05-01-2014, 14:02 | #1 (permalink) | |
No Life Poster Join Date: Jun 2008 Location: Wish i was on Mars Age: 40
Member: 789089 Status: Offline Sonork: 100.1617*** Thanks Meter: 267 | nokia 220 code not able to disable Dzirt I have a nokia 220 for user code I have installed the proper drivers as u said in some thread. Quote:
LOG Code: Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 10.03.11 00-00-00 RM-969 IMEI 1 : IMEI 2 : XappVer : 00000758 Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : MH CNT : Rivendell.10.03.11.p1 Product SN : 138E1FDAU Product code : 059V107 Base Prd.code: 059T730 Module code : 0205836 Hardware info======= HWID : 3000 LCDVer: TPO Lock info =========== IMEI : IMEI spNet : Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; SimLock status : Ok Security status : Ok Done! Rebooting phone to FlashMode... Wait for phone... Device boot not done Check Drivers Try again Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok also I am not able to see this window while I had installed the drivers Plz advice how do I disable user code on this phone thanks in advance Br frenzy | |
05-01-2014, 14:26 | #6 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Why not try from dead mode? Hint : disconnect all VCP devices - e.g. boxes. And try again. If system not in good condition it can stuck on COM port enumerate. |
05-01-2014, 14:29 | #7 (permalink) | |
Member: 789089 Status: Offline Sonork: 100.1617*** Thanks Meter: 267 | Quote:
I have disconnected all devices,how do I try in dead mode, do u mean switch off phone and click flash and connect the phone as I have already tried it. correct me if wrong plz thanks | |
05-01-2014, 14:37 | #8 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Reboot PC. Use other USB port. Insert cable in powered Off phone. After 5-7 seconds - remove cable, battery. Repeat stat 3 times. Disconnect all other devices. Run BEST, MTK tab , select need operation - e.g. for rest code - Format/Factory set Insert cable. It must work in that case. |
05-01-2014, 16:26 | #9 (permalink) | |
will give this a try and get back to u, so u do agree that installation of my drivers is perfect.Its not a issue of drivers then. frenzy | |
05-01-2014, 16:37 | #11 (permalink) | |
when the phone is in normal mode and if i try to flash or format the phone tries to go in DL mode or tries to reset, but it is not able to so phone come in the normal mode again and keeps on charging I still think it might be a driver issue then. how do I uninstall the drivers completely and start afresh. frenzy | |
05-01-2014, 16:40 | #12 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Via Control Panel - Programs It will be inside. After reboot PC. Install Nokia Serial driver again. Reboot. Try flash. Try from dead mode as well. |
05-01-2014, 16:43 | #13 (permalink) | |||
I am really sorry to trouble you Dzirt, but when you say Quote:
frenzy | |||
05-01-2014, 17:05 | #14 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | From Meego and all next tab there is no "dead" or "alive" mode more. I leave this for BB5 , because all users know this modes from long time ago , so , others now without it. BEST know - connected phone or not and with this info it start need mode. |
The Following User Says Thank You to Dzirt For This Useful Post: |
