : RM-1035_VIVA_eMP_11.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_11.00.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_AH_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_AH_EURO_GR_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_JUMP_TABLE_AH_EURO_GR_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_VIVA_eMP_11.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:00:59 Reboot phone Ok BR |
07-18-2017, 11:36 | #8 (permalink) | |
remove battry Check in sticker CODE find some and flash phone will be ok | |
The Following 2 Users Say Thank You to masoudsoftwrae For This Useful Post: |
